    Issue with SZP on Secondary Idex Toolhead
    503
      T3P3Tony administrators @Superbrain8
      @Superbrain8 thanks. also:
      When you says it resets the wifi to home the machine, does it actually reset the entire board (i.e. the symptom of DWC disconnecting is actually the board resetting)?
      Does this happen everytime you home the machine?
      Superbrain8undefined 1 Reply Last reply Reply Quote 0
      • Superbrain8undefined
        Superbrain8 @T3P3Tony
        homing the machine causes it to get stuck when attempting to home the Z axis it times out and the wifi module seems to reset, that is atleast what i can see on the panel due that reconnects to the Wifi on timeout
        T3P3Tonyundefined 3 Replies Last reply Reply Quote 0
          @Superbrain8 ok interesting. can you run it a couple of times on 3.6.0beta4 and post the M122 after each one. I am looking to see if the error is identical.
            @Superbrain8 also please send a picture of the paneldue console when this happens for me to double check.
              Homed 3 times and ran M122 after each unsuccessful home
              RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-beta.4 (2025-02-11 09:50:58) running on Duet 3 Mini5plus WiFi (standalone mode)
              Board ID: YQ6KF-K096U-D65J0-40KMG-4G03Z-H28XK
              Used output buffers: 1 of 40 (24 max)
              Static ram: 94732
              Dynamic ram: 97496 of which 12 recycled
              Never used RAM 49228, free system stack 196 words
              Tasks: NETWORK(1,ready,14.4%,207) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,353) TMC(4,nWait 6,0.8%,99) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) MAIN(1,running,83.3%,659) IDLE(0,ready,0.5%,29) USBD(3,blocked,0.0%,147) AIN(4,delaying,0.8%,261), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:00:58 ago, cause: software
              Last software reset at 2025-02-22 17:15, reason: HeatTaskStuck, Gcodes spinning, available RAM 48832, slot 2
              Software reset code 0x0143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0000080f BFAR 0xe000ed38 SP 0x200117d8 Task Move Freestk 1018 ok
              Stack: 00000000 2001112c 10000000 e000e000 20000f4c 0009f1c5 0009f9b0 61000000 20016de8 20023598 20023598 20023510 00053fd1 00006a74 00000001 00056db3 a5a5a5a5 20023598 20023518 00000000 a5a5a500 4186a760 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
              === Storage ===
              Free file entries: 20
              SD card longest read time 0.7ms, write time 0.0ms, max retries 0
              Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
              No step interrupt scheduled
              Driver 0: standstill, SG min 90, r/w errs 0/1, ifcnt 31, reads/writes 3046/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 1: standstill, SG min 48, r/w errs 0/1, ifcnt 31, reads/writes 3046/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 2: standstill, SG min 2, r/w errs 0/1, ifcnt 31, reads/writes 3045/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 3: standstill, SG min 78, r/w errs 0/1, ifcnt 31, reads/writes 3045/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 4: standstill, SG min 2, r/w errs 0/1, ifcnt 31, reads/writes 3046/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 5: not present
              Driver 6: not present
              === DDARing 0 ===
              Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
              Segments left 0, axes/extruders owned 0x00000803, drives owned 0x00000803
              Code queue is empty
              === DDARing 1 ===
              Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000
              Code queue is empty
              Heater 1 is on, I-accum = 0.0
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              === Filament sensors ===
              Driver 11: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              Driver 10: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
              === CAN ===
              Messages queued 550, received 2913, lost 0, ignored 0, errs 0, boc 0
              Longest wait 3ms for reply type 6061, peak Tx sync delay 186, free buffers 26 (min 25), ts 277/276/0
              Tx timeouts 0,0,0,0,0,0
              === Network ===
              Slowest loop: 6.32ms; fastest: 0.00ms
              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              === WiFi ===
              Interface state: active
              Module is connected to access point
              Failed messages: pending 0, notrdy 0, noresp 0
              Firmware version 2.2.1
              Module reset reason: Power up, Vcc 3.41, flash size 2097152, free heap 39348
              MAC address f0:08:d1:02:e5:fa
