    6HC. Pi, tablet or?
    • 3DPMicroundefined
      3DPMicro
      Hey, Gents. I'm resuming a paused printer build and recently purchased the 6HC. The machine will be Cartesian and use 6 steppers. 2 for xy, 2 for z and 2 for dual extrusion. I'd like for non print moves to be fast as possible and because it will use 20mm lead ball screws on the x and y, allowing the 5160s to run to their maximum speed potential is important.
      I like the idea of not being tied to my desk/laptop to control this machine so what are my options?
      A tablet with wifi module on the 6hc or a Pi and PC monitor may be another. If I use a Pi what version and ram is appropriate (with some headroom). Also would the Pi take any load, like step rate potential, off the 6hc?
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        Phaedrux Moderator @3DPMicro
        @3DPMicro said in 6HC. Pi, tablet or?:
        I wouldn't use anything less than a pi4 these days. 2 to 4gb
        I don't think you'll get any hits to performance. You do gain upload speed though, if you have large job files it can make a difference. You also gain display flexibility since you can run a touch screen off the pi and use DWC directly as well as remotely.
        3DPMicroundefined 1 Reply Last reply Reply Quote 0
        • 3DPMicroundefined
          3DPMicro @Phaedrux
          @Phaedrux thank you
