Can this 5-axis FDM be configured with RRF?
Posting here since it's 5 axis, but this is for a 3D printer project.
Only focusing on the rotational axes in this topic, I want to build the illustrated design so that the nozzle can rotate.At rest position the axis closest to the end effector is parallel to the Y axis, and the next one is parallel to the X axis. Both have offsets (one relative to the other and to the end effector).
XY axes are CoreXY, Z connected to the carriage, fixed bed. So reading the documentation this would be a XYZAB or something like that? And there should be some way to configure them using M669, but am not sure the firmware has support for all the parameters. It mostly talks about AC/BC configurations where offsets are supported, but doesn't mention offsets for AB and I couldn't find a good example configuration to get inspiration from.What I would like to get from the firmware is the IK solving so that when the g-code asks for a motion that involves A and B axes rotation, it will adjust the XYZ position so that the end effector stays in the same place with relation to the bed, but changes angles.
I'm asking here if this is supported by the firmware so that I don't invest time in building a device that cannot be configured.
Edit: here are the two vectors I'm wondering how to configure.
@MihaiDesigns I don't think that kinematic type is supported in the 'normal' firmware, but there is work on-going on a version of RRF that, I think, might support it, which is @JoergS5's work: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuring_RepRapFirmware_for_a_Robot_printer
The development discussion is here, though focus is more on palletised robots (4 axis arms, basically): https://forum.duet3d.com/topic/17421/robotic-kinematics/383
This recent thread describes a machine where moves in BC move XYZ too, I think similar to your requirement: https://forum.duet3d.com/topic/35865/voron5x-with-rtcp/Hope that helps!
@droftarts said in Can this 5-axis FDM be configured with RRF?:
I see that the robot printer still implements only AC and BC (used for the Voron5X).
Since I need this for a PoC, I guess one somewhat easy solution is to write a gcode processor that calculates the XYZ compensation when rotating A and B. I mean it would anyways be some generated gcode to print basic shapes with steep overhangs (it's one of the reasons I wanted the rotating axes).
In which case the firmware needs to move some extra axes I suppose, like G1 X Y Z U V? Then it would move all axes at the same time? And my gcode processor segments the moves into very short segments (0.2mm in length or so). Am I going the right direction here? -
@MihaiDesigns If you use a Gcode post process to calculate the offsets, then yes you can move multiple axes at the same time with the 'normal' firmware.
@MihaiDesigns Pre-processing such a big part of a sliced file will mess up the extrusion calculation, too.
Unless your slicer already knows about the extra axes and it's just RRF that needs to be altered.