              IP address 192.168.178.47
              Signal strength -39dBm, channel 6, mode 802.11n, reconnections 0
              Clock register 00002002
              Used output buffers: 1 of 40 (21 max)
              Static ram: 94732
              Dynamic ram: 97508 of which 0 recycled
              Never used RAM 49228, free system stack 192 words
              Tasks: NETWORK(1,ready,11.5%,205) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,356) Move(4,nWait 6,0.0%,353) TMC(4,nWait 6,0.8%,103) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,352) MAIN(1,running,85.2%,659) IDLE(0,ready,1.5%,29) USBD(3,blocked,0.0%,147) AIN(4,delaying,0.8%,261), total 100.0%
              Owned mutexes:
              Last reset 00:00:18 ago, cause: software
              Last software reset at 2025-02-22 17:17, reason: HeatTaskStuck, Gcodes spinning, available RAM 49012, slot 0
              Stack: 00000000 2001112c 10000000 e000e000 20000f4c 0009f1c5 0009f9b0 61000000 20016de8 20023598 20023598 20023510 00053fd1 0001491c 00000001 00056db3 a5a5a5a5 20023598 20023518 00000000 a5a5a500 418357f0 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
              === Storage ===
              Driver 0: standstill, SG min 92, r/w errs 0/1, ifcnt 48, reads/writes 933/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 1: standstill, SG min 48, r/w errs 0/1, ifcnt 48, reads/writes 933/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 2: standstill, SG min 0, r/w errs 0/1, ifcnt 48, reads/writes 932/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 3: standstill, SG min 78, r/w errs 0/1, ifcnt 48, reads/writes 932/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 4: standstill, SG min 0, r/w errs 0/1, ifcnt 48, reads/writes 933/14, timeouts 0, DMA errs 0, CC errs 0
              === DDARing 0 ===
              Code queue is empty
              === DDARing 1 ===
              Code queue is empty
              === CAN ===
              Messages queued 199, received 943, lost 0, ignored 0, errs 0, boc 0
              Longest wait 3ms for reply type 6061, peak Tx sync delay 6, free buffers 26 (min 25), ts 87/86/0
              === Network ===
              Slowest loop: 5.20ms; fastest: 0.00ms
              === WiFi ===
              Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 35904
              Signal strength -41dBm, channel 6, mode 802.11n, reconnections 0
              Used output buffers: 2 of 40 (22 max)
              Static ram: 94732
              Never used RAM 49228, free system stack 194 words
              Tasks: NETWORK(2,nWait 7,11.7%,225) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,371) Move(4,nWait 6,0.0%,353) TMC(4,delaying,0.8%,99) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,353) MAIN(1,running,85.2%,659) IDLE(0,ready,1.3%,29) USBD(3,blocked,0.0%,147) AIN(4,delaying,0.8%,255), total 100.0%
              Last reset 00:00:19 ago, cause: software
              Last software reset at 2025-02-22 17:17, reason: HeatTaskStuck, Gcodes spinning, available RAM 49012, slot 1
              Stack: 00000000 2001112c 10000000 e000e000 20000f4c 0009f1c5 0009f9b0 61000000 20016de8 20023598 20023598 20023510 00053fd1 00009760 00000001 00056db3 a5a5a5a5 20023598 20023518 00000000 a5a5a500 41836d80 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
              === Storage ===
              Driver 0: standstill, SG min 92, r/w errs 0/1, ifcnt 65, reads/writes 1016/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 1: standstill, SG min 46, r/w errs 0/1, ifcnt 65, reads/writes 1015/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 2: standstill, SG min 0, r/w errs 0/1, ifcnt 65, reads/writes 1015/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 3: standstill, SG min 78, r/w errs 0/1, ifcnt 65, reads/writes 1015/14, timeouts 0, DMA errs 0, CC errs 0
              Driver 4: standstill, SG min 0, r/w errs 0/1, ifcnt 65, reads/writes 1016/14, timeouts 0, DMA errs 0, CC errs 0
              === DDARing 0 ===
              Code queue is empty
              === DDARing 1 ===
              Code queue is empty
              === CAN ===
              Messages queued 213, received 1029, lost 0, ignored 0, errs 0, boc 0
              Longest wait 2ms for reply type 6061, peak Tx sync delay 3, free buffers 26 (min 25), ts 94/93/0
              === Network ===
              Slowest loop: 5.17ms; fastest: 0.00ms
              === WiFi ===
              Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 35908
              and here the Picture of the panel due Console
                @Superbrain8
                It looks like from the M122 that the whole board is resetting on homing
                Here is an experimental build that it would be good to test please.
