    Mesh Bed Compensation Issue – Front Closer Than Rear
    369
    • cemuundefined
      cemu
      Hey everyone,
      I’m having an issue with mesh bed compensation on one of my IDEX printers using Duet2 with an Duex5. Everything seems to be working fine, but no matter what I do, the front of the bed is always closer than the rear. I’ve set up other printers using Duet3D, and they don’t have this problem, so I’m not sure what might be causing it in this case.
      Has anyone run into this before? Any suggestions on what to check or adjust? I’d really appreciate any help!
      Thanks in advance!
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"IX Pro Lite"                                                               ; set printer name
      M575 P1 S1 B57600        ; configure PanelDue support
      M551 P"2845"        ; set password
      M552 S1        ; enable network
      M586 P0 S1        ; enable HTTP
      M586 P1 S1        ; enable FTP
      M586 P2 S1        ; enable Telnet
      M569 P0 S0        ; physical drive 0 goes forwards
      M569 P1 S1        ; physical drive 1 goes forwards
      M569 P2 S0        ; physical drive 2 goes forwards
      M569 P3 S0        ; physical drive 3 goes forwards
      M569 P4 S0        ; physical drive 4 goes forwards
      M569 P5 S1        ; physical drive 5 goes forwards
      M569 P6 S1        ; physical drive 6 goes forwards
      M569 P7 S1        ; physical drive 7 goes forwards
      M569 P8 S1        ; physical drive 8 goes forwards
      M584 X0 Y1:7 Z5:2:6 U8 E3:4                                                       ; set drive mapping
      M350 X16 Y16:16 Z16:16:16 U16 E16:16 I1                                           ; configure microstepping with interpolation
      M92  X80 Y80:80 Z800:800:800 U80 E691.84:691.84              ; set steps per mm
      M566 X800.00 Y300.00:300.00  Z150.00:150.00:150.00 U800.00 E900.00:900.00         ; set maximum instantaneous speed changes (mm/min)
      M203 X50000.00 Y30000.00:30000.00 Z1600.00:1600.00:1600.00 U50000.00 E10000:10000 ; set maximum speeds (mm/min)
      M201 X1000.00 Y750.00:750.00 Z500.00:500.00:500.00 U10000.00 E5000:5000           ; set accelerations (mm/s^2)
      M906 X1800 Y1800:1800 Z1250:1250:1250 U1800 E900:900 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84  S30        ; Set idle timeout
      M669 K0 X1:0:0:0 Y1:1:0:-1 Z0:0:1:0 U0:0:0:1
      M911 S21.0 R23.0 P"M913 Z0 G91 M83 G1 X5 E-5 F1000"
      M950 S8 C"duex.pwm2"
      M208 S1 X-63 Y-5 U0 Z-1                                                           ; set axis minima
      M208 S0 X500 Y315 U563 Z400                                                       ; set axis maxima
      ;Sağ ön Z ye bağlı e0stop, Sol ön e1stop, arka e2stop
      M574 X1 S1  P"xstop"                                                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^xstop
      M574 Y2 S1  P"ystop+duex.e3stop"                                                  ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^ystop
      M574 Z2 S1	P"e0stop+zstop+e1stop"                                                ; configure active-high endstops for low end on Z via pins zstop and e1stop
      M574 U2 S1  P"duex.e2stop"                                                        ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin ^zstop
      M671 X-100:250:600 Y-24:376:-24 S5                                                ; leadscrews at rear left, front middle and rear right
      M558 P8 R0.5 C"zprobe.in" H2 F400 T8000 A4 X0 Y0 Z5                               ; set Z probe type to effector and the dive height + speeds
      G31 P50 X0 Y0 Z17.8                                                              ; set Z probe trigger value, offset and trigger height
      M557 X30:470 Y30:270 S30                                                          ; probe from X=20 to 530, Y=0 to 270mm with a mesh spacing of 30mm
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   A"Bed_HEAT"                      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                                             ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 R1.184 C132.5 D3.43 S1.00 V24.2                                        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; map heated bed to heater 0
      M143 H0 S120        ; set temperature limit for heater 0 to 120C
      M308 S1 P"e1temp" Y"pt1000" pt1000 B4138  A"X_HEAT"                               ; configure sensor 3 as thermistor on pin e1temp
      M950 H1 C"e1heat" T1                                                              ; create nozzle heater output on e1heat and map it to sensor 3
       M307 H1 R3.845 K0.473:0.000 D3.95 E1.35 S1.00 B0 V24.1                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S301        ; set temperature limit for heater 2 to 280C
      M308 S2 P"e0temp" Y"pt1000" pt1000 B4138  A"U_HEAT"                               ; configure sensor 1 as thermistor on pin e0temp
      M950 H2 C"e0heat" T2                                                              ; create nozzle heater output on e0heat and map it to sensor 1
