    Duet 2 wifi AND LIS3DH
    700
    • lucundefined
      luc
      Hi guys, for the connection of a Duet 2 wifi and the LIS3DH accelerometer I am a bit confused as I read different connections between the instructions and some posts of other users.
      In the instructions (https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer) I read:
      Duet LIS3DH
      SDA (MOSI) PIN 5 (MOSI)
      SDO (MISO) PIN 8 (MISO)
      SCL PIN 4
      GND PIN 3
      and I don't seem to have any doubts up to here but for the following I read different connections in various posts than the instructions and I have doubts. How should they be connected?
      CS PIN 1 or PIN 9?
      INT1 PIN 3 or PIN 7?
      Maybe I can connect them as I want but is it enough then to use the correct M955?
      M955 P0 C “spi.cs3+spi.cs1”
      M955 P0 C “spi.cs9+spi.cs7”
      Sorry if this sounds like a stupid question but I couldn't figure it out by myself?
      Thank you
        droftarts administrators @luc
        @luc here under the pictures https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer#wiring-schemes it says:
        Note: the pictures above show an alternative wiring scheme, using pin 7 for INT1 and pin 9 for CS on the TEMP_DB connector. We now recommend using pin 1 for CS and pin 3 for INT1 on the TEMP_DB connector.
        The pins relate to the pins on the TempDB connector, pin 9 is SPI_CS4, pin 7 is SPI_CS3:
        If you have already connected it using pins 9 and 7, you'll need
        M955 P0 C"spi.cs4+spi.cs3"
        The main problem with using pins 9 and 7 is that you then can't stack the accelerometer on top of a temperature daughterboard, as there would be no SPI connection.
        lucundefined 1 Reply Last reply Reply Quote 0
        • lucundefined
          luc @droftarts
          @droftarts
          No, I haven't mounted it yet. The accelerometer should arrive on friday and I was studying the situation to prepare the wiring in advance.
          I thank you, it is clearer to me now.
          tasundefined 1 Reply Last reply Reply Quote 0
          • tasundefined
            tas @luc
            @luc Please note GND is on pin 2 of the temperature daughterboard connector, not pin 3 as you listed.
            • lucundefined
              luc
              Yes thank you, I had noticed that.
              This should be the correct connection with the wire colors that I will use:
              Accelerometer / Duet
              Red 3 Volt / PIN 8 + 3,3 cavo rosso
              SDA (MOSI) / PIN 5 SPI_MOSI cavo blu
              SDO (MISO) / PIN 6 SPI_MISO cavo giallo
              SCL / PIN 4 SPI_SCK cavo viola
              GND / PIN 2 GND cavo nero
              CS / PIN 9 SPI_CS4 cavo arancione
              INT1 / PIN 7 SPI_CS3 cavo verde
                @luc Like I said, it's better to use:
                CS / PIN 1 SPI_CS2 cavo arancione
                INT1 / PIN 3 SPI_CS1 cavo verde
                If you add a temperature daughterboard in the future, you won't have to change the wiring when you plug the accelerometer in on top of the temperature daughterboard, only the configuration.
                • lucundefined
                  luc @droftarts
                  @droftarts said in Duet 2 wifi AND LIS3DH:
                  Yeah, yeah...okay, thank you.
                  • lucundefined
                    luc
                    Here I am again!
                    Continuing to study the settings, I arrived at the M955 setting.
                    From what I understand in config.g I enter:
                    M955 P0 C “spi.cs4+spi.cs3” (change cs4 and cs3 if I use different pins)
                    But I also need to set the orientation (which for me will follow the axis orientation) so I add:
                    M955 P0 I20
                    I am not clear if I also have to add the S and R paramenters so it becomes:
                    M955 P0 I20 S5000 R10 ?
                      jay_s_uk @luc
                      @luc no need to mess with S and R so don't include them
                      • lucundefined
                        luc @jay_s_uk
                        @jay_s_uk Okay, thank you.
                        So do I just use M955 P0 I20 or not even that which seems to me that by default it considers it oriented according to the axis direction of the sensor?
                          jay_s_uk @luc
                          @luc you'll probably need to adjust the I value once you get it installed and work out which way its pointing
                          • lucundefined
                            luc
                            Connected as per the description above. The acelerometer led is on green.
                            Entered the following string in config.g:
                            I try to send M955 and get the following message:
                            Error: M955: missing parameter 'P'
                            I read the guidea and for the connection type it seems to me that P0 is correct. What am I doing wrong?
                            tasundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            • lucundefined
                              luc
                              Despite the error in my previous post I tried to see if it worked and it did....did the first test.
                              I attach the image and I would like to know from you who are experts what you think. I got an idea nma would like your opinion. Thank you
                              • tasundefined
                                tas @luc
                                @luc That is the hardware wiring part of M955. You must also tell Duet the communication settings.
                                ;M955 P0 C"spi.cs4+spi.cs3";LIS3DH
                                ;M955 P0 I25 S1344 R10  ; S1344 is 1344Hz sample rate.  R10 is 10 bit resolution for LIS3DH.
                                You can enter all of the parameters on one line if you like.
                                Make sure to check your orientation for the I parameter and insert the appropriate two numbers.
                                • lucundefined
                                  luc @tas
                                  @tas said in Duet 2 wifi AND LIS3DH:
                                  Thank you for your response.
                                  I added M955 P0 I20 S1344 R10 but if I send m955 I always get: Error: M955: missing parameter 'P'
                                  tasundefined 2 Replies Last reply Reply Quote 0
                                  • tasundefined
                                    tas @luc
                                    @luc You have to send M955 P0. Sorry early in the day for me! There are defaults for the other settings which is why it works for you.
                                    • tasundefined
                                      tas @luc
                                      @luc Also I should have removed the semicolons in front of each line before posting the code. I now use another acclerometer.
                                      • lucundefined
                                        luc @tas
                                        @tas
                                        OK...It's ok. Now with m955 po no longer gives error and responds with parameters
                                        many thanks
                                          @luc said in Duet 2 wifi AND LIS3DH:
                                          Make sure you are using straight quote marks, not curly quote marks, ie the above should be
                                          What firmware version are you using? Send M122 and post the response.
                                          • lucundefined
                                            luc @droftarts
                                            All ok, thank you too!
                                            The first test performed is what I insierite a few posts above.
                                            Can you give me your opinion on the result?
                                            Is there a document to read that explains how to interpret the values?
