    Issue with SZP on Secondary Idex Toolhead
    731
    • Superbrain8undefined
      Superbrain8 @T3P3Tony
      @T3P3Tony installed the new firmware, homed the printer but it still fails to home the Z axis
      here is a M122 after the failed home attempt
      RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-beta.4+2 (2025-02-18 10:06:11) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: YQ6KF-K096U-D65J0-40KMG-4G03Z-H28XK
      Used output buffers: 1 of 40 (22 max)
      Static ram: 94764
      Dynamic ram: 97496 of which 12 recycled
      Never used RAM 49196, free system stack 188 words
      Tasks: NETWORK(1,ready,10.2%,235) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,353) TMC(4,nWait 6,0.8%,99) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,353) MAIN(1,running,86.2%,659) IDLE(0,ready,1.8%,29) USBD(3,blocked,0.0%,147) AIN(4,delaying,0.8%,269), total 100.0%
      Owned mutexes:
      Last reset 00:00:14 ago, cause: software
      Last software reset at 2025-02-23 14:59, reason: HeatTaskStuck, Gcodes spinning, available RAM 49124, slot 0
      Software reset code 0x0143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x200117d8 Task Move Freestk 1018 ok
      Stack: 00000000 2001112c 10000000 e000e000 20000f4c 0009f255 0009fa40 61000000 20016e08 200235b8 200235b8 20023530 00053f71 00007ff0 00000001 00056d53 a5a5a5a5 200235b8 20023538 00000000 a5a5a500 418a2040 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
      === Storage ===
      Free file entries: 20
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
      No step interrupt scheduled
      Driver 0: standstill, SG min 4, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
      Driver 1: standstill, SG min 10, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
      Driver 2: standstill, SG min 0, r/w errs 0/1, ifcnt 64, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
      Driver 3: standstill, SG min 2, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
      Driver 4: standstill, SG min 0, r/w errs 0/1, ifcnt 64, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
      Driver 5: not present
      Driver 6: not present
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      === Filament sensors ===
      Driver 11: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      Driver 10: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 168, received 761, lost 0, ignored 0, errs 0, boc 0
      Longest wait 2ms for reply type 6061, peak Tx sync delay 351, free buffers 26 (min 25), ts 70/69/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 5.21ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.2.1
      Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 39332
      MAC address f0:08:d1:02:e5:fa
      IP address 192.168.178.47
      Signal strength -42dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002002
      • gloomyandyundefined
        gloomyandy @Superbrain8
        @Superbrain8 If you reduce the length of the homing moves you are using (they are currently set to -99999) to something like -9999, do you still see the board reset?
        Superbrain8undefined 1 Reply Last reply Reply Quote 2
          Superbrain8 @gloomyandy
          @gloomyandy that fixed that issue, thanks.
          will see how the original issue for this post is fixed too
          Superbrain8undefined dc42undefined 2 Replies Last reply Reply Quote 1
            Superbrain8 @Superbrain8
            no that one still persists, the mesh is scanned in the Y axis instead of the X Axis but is generated as if scanned in the X Axis
            droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
              droftarts administrators @Superbrain8
              @Superbrain8 said in Issue with SZP on Secondary Idex Toolhead:
              I suspect this is because of the axis mapping of the second axis. It will need @dc42 to look at it, and probably fix in firmware.
              As a workaround for now, I think your options will be either to put the SZP on the primary toolhead, or swap the X and U axes, so that the second tool is referred to as the X axis, and the first tool is the U axis.
                dc42 administrators @Superbrain8
                @Superbrain8 thanks, we created this issue:
                https://github.com/Duet3D/RepRapFirmware/issues/1094
                It's scheduled to be fixed between 3.6.0-rc.1 and 3.6.0 stable.
                gloomyandy created this issue in Duet3D/RepRapFirmware
                closed Long homing moves can cause HeatTaskStuck software reset and/or Code 7 halts #1094
                • droftartsundefined droftarts referenced this topic
                  Please try the 3.6.0-rc.2+1firmware from https://www.dropbox.com/scl/fo/kj7gwwzxg5lhe26twph5z/AAdwkPCTYi6bcogLmIIIup4?rlkey=8oo6z5il7wzk2u5b7qpykf3qv&dl=0.
                  Superbrain8undefined 1 Reply Last reply Reply Quote 0
                    Superbrain8 @dc42
                    @dc42 Thanks for the reply,
                    running this firmware resolves the issue, it now Scans as expected in the X axis and the mesh generated also looks correct.
                    • Superbrain8undefined Superbrain8 has marked this topic as solved
                      @Superbrain8 thanks for confirming!