       M307 H2 R3.845 K0.473:0.000 D3.95 E1.35 S1.00 B0 V24.1                           ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S301        ; set temperature limit for heater 1 to 280C
      M950 F2 C"fan0" Q500                                                              ; create fan 0 on pin fan0 and set its frequency
      M106 P2 S1 H1 T40        ; set fan 0 value. Thermostatic control is turned on
      M950 F3 C"fan1" Q500                                                              ; create fan 1 on pin fan2 and set its frequency
      M106 P3 S1 H2 T40        ; set fan 1 value. Thermostatic control is turned on
      M950 F0 C"fan2" Q500                                                              ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"X-PC"                                                            ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"duex.fan3" Q500                                                         ; create fan 0 on pin fan0 and set its frequency
      M106 P1 S0 H-1 C"U-PC"                                                            ; set fan 0 value. Thermostatic control is turned off
      M950 F4 C"duex.e4heat" Q500                                                       ; create fan 0 on pin fan0 and set its frequency
      M106 P4 S0 H-1 C"Chamber"                                                         ; set fan 0 value. Thermostatic control is turned off
      M950 F5 C"duex.e5heat" Q500                                                       ; create fan 0 on pin fan0 and set its frequency
      M106 P5 S0 H-1 C"Static"                                                          ; set fan 0 value. Thermostatic control is turned off
      M950 F6 C"duex.e6heat" Q500                                                       ; create fan 0 on pin fan0 and set its frequency
      M106 P6 S0 H-1 C"Under Bed"                                                       ; set fan 0 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0 S"X"                                                             ; define tool 0
      G10 P0 X0 Y0 Z0 S0 R0                                                             ; set tool 0 axis offsets
      G10 P0 R0 S0        ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 X3 F1 S"U"                                                          ; define tool 1
      G10 P1 Y0 U0 Z0 S0 R0                                                             ; set tool 1 axis offsets
      G10 P1 R0 S0        ; set initial tool 1 active and standby temperatures to 0C
      ; Create a tool that prints 2 copies of the object using both carriages
      M563 P2 D0:1 H1:2 X0:3 F0:1 S"XU-Copy"                                            ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
      G10 P2 X0 Y0 U-250 S0 R0                                                          ; set tool offsets and temperatures
      M567 P2 E1:1        ; set mix ratio 100% on both extruders
      M568 P2 S1        ; turn on mixing for tool 2
      M563 P3 D0:1 H1:2 X0:3 F0:1 S"XU-Mirror"                                          ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
      G10 P3 X0 Y0 U-500 S0 R0                                                          ; set tool offsets and temperatures
      M567 P3 E1:1        ; set mix ratio 100% on both extruders
      M568 P3 S1        ; turn on mixing for tool 2
      if sensors.probes[0].value[0] == 0
          M291 P"Sensor-detected parking operation is started" R"Please Wait" T5 ; Display message
          G90                                                ; Set to Absolute Positioning
          G29 S2                                             ; Clear the height map
          T0                                                 ; Ensure Tool 0 is selected
          G28                                                ; Home All
          G1 X374 Y260 F5000 					               ; Go to Klick pick up point
          M280 P8 S22 						               ; Opes servo arm
          G1 X374 Y308 F2000 					               ; Drop Klick
          G1 X324 Y308 F2000 					               ; Remove Klick
          M280 P8 S130 						               ; Close servo arm
          M400
              while true
                  M291 P"Sensor could not be released. Please see service manual" R"ERROR" ; Display message
          else
              M291 P" Parking operation is completed" R"SUCCESS" T5 ; Display message
              G28
      T3P3Tonyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @cemu
        @cemu said in Mesh Bed Compensation Issue – Front Closer Than Rear:
        Please can you confirm what you have done. Also post your heighmap.csv (or the heighmap file you are using if not the default)
        www.duet3d.com
        cemuundefined 1 Reply Last reply Reply Quote 1
          droftarts administrators @cemu
          Please first check that your leadscrew couplings are tight, if that's how the motor is connected to the leadscrew, and that particularly the front Z carriage is moving freely on it's bearing, ie not getting stuck 'up'.
