Multiple motion system
@dc42 Thank you
@Alva I have reproduced this and I am looking into it.
@Alva I created https://github.com/Duet3D/RepRapFirmware/issues/1064 and I am testing a fix.
@Alva please try the new Duet 3 Mini firmware binary at https://www.dropbox.com/scl/fo/pasag1g18orahwvn49qp2/ABWgw6D-TyKWxxurTmGwiUE?rlkey=r9h3rjyw1l4wh7xbr8yho37gw&dl=0.
@dc42 It seems to be working. I have tried all the above conditions and works as intended. Can i expect the same fix for Duet3 6HC board as well, as i observed the same behavior in it as well. Thank you
@Alva I have just put a 6HC build at the same location.
@dc42 Thank you , I will check it out
@Alva please can you confirm if you have tested this.