                Duet3Firmware_Mini5plus.uf2
                It is an internal build to fix a different issue but that also presented as a heattaskstuck so they may be related,,
                  @T3P3Tony installed the new firmware, homed the printer but it still fails to home the Z axis
                  here is a M122 after the failed home attempt
                  RepRapFirmware for Duet 3 Mini 5+ version 3.6.0-beta.4+2 (2025-02-18 10:06:11) running on Duet 3 Mini5plus WiFi (standalone mode)
                  Used output buffers: 1 of 40 (22 max)
                  Static ram: 94764
                  Never used RAM 49196, free system stack 188 words
                  Tasks: NETWORK(1,ready,10.2%,235) LASER(5,nWait 7,0.0%,269) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,353) TMC(4,nWait 6,0.8%,99) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,353) MAIN(1,running,86.2%,659) IDLE(0,ready,1.8%,29) USBD(3,blocked,0.0%,147) AIN(4,delaying,0.8%,269), total 100.0%
                  Owned mutexes:
                  Last reset 00:00:14 ago, cause: software
                  Last software reset at 2025-02-23 14:59, reason: HeatTaskStuck, Gcodes spinning, available RAM 49124, slot 0
                  Stack: 00000000 2001112c 10000000 e000e000 20000f4c 0009f255 0009fa40 61000000 20016e08 200235b8 200235b8 20023530 00053f71 00007ff0 00000001 00056d53 a5a5a5a5 200235b8 20023538 00000000 a5a5a500 418a2040 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                  === Storage ===
                  Driver 0: standstill, SG min 4, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
                  Driver 1: standstill, SG min 10, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
                  Driver 2: standstill, SG min 0, r/w errs 0/1, ifcnt 64, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
                  Driver 3: standstill, SG min 2, r/w errs 0/1, ifcnt 63, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
                  Driver 4: standstill, SG min 0, r/w errs 0/1, ifcnt 64, reads/writes 741/14, timeouts 0, DMA errs 0, CC errs 0
                  === CAN ===
                  Messages queued 168, received 761, lost 0, ignored 0, errs 0, boc 0
                  Longest wait 2ms for reply type 6061, peak Tx sync delay 351, free buffers 26 (min 25), ts 70/69/0
                  === Network ===
                  Slowest loop: 5.21ms; fastest: 0.00ms
                  === WiFi ===
                  Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 39332
                  Signal strength -42dBm, channel 6, mode 802.11n, reconnections 0
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @Superbrain8
                    @Superbrain8 If you reduce the length of the homing moves you are using (they are currently set to -99999) to something like -9999, do you still see the board reset?
                    Superbrain8undefined 1 Reply Last reply Reply Quote 2
                      Superbrain8 @gloomyandy
                      @gloomyandy that fixed that issue, thanks.
                      will see how the original issue for this post is fixed too
                      Superbrain8undefined dc42undefined 2 Replies Last reply Reply Quote 1
                        Superbrain8 @Superbrain8
                        no that one still persists, the mesh is scanned in the Y axis instead of the X Axis but is generated as if scanned in the X Axis
                        droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          droftarts administrators @Superbrain8
                          @Superbrain8 said in Issue with SZP on Secondary Idex Toolhead:
                          I suspect this is because of the axis mapping of the second axis. It will need @dc42 to look at it, and probably fix in firmware.
                          As a workaround for now, I think your options will be either to put the SZP on the primary toolhead, or swap the X and U axes, so that the second tool is referred to as the X axis, and the first tool is the U axis.
                            dc42 administrators @Superbrain8
                            @Superbrain8 thanks, we created this issue:
                            https://github.com/Duet3D/RepRapFirmware/issues/1094
                            It's scheduled to be fixed between 3.6.0-rc.1 and 3.6.0 stable.
                            gloomyandy created this issue in Duet3D/RepRapFirmware
                            closed Long homing moves can cause HeatTaskStuck software reset and/or Code 7 halts #1094
                            • droftartsundefined droftarts referenced this topic
                              Please try the 3.6.0-rc.2+1firmware from https://www.dropbox.com/scl/fo/kj7gwwzxg5lhe26twph5z/AAdwkPCTYi6bcogLmIIIup4?rlkey=8oo6z5il7wzk2u5b7qpykf3qv&dl=0.
                                Superbrain8 @dc42
                                @dc42 Thanks for the reply,
                                running this firmware resolves the issue, it now Scans as expected in the X axis and the mesh generated also looks correct.
                                • Superbrain8undefined Superbrain8 has marked this topic as solved
                                  @Superbrain8 thanks for confirming!