          Do you use three-point bed levelling using the Klicky probe near the leadscrew positions before mesh levelling? Ideally you need to do this every time you turn the machine on, as the motors can jump a couple of full steps in either direction when powered up, so the bed will can be in a different position each time. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
          Not a big issue (though it depends what version of RRF you are using), but the following Gcodes in your config.g can only take one parameter for X, Y, Z and U (E can take as many parameters as there are extruders):
          Generally, only the first parameter is used (because all motors on a multiple-motor axis must be identical). So should be:
          M350 X16 Y16 Z16 U16 E16:16 I1                                           ; configure microstepping with interpolation
          M92  X80 Y80 Z800 U80 E691.84:691.84              ; set steps per mm
          M566 X800.00 Y300.00  Z150.00 U800.00 E900.00:900.00         ; set maximum instantaneous speed changes (mm/min)
          M203 X50000.00 Y30000.00 Z1600.00 U50000.00 E10000:10000 ; set maximum speeds (mm/min)
          M201 X1000.00 Y750.00 Z500.00 U10000.00 E5000:5000           ; set accelerations (mm/s^2)
          M906 X1800 Y1800 Z1250 U1800 E900:900 I30                          ; set motor currents (mA) and motor idle factor in per cent
          Please post what version of RRF you are using. Send M122 and post the response.
          • cemuundefined
            cemu @T3P3Tony
            @T3P3Tony said in Mesh Bed Compensation Issue – Front Closer Than Rear:
            Hi Tony,
            Thanks for your response! Below, I’m sharing my probe repeatability test results, the latest height map, homing files, and my updated config file.
            I have tried to fine-tune the x y z axis steps per mm by measuring with a micrometer to ensure accuracy, did not work thus went back to stock steps per/mm. I have tested both three-point independent Z motor bed leveling and standard spring leveling, but the issue persists in both cases. Additionally, I have tried tweaking the lead screw coordinates to compensate for any potential mechanical misalignment. The mechanical system has been carefully checked for any loose components or inconsistencies. I have also tested after allowing the machine to thermally stabilize for 30+ minutes, but the results remain the same.
            @droftarts said in Mesh Bed Compensation Issue – Front Closer Than Rear:
            I have inspected the mechanical system, ensuring that the lead screw couplings are tight and that all Z carriages move freely without binding. I am using three-point independent Z motor leveling, the config has been adjusted according to your suggestion. However, after applying these updates, I am now getting the warning:
            "Warning: the height map has a substantial Z offset."
            Let me know if you need any additional details, and I appreciate any further suggestions!
