Wiki moving
Hi everyone!
I have nearly finished migrating all the wiki pages to Dozuki, you can check it out here:
There are still a few updates left to do, linking between pages to update and some cosmetic changes but once that is complete the Dozuki site will replace the current wiki.
Feel free to give feedback on this page and to start to use the comment sections on Dozuki to suggest changes to the documentaiton etc.
Over time the standard wiki pages will be migrated to or supplemented with guides. Guides are better for step by step processes, wiki pages are better for reference. Guides do take a long time to produce though.
From now I have stopped new account registrations on the old wiki and new updates to documentation will happen on the Dozuki site.
Cheers
Tony
I really like the way this looks!
I assume you don't want to hear about dead links yet.
Congratulations….
Looks great!!!!!!!!!!
When is the move scheduled?
Nice layout! Clear and easy to navigate.
Looks Great! Love it!
Thanks John
Dead links are part of what I will be sorting over the next day or so. After that I will want to hear about them!
The new layout is Great! Thank you! It will be so much easier to look things up.
The old documentation was a little harder to find certain things but it was still a hundred times better than the documentation for a Replicape board. I know from experience…
Me too!
That looks great and easy to navigate.
Many thanks. -
Looks great and thanks. Timing is perfect. I am about to start wiring mine up.
Looks lovely, though must admit I initially missed having one long index list to scroll through
There seems to be some sort of configuration problem, and I can't see where/how to fix it even if my edits would be accepted.
For example, on the page
https://duet3d.dozuki.com/Wiki/Power_Wiring
The link to 'Wiring and hardware differences from RAMPS etc. ' is specified in the source as '[[Wiring and hardware differences from RAMPS etc.]] ' but links to 'https://duet3d.dozuki.com/Wiki/Edit/Wiring_and_hardware_differences_from_RAMPS_etc.' (the edit page, which is presumably not the desired behaviour). But further down the same page under '5V' options the 'PanelDue' link is specified the same '[[PanelDue]]' way but goes to the correct (content not edit) page.
This is the same on several of the other pages/links I've found. -
Thanks Rob, some of the links did not migrate perfectly and a few I did manually are pointing at the edit page. Please comment on the dozuki site if you see this and I will fix. I have sorted the one you have pointed out.
Hmmm, i have to say i don't find the new one attractive.
I can't find anything anymore without the help of the search field.
Could be because i was used to the old one.
But i would like to see a page where i can find all the topics in a big overview if you know what i mean. -
Much prefer the new one, good work, expect it will only get better.
But i would like to see a page where i can find all the topics in a big overview if you know what i mean.Yes you have to drill down by category. I will look and see if I can make an overview page similar to the old wiki. To be fair alot of people did not like that and preferred search so it would be good if we get both working well.
Thanks, if you see bits that need improvement let us know!
Thanks. This new guides is set up much more clearly.
Not sure why you changed it to be honest. Every link off of google is dead and the redirect only puts you to the top level categories. I am trying to find a guide on updating my wifi via gcode and can't find it … but found the old link on google.
Frustrated. There's something to be said about "if it ain't broke".
Me too!!! Where has it gone?
All the redirects have been fixed now as far as I am aware. Please let me know if any do not work.
We moved to Dozuki to make use of the Guides (much better than wiki pages), now we have write some more guides
All the information was migrated tto dozuki - and now the 301 redirects should work.
Sorry for the frustration everyone!
…................... now we have write some more guides
Tony. Do you plan to include the guide I did on mixing hot ends (Diamond etc)? If so, do you need anything from me?
Cheers
Edit. I'm back from the other side of the world now - at least my body is
