    Calibrating steps/mm
    1919
    • Jddt
      Jddt last edited by
      When I completed the steps/mm calibration and I run code, like the homing code, then the distance is completely wrong.
      Any advice.
      Thanks
      • mrehorstdmd
        mrehorstdmd last edited by
        What type of mechanism? What distance is "wrong" when homing?
        Steps per mm is normally a simple function of the pulley teeth, belt pitch, and steps/rev of the motor.
        • Jddt
          Jddt last edited by
          I am using external drivers. All my final drive pulleys are HTD5 20 tooth. I do not get any consistency with the distance the axis move.
          See calculations below.0_1529519753000_04bdb18e-452c-4e57-9863-3e6df798767c-image.png
          Jddt 1 Reply Last reply Reply Quote 0
            If you are using external drivers then you will need to use a T parameter on the M569 commands for those drivers, because the default width of the step pulses generated is fine for the built-in TMC2660 drivers but too short for almost all external drivers. See https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers#Section_Configuring_the_Enable_polarity_and_step_timing.
            • Jddt
              Jddt last edited by
              Settings I am using now. Can the T setting influence the accuracy of my steps?
              M569 P5 S1 R1 T2.5:2.5:5:2.5
              M569 P6 S1 R1 T2.5:2.5:5:2.5
              M569 P7 S0 R1 T2.5:2.5:5:2.5
              M569 P8 S0 R1 T2.5:2.5:5:2.5
              M584 X5 Y6 Z7 E8
                If the T values are too small then you can miss steps.
                • nz_andy
                  nz_andy last edited by
                  What is the external drive micro step set at? you have 10,000 miro-steps per revolution listed in you post, so micro step setting is 50?
                  • Jddt
                    Jddt last edited by
                    • nz_andy
                      Have you tried using 1/16 micro-stepping instead of 1/50th? if that works that may tell you there is an issue with the signal frequency / pulse width.
                      • deckingman
                        deckingman @nz_andy last edited by
                        @nz_andy said in Calibrating steps/mm:
                        Good spot. That could well be the OP's problem as 50x micro stepping isn't a supported mode - see documentation here https://duet3d.dozuki.com/Wiki/GCode#Section_M350_Set_microstepping_mode.
                        • Jddt
                          Jddt last edited by
                          Thanks for noticing the error in my calculation. I am using external drivers and are not using the M350 command.
                          • Jddt
                            Jddt @Jddt last edited by
                            @jddt Changed to 128 Micro Steps
                            • Jddt
                              Jddt @dc42 last edited by
                              What is the max T values you suggest to be safe?
                                dc42 administrators @Jddt last edited by
                                @jddt said in Calibrating steps/mm:
                                High T values will limit the maximum step pulse frequency. I doubt that any stepper drivers need greater than T10.
                                • Jddt
                                  Jddt last edited by Jddt
                                  The motors started to work properly with a value of T5
                                    According to the datasheet, T2.5:2.5:5:0 should work.