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.4 (2024-11-24 10:43:42) running on Duet WiFi 1.02 or later + DueX5
            Board ID: 0JD0M-9P6M2-NW4SJ-6J1F8-3SJ6M-1ASHK
            Used output buffers: 17 of 26 (22 max)
            Static ram: 23488
            Dynamic ram: 74988 of which 0 recycled
            Never used RAM 12028, free system stack 98 words
            Tasks: NETWORK(2,nWait 6,15.2%,222) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,274) DUEX(5,nWait 5,0.0%,18) MAIN(1,running,84.5%,742) IDLE(0,ready,0.2%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:20:17 ago, cause: software
            Last software reset at 2025-02-08 11:59, reason: User, Gcodes spinning, available RAM 15000, slot 0
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 27.4, current 29.3, max 29.9
            Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/520/520, gc cycles 0
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min 0
            Driver 1: standstill, SG min 0
            Driver 2: standstill, SG min 0
            Driver 3: standstill, SG min n/a
            Driver 4: standstill, SG min n/a
            Driver 5: standstill, SG min 0
            Driver 6: standstill, SG min 0
            Driver 7: standstill, SG min 0
            Driver 8: standstill, SG min 0
            Driver 9: standstill, SG min n/a
            Driver 10:
            Driver 11:
            Date/time: 2025-02-08 12:19:44
            Slowest loop: 195.87ms; fastest: 0.17ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 12.0MBytes/sec
            SD card longest read time 8.1ms, write time 99.4ms, max retries 0
            DMs created 83, segments created 5, maxWait 137624ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
            no step interrupt scheduled
            Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
            === DDARing 0 ===
            Scheduled moves 238, completed 238, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 10], CDDA state -1
            Heater 0 is on, I-accum = 0.2
            Movement locks held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Q0 segments left 0
            Code queue 0 is empty
            === DueX ===
            Read count 39, 1.92 reads/min
            === Network ===
            Slowest loop: 344.29ms; fastest: 0.00ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            HTTP sessions: 1 of 8
            === WiFi ===
            Interface state: active
            Firmware version 2.2.0
            MAC address e0:98:06:a4:41:ab
            Module reset reason: Turned on by main processor, Vcc 3.42, flash size 4194304, free heap 31848
            WiFi IP address 100.100.10.51
            Signal strength -51dBm, channel 13, mode 802.11n, reconnections 0
            Clock register 00002002
            ; Configuration file for Duet2 WiFi + DueX5 (firmware version 3.5.4)
            G90
            M83
            M550 P"X Pro"        ; set printer name
            M586 P1 S0        ; FTP
            M586 P2 S0        ; Telnet
            M671 X-115:245:615 Y-30:375:-30 S5                                                   ; leadscrews at rear left, front middle and rear right
            M84  S10        ; Set idle timeout
            M208 S1 X-64.4 Y-5 U0 Z-1                                                            ; set axis minima
            M208 S0 X500 Y315 U564.98 Z400                                                       ; set axis maxima
            G31 P50 X0 Y3 Z17.55        ; set Z probe trigger value, offset and trigger height
            M140 H0
            M143 H0 S120
            M143 H1 S301
            M143 H2 S301
            M106 P2 S1 H1 T40
            M106 P3 S1 H2 T40
            M563 P0 S"X" D0 H1 F0
            G10 P0 X0 Y0 Z0 U0
            G10 P0 R0 S0
            M563 P1 S"U" D1 H2 F1 X3
            G10 P1 Y0.4 U0 Z-0.05 S0 R0
            G10 P1 R0 S0
            M563 P2 S"XU-Copy" D0:1 H1:2 X0:3 F0:1
            M567 P2 E1:1
            M568 P2 S1
            M567 P3 E1:1
            M568 P3 S1
            ; bed.g
            G90
            G29 S2
            M561
            T0
            G28
            G1 X372 F6000 						; Go to Klick pick up point
            M280 P8 S20 						; Opes servo arm
            G4 P1000
            G1 Y260 F5000 						; Pick Up Klick
            M400
            G1 X250 Y150 Z120 F5500 					; Go to bed center
            G30 								; Probe onece for Z=0
            G30 P0 X250 Y270 Z-99999 			; probe near a leadscrew
            G30 P1 X8 Y0 Z-99999 				; probe near a leadscrew
            G30 P2 X483 Y0 Z-99999 S3 			; probe near a leadscrew and calibrate 3 motors
            G1 X250 Y150 F6000 					; Go to bed center
            G29
            G1 Z120 F5000 						; Lower Bed
            G1 X372 Y260 F5000 					; Go to Klick pick up point
            G1 X372 Y312 F2000 					; Drop Klick
