    Multiple motion system
    69
    2.6k
    • Alvaundefined
      Alva @Alva
      @Alva Looks like it is a timing problem or something.
        dc42 administrators @Alva
        @Alva thanks, I will try to replicate it.
        Alvaundefined 1 Reply Last reply Reply Quote 0
        • Alvaundefined
          Alva @dc42
          @dc42 Thank you 🙏
          dc42undefined 3 Replies Last reply Reply Quote 0
            @Alva I have reproduced this and I am looking into it.
              @Alva I created https://github.com/Duet3D/RepRapFirmware/issues/1064 and I am testing a fix.
              dc42 created this issue in Duet3D/RepRapFirmware
              closed Use of multiple motion systems causes Code 3 halts in 3.6 beta1 and beta2 releases #1064
                @Alva please try the new Duet 3 Mini firmware binary at https://www.dropbox.com/scl/fo/pasag1g18orahwvn49qp2/ABWgw6D-TyKWxxurTmGwiUE?rlkey=r9h3rjyw1l4wh7xbr8yho37gw&dl=0.
                • Alvaundefined
                  Alva @dc42
                  @dc42 It seems to be working. I have tried all the above conditions and works as intended. Can i expect the same fix for Duet3 6HC board as well, as i observed the same behavior in it as well. Thank you 🙂
                    @Alva I have just put a 6HC build at the same location.
                    • Alvaundefined
                      Alva @dc42
                      @dc42 Thank you , I will check it out
                        T3P3Tony administrators @Alva
                        @Alva please can you confirm if you have tested this.
                        • Alvaundefined
                          Alva @T3P3Tony
                          @T3P3Tony Hello sorry, i haven't checked it out. The 6HC board i have is bit different from the original version. So i need to build it differently. I am actually waiting for the beta 3 version of the firmware now.
                            @Alva you could try 3.6.0-beta.2+5 at https://www.dropbox.com/scl/fo/1l1t3h52jkapaszdpcruz/AOWakD9qTwZ2HRnV7N3vVvQ?rlkey=42ehcpbas7rwgz6z1318mbceh&dl=0 if you like. Use it with care because the changes in it are quite substantial. You may wish to reduce motors currents until you are happy that it behaves correctly. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta3-in-preparation for important changes.
                            Alvaundefined 2 Replies Last reply Reply Quote 0
                            • Alvaundefined
                              Alva @dc42
                              @dc42 Thank you. I will try it out and let you know the status.
                              • Alvaundefined
                                Alva @dc42
                                @dc42 g binary "0:/firmware/Duet3_SDiap32_MB6HC.bin" not found , in the drop box this file is not available
                                  droftarts administrators @Alva
                                  @Alva Get the "Duet3_SDiap32_MB6HC.bin" file individually from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
                                  Otherwise it's in the zip file download in most releases, eg in "Duet2and3Firmware-3.5.4.zip" here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4
                                  • Alvaundefined
                                    Alva @droftarts
                                    @droftarts thank you. got it.
                                    • Alvaundefined
                                      Alva @Alva
                                      @Alva Tested the second motion system with the new version 3.6.0.beta2 + 5, but i am getting the error shows in the picture below:
                                      tried gcode :
                                      set global.daemonStop = true ; stopped the daemon
                                      M118 S{"starting to move"}
                                      G90
                                      set global.daemonStop = false ; activated the daemon which only use U axis
                                      G1 X0 Y0
                                      M400 S1
                                      G91
                                      G1 X100 Y100 F200
                                      M400 S1
                                      G90
                                      M118 S{"move done"}
                                      M99
                                      daemon.g :
                                      ; File Name: 		/sys/daemon.g
                                      if(!exists(global.daemonStop))
                                      	global daemonStop = false	; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file
                                      while( global.daemonStop == false )
                                          if(state.status== "processing")
                                              G91
                                              M596 P1
                                              G1 U5 F300
                                              M596
                                          G4 P0
                                      M99; Exit; File Name: 		/sys/daemon.g
                                      • Alvaundefined
                                        Alva @Alva
                                        @Alva U axis was trying to use only in the second motion system. so motion system 0 and motion system 1 are not able to execute simultaneously.
                                        • Alvaundefined
                                          Alva @Alva
                                          @Alva i have tried the same with the 3.6.0.beta2 +3 it worked as intended
                                          Alvaundefined 1 Reply Last reply Reply Quote 1
                                          • Alvaundefined
                                            Alva @Alva
