    Octopus Pro F429 with wifi module, does it run RRF?
    STM
    • RodrigoRMaraujoundefined
      RodrigoRMaraujo
      Hello everyone.
      I bought this Octopus Pro F429 with a Wi-Fi module esp32.
      Could you tell me if RRF runs on this board?
      I haven't learned anything about this RRF variant yet, even though I've been using Duet boards since 2019. I have a Corexy with an Octopus board running Klipper, and I want to replace it with this one with RRF and stop using Klipper.
      WhatsApp Image 2024-12-23 at 14.43.38 (1).jpeg WhatsApp Image 2024-12-23 at 14.43.38 (2).jpeg WhatsApp Image 2024-12-23 at 14.43.38.jpeg
      oliofundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @RodrigoRMaraujo
        @RodrigoRMaraujo should work
        • gloomyandyundefined
          gloomyandy @RodrigoRMaraujo
          @RodrigoRMaraujo It looks like it has a STM32F429ZGT6 mcu, in which case yes RRF should run on it. See: https://teamgloomy.github.io/btt_octopus_pro_1.0_f429_general_3_5.html
          Before going too far you might also want to spend some time reading some of the background notes on the stm32 port https://teamgloomy.github.io/index.html
          RodrigoRMaraujoundefined 2 Replies Last reply Reply Quote 0
            RodrigoRMaraujo @gloomyandy
            @gloomyandy thank you.
            I will read everything!
              @gloomyandy
              I managed to install and update to version 3.5.4.
              I'm confused whether I need to update the wifi firmware or should I keep it as it is working. Can you clarify this doubt for me?
              Thank you.
                jay_s_uk @RodrigoRMaraujo
                @RodrigoRMaraujo best to update it
                RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 0
                  RodrigoRMaraujo @jay_s_uk
                  @jay_s_uk
                  Thank you!
