    SZP Coil board
    Hardware wishlist
    • adrianundefined
      adrian
      Is possible for a Duet3D to produce a SZP Coil board to be same size as a beacon and/cartographer probe for easy toolhead mount compatibility?
      • T3P3Tonyundefined
        T3P3Tony administrators @adrian
        @adrian what are the dimensions and mounting holes?
        www.duet3d.com
        droftartsundefined adrianundefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @T3P3Tony
          @T3P3Tony @adrian I remember @jay_s_uk saying one of the Fly CAN boards are supplied with (or had an option) of a coil board with the same mounting hole spacing as Beacon.
          • adrianundefined
            adrian @T3P3Tony
            @T3P3Tony
            https://github.com/beacon3d/docs/tree/master/mcad/beacon
            https://docs.beacon3d.com/installation/
              jay_s_uk @droftarts
              @droftarts I believe both the fly boards are supplied with coils that have the same mounting holes as the beacon. I don't have retail ones though so can't confirm
              • adrianundefined
                adrian
                I was hoping these would come with the Roto toolboard. Then I wouldn’t have to buy two pieces of hardware. Seems like the beacon footprint is becoming a standard for tool head probe design.
                • T3P3Tonyundefined
                  @adrian are the mounts difficult to modify? Which one specifically do you need to modify?
                  www.duet3d.com