            G1 X322 Y312 F2000 					; Remove Klick
            M400
            ; homez.g
            ; called to home the Z axis
            M400
            M400 G91
            G1 H1 Z800 F15000
            G1 H2 Z-5 F7500
            G1 H1 Z500 F4500
            G90
            M400
            ;homeall.g
            ; called to home all axes
            M400
            M400 G91
            G1 H1 X-505 F4000
            G1 H2 X5 F9500
            G1 H1 X-320.5 F4000
            G90
            M400
            M400
            G91
            G1 H1 U505 F4000
            G1 H2 U-5 F9500
            G1 H1 U30 F4000
            G90
            M400
            G1 X-40 U547
            M400
            G91
            G1 H1 Y305 F4000
            G1 H2 Y-5 F8000
            G1 H1 Y305 F3500
            G90
            M400
            G1 Y305
            M400
            G91
            G1 H1 X-505 F4000
            G1 H2 X5 F9500
            G1 H1 X-320.5 F4000
            G90
            M400
            M400
            G91
            G4 P200
            G1 H1 U505 F4000
            G1 H2 U-5 F9500
            G1 H1 U30 F4000
            G90
            M400
            M400
            M400 G91
            G1 H1 Z800 F15000
            G1 H2 Z-5 F7500
            G1 H1 Z500 F4500
            G90
            M400
            RepRapFirmware height map file v2 generated at 2025-02-07 21:50	 min error -0.098	 max error 0.176	 mean 0.056	 deviation 0.055
            axis0	axis1	min0	max0	min1	max1	radius	spacing0	spacing1	num0	num1
            X	Y	2.75	497.67	1.83	295.96	-1	32	32	16	10
            0.022	0.017	0.051	0.052	0.046	0.066	0.128	0.091	0.171	0.124	0.106	0.107	0.134	0.121	0.114	0.078
            0.005	0.027	0.087	0.056	0.081	0.072	0.119	0.134	0.13	0.119	0.069	0.11	0.084	0.076	0.077	0.064
            -0.011	0.012	0.041	0.055	0.066	0.084	0.136	0.124	0.138	0.109	0.098	0.143	0.098	0.109	0.076	0.068
            0.004	0.022	0.055	0.082	0.059	0.079	0.132	0.107	0.176	0.083	0.103	0.106	0.099	0.07	0.049	0.005
            -0.029	-0.001	0.021	0.036	0.092	0.044	0.093	0.124	0.126	0.088	0.075	0.057	0.07	0.068	0.007	-0.081
            -0.068	-0.028	-0.001	0.031	0.055	0.052	0.062	0.068	0.097	0.08	0.064	0.039	0.051	0.036	0.017	-0.066
            -0.071	-0.026	-0.018	0.007	0.007	0.008	0.077	0.112	0.114	0.063	0.03	0.015	0.058	0.046	0.014	-0.041
            -0.068	0.049	0.117	0.047	-0.005	0	0.086	0.105	0.129	0.089	0.051	0.012	0.048	0.049	0.046	-0.036
            -0.098	-0.033	-0.01	-0.028	0.022	-0.001	0.052	0.101	0.112	0.077	0.077	0.108	0.026	0.037	0.054	-0.022
            -0.053	-0.055	-0.041	-0.015	0.001	0.023	0.069	0.111	0.126	0.094	0.119	0.095	0.116	0.092	0.116	0.041
            gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @cemu
              @cemu Can you post some pictures of your printer showing the print head at the "front" and "rear" of the bed?
              cemuundefined 1 Reply Last reply Reply Quote 0
              • cemuundefined
                cemu @gloomyandy
                @gloomyandy Of course
                )WhatsApp Image 2025-02-08 at 19.54.16_9e905358.jpg WhatsApp Image 2025-02-08 at 19.54.16_d8ac8f7d.jpg WhatsApp Image 2025-02-08 at 19.54.34_dac13611.jpg
                  At what point do you get this message? Usually you get this when you load a height map (G29 S1) without homing Z, or the height map was created with a large Z offset.
                  Your M122 reports that no bed compensation is in use ("bed comp in use: none, height map offset 0.000"):
                  Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                  Though I don't know at what point you sent this M122. Check that your print file isn't cancelling bed mesh.
                  • cemuundefined
                    cemu @droftarts
                    @droftarts Hi Ian,
                    After applying the suggested updates, I created a new mesh from scratch, and the warning appeared immediately after the mesh was generated. I set the Z=0 datum at the center of the bed and ensured that a probe point was present at the center during mesh generation. However, the center probe point came out 0.25mm higher than expected, and the entire bed appeared to be above the 0 reference plane.
                    Right now, I’ve prepared a fresh config file from scratch, with triple screw adjustment disabled and even without activating the servo arm. However, I’m still seeing the same issue.
                    I also experimented with some slicer tweaks—setting the first layer height to 0.3mm and layer width to 0.5mm—to allow for a bit more error tolerance and improve adhesion. The squares are printing better, and while the front is still closer, the back is at least adhering now.
                    A full-layer test print is currently in progress, and once it’s finished, I’ll share photos of the results along with my latest home and config files.
