    Welcome to the New Forum
    46
    6.5k
    • dragonnundefined
      dragonn
      Today I am getting some problem when browsing the forum like:
      Internal Error.
      Oops! Looks like something went wrong!
      Or:
      MSquaredundefined 1 Reply Last reply Reply Quote 0
      • briangilbertundefined
        briangilbert
        Is it possible to enable the mobile API's so that I can use the Discourse app to read and respond on my phone?
        Co-creator of the Zesty Nimble direct drive extruder
        • MSquaredundefined
          MSquared @dragonn
          @dragonn I was seeing the same thing earlier too; but the server and all the services looked fine. I am guessing it had something to do with the network. Keeping an eye on it tho!
          • MSquaredundefined
            MSquared @briangilbert
            @briangilbert This is NodeBB. It is very similar to Discourse but I doubt that the Discourse app would work.
            briangilbertundefined 1 Reply Last reply Reply Quote 0
              briangilbert @MSquared
              @msquared thanks.. do you know if there is a mobile app that supports it?
              Beside Safari 😉
              dragonnundefined 1 Reply Last reply Reply Quote 0
              • MSquaredundefined
                MSquared
                Hey All,
                I believe that I found and resolved the issue that was causing errors on the forum during peak load times. Please let me know if you continue to see any errors. Thanks!
                -M
                • dragonnundefined
                  dragonn @briangilbert
                  @briangilbert said in Welcome to the New Forum:
                  Beside Safari 😉
                  Maybe they is a Tapatalk plugin?
                  • Qdeathstarundefined
                    Qdeathstar
                    Is there a PM function?
                    • otaku521undefined
                      otaku521
                      How do I stop getting email notifications? I have turn off all notifications already... 0_1524113354807_Screen Shot 2018-04-19 at 12.48.08 PM.png
                      • resamundefined
                        resam @T3P3Tony
                        @resam said in Welcome to the New Forum:
                        @T3P3Tony any chance to improve the email notifications? They completely mess up the markup. Not even quotes are displayed correctly - it's just the whole text in a single line... This makes it really difficult to follow and actually read, because "old quoted text" is indistinguishable from the actual new reply text.
                        Basically this open issue: https://github.com/NodeBB/NodeBB/issues/6348
                        Would be nice if you could raise your voice over there to put some attention on it!
                        RoiEXLab created this issue in NodeBB/NodeBB
                        closed Quoted text blocks not identifiable as such in emails #6348
                        • 3mmundefined
                          3mm
                          @t3p3tony
                          Hey, sorry to complain, but, why do web 'programmers' persist in creating websites where the background is all white, while presenting system text in a light grey font? Are they retarded? I know that Wozniak envisioned a world where no paper would be used in the then upcoming computer environment. But, paper doesn't glow, computer screens do. They generally glow bright white, which causes the Human pupil to contract...restricting the intensity of the light entering the eyeball, but then the text is a light grey color! So the pupil must dilate to allow enough light into the eyeball for the brain to be able to recognize the characters. End result? Old-f.arts suffer significant eyestrain, but its a kewl website.
                          There are 10 types of people: Those who understand binary and those who don't.
                          JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                          • JohnOCFIIundefined
                            JohnOCFII @3mm
                            @3mm Thankfully, there are a number of different "skins" you can choose. The one I'm using now has white text on a gray or black background.
                            You can access this via the Profile menu in the upper right of the window. Under that, choose settings. in the upper left is the "Select a Skin" setting. The one I'm using now is called "slate." There are many others too.
                            John
                            3mmundefined 1 Reply Last reply Reply Quote 1
                            • 3mmundefined
                              3mm @JohnOCFII
                              @johnocfii
                              Thank you...
                              3mm
                              • T3P3Tonyundefined
                                T3P3Tony administrators @otaku521
                                @otaku521 You will probably still be getting notifications from individual topics you were watching (either due to automatic settings or manually clicked watching) if you de-select watching on this threads you should stop getting any email notifications.
                                www.duet3d.com
                                • zerspaner_gerdundefined
                                  zerspaner_gerd
                                  Is there a small manual for the new forum?
                                  For example, I do not find that correct information about incorporation of code.
                                  I saw this string by chance
                                  ```TEST```
                                  Are there any more, as in old forum.
                                  Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                  • T3P3Tonyundefined
                                    T3P3Tony administrators @zerspaner_gerd
                                    @zerspaner_gerd Most of the features for dealing with the options for text/code etc are explained here:
                                    http://commonmark.org/help/
                                    My first post in this thread has some information about how to upload images etc.
                                    Cheers
                                    www.duet3d.com
