RRF to Duet3 6HC
Problem installation firmware to Duet3 6HC v 1.02
@agz90 said in RRF to Duet3 6HC:
Hello, I have a problem installing the rap rap on the board. I load the latest rap rap with Bossa, it saves it, but when I check it, it gives me an error and the board doesn't start.
How are you checking it?
What error does it report?
Are you following these steps to flash the firmware?
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards -
@Phaedrux said in RRF to Duet3 6HC:
Are you following these steps to flash the firmware?Yes, I followed all the steps exactly as described. Checked with Bossa verify. My problem is that I thought I could install Clipper on the board, apparently I deleted the boot file and now it doesn't work. I don't know how to restore the rep rap on the board.
@agz90
@agz90 install firmware 3.6.0 Release Candidate 1
Make sure your bossa check boxes match this
Try this bin file for 3.5.4
https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/Duet3Firmware_MB6HC.bin
@agz90 also make sure that you remove the Erase jumper before you command Bossa to flash the firmware.