                    Also, I took the M122 report right after powering on the printer. During printing, I monitored the Z motors, and they are actively moving. If I disable mesh compensation during printing, the results get significantly worse.
                    Thanks for your help!!
                      @cemu I generally find bed mesh height mapping is more reliable if I home Z before AND after either making the bed mesh, or loading a bed mesh. I can't quite work out if that's what you're doing! If you're finding the nozzle is too far away from the bed and you are having to baby-step, you may want to adjust the Z probe Z offset (G31 Z... in config.g).
                      You can also do adaptive bed mesh, ie a bed mesh only where you are going to print, before each print. This was posted recently, and there are other examples on the forum: https://forum.duet3d.com/topic/37423/adaptive-mesh-probing-script-for-prusaslicer-superslicer
                      cemuundefined 2 Replies Last reply Reply Quote 0
                      • cemuundefined
                        cemu @droftarts
                        @droftarts Hi Ian,
                        In normal operation, I do use adaptive mesh, and the mesh grid is automatically generated based on the print area defined by the slicer. My bed.g file follows this sequence:
                        Homing all axes
                        Setting Z=0 datum
                        Lead screw adjustment
                        Setting Z=0 datum again
                        Running G29 for mesh compensation
                        However, I wasn't resetting Z=0 after generating the mesh, so I'll try that in my next test.
                        I haven’t needed to apply baby stepping—the Z=0 datum point prints well. However, at that point, the mesh consistently shows a 0.2mm offset above the 0 plane. The pattern is always the same: the front is closer, and the back is farther. It feels like if the rear stepper moved slightly higher, the issue would resolve itself without modifying the mesh.
                        I’m sharing the latest config files, home files, and print results below. The slicer tweaks helped—the first layers initially looked great, but once removed from the bed, I noticed that on the rear corners, the solid fill wasn’t fully connecting.
                        Do you have any other ideas to try?
                        Thanks!
                        config.g
                        bed.g
                        homeall.g
                        homeu.g
                        homex.g
                        homey.g
                        homez.g
                        heightmap.csv
                        WhatsApp Image 2025-02-10 at 16.55.25_66388f9c.jpg WhatsApp Image 2025-02-10 at 16.55.25_584d4149.jpg
                        • cemuundefined
                          cemu @droftarts
                          @droftarts
                          Hi Ian,
                          I tested taking Z=0 datum both before and after mesh generation, and when I do this, I end up needing to use baby stepping—I have to lower Z by at least 0.20mm for proper first-layer adhesion.
                          If I take Z=0 datum, generate the mesh, and then start printing immediately, a Z offset of 17.7 works well for the middle of the bed, but I still see the same issue where the front is too close and the back is too far.
                          However, if I take Z=0 datum, , then reload the same mesh with G29 S1 and take Z=0 again, the Z offset shifts unexpectedly.
                          Let me know if you have any thoughts on this!
                          Thanks!
                            Can you test measuring the z probe trigger height at different locations around the bed?
                              @cemu Here's the image of your bedmesh (if you have the 'Height Map' plugin enabled you can see this for yourself):
                              This shows a pronounced bowing of the bed, with the middle being around 0.4mm higher than the edge, and appears to get a little worse front-to-back. I think the first thing to do is to determine if it's the bed that is not flat (put a straight edge across it), or if the X axis gantry is bowed - a possibility as the X axis is long. If both appear straight, the distortion is being introduced by the X carriage sagging along the X axis travel, rotating around the X axis. This may lead to a mis-measurement of the bed from the nozzle, because the probe is offset from the nozzle. Usually we see this if the probe is offset in the Y direction, like the following image, but it could also apply with a probe in the Z direction:
                              If the carriage is rotating around the X axis, you might also notice that a line extruded along the X axis exhibits a slight bow. Possible causes for this that I can think of are: loose linear carriage on the linear rail, off-centre weight distribution of X carriage, wires/filament feed pulling on the carriage, belts tilting the carriage.
                              You can create a mesh using the actual nozzle, by setting the probe type to 0 (M558 P0, see https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#mode-0). This is a bit laborious, so don't do a mesh with too many points! But it may show up a difference between what the probe is measuring vs the Z position of the nozzle.
