    How to Run 12V HotEnd with 24V Duet2?
    16
    2.3k
    • SnowCrashundefined
      SnowCrash
      What would be the best way to run a 12V/40W hotend with a 24V Duet2 (dc-dc converter/mosfet based circuit/opto-isolator/something else)?
      Thanks!
      • Barracuda72undefined
        Barracuda72
        just buy a new 24V heater catrigde..a single 24 cartrigde costs under 2€ at aliexpress
        SnowCrashundefined 1 Reply Last reply Reply Quote 0
          SnowCrash @Barracuda72
          @barracuda72 said in How to Run 12V HotEnd with 24V Duet2?:
          Wish it was that simple.
          I've got an Atom MK3 hotend which has a small circular disc-type heater installed - so far I couldn't find one of these with 24V rating, but perhaps someone knows?
          • elmoretundefined
            elmoret
            DC to DC converter, power it directly from the printer power supply, positive from the DC-DC converter goes to the heater lead 1, negative from the Duet goes to the heater lead 2.
            The Duet will switch the negative side to achieve temperature control, and the hotend will see 12v maximum assuming the DC-DC converter does not fail.
            SnowCrashundefined 1 Reply Last reply Reply Quote 1
              SnowCrash @elmoret
              @elmoret said in How to Run 12V HotEnd with 24V Duet2?:
              Thanks for the suggestion, @elmoret!
              If it was linear voltage, I wouldn't think twice about it and indeed use a dc-dc converter. My concern, though, is these converters tend to be relatively slow and as you point out the Duet uses pwm for controlling the voltage input to the heater. Hence, I worry a converter may not always be quick enough to do the job.
              Any opinion on this, guys?
              • wilrikerundefined
                wilriker
                This post is deleted!
                  dc42 administrators @SnowCrash
                  @snowcrash said in How to Run 12V HotEnd with 24V Duet2?:
                  What @elmoret is suggesting is that you use the DC-DC converter to provide +12V power to the positive heater lead. Not to power the converter from the PWM output, which would be a bad idea.
                  • DjDemonDundefined
                    DjDemonD
                    Yes using it the way elmoret suggested works great and I have done so many times.
                    Do not PWM it down from 24v. Most people would set 50% which is actually still 2x the max power, it would need to be 25% PWM max to get a rough equivalent, but even then its just 25% duty cycle of 24v ON, 0v, 24v On, 0v etc... You're still running your heater at 4 times its rated power output just only for 25% of the time, assuming nothing (like a mosfet) fails and runs the heater at 4 times power for the few minutes/seconds it would take to melt and/or catch fire.
                    www.precisionpiezo.co.uk
                      SnowCrash @dc42
                      Thanks for the clarification, @dc42, that indeed makes sense (sorry @elmoret for not fully grasping your suggestion till now).
                      And thanks for confirmation @DjDemonD, and the additional explanation!
                      Just to make sure I've got it right, this is the converter I intend to use:
                      And here's how what I take the setup to be:
                      Is this right?
                        Yes that's right.
                          SnowCrash @dc42
                          @dc42 said in How to Run 12V HotEnd with 24V Duet2?:
                          Yes that's right.
                          Thanks, @dc42!
                            SnowCrash @SnowCrash
                            Apologies for reviving this old thread, but I'm re-designing the PCB containing the above circuit for running a 12V hotend off a 24V power-supply, and it occurred to me that it might be a good idea to add a protection diode like so:
                            I'm aware that these types of diodes are typically added in series with inductive loads (like we do in the case of fans), whereas the heater is resistive, but perhaps there would nevertheless a benefit in adding the diode here? or is it completely redundant?
                            Thanks!
                            SnowcCash
                            • SLKittieundefined
                              SLKittie
                              Wouldn't it be easier using a mosfet?
                              im not sure if i am right or not though.
                              Plagiarism picture incoming? (edit:- clean up picture a bit)
                              I'm not sure if it would work like this but from my understanding it looks like it?
                              Don't quote me on this though. lol. i may not be right haha. just a thought
                              • fcwiltundefined
                                fcwilt @SnowCrash
                                Thanks!
                                SnowcCash
                                It would serve no purpose since, as you pointed out, the load is resistive.
                                It wouldn't hurt anything other than to reduce the voltage going to the heater a bit but why would you want to do that.
                                  SnowCrash @fcwilt
                                  Apologies for the late response. Either I didn't get notification for the posts for some reason or I managed to somehow totally miss them.
                                  Thanks for the clarification, @fcwilt 🙂
                                  @latexcupcake, given that conventional MOSFETs have only 3 terminals, and your drawing contains 6 connections for it, I can't really see how it can work. However, if by MOSFET you meant a MOSFET-based power module (and an optocoupler) similar to this one
                                  Then that could potentially work depending on the type of built-in Mosfet (I tests a number of these modules in practice and some worked but others didn't).
                                  That said, a simple diode setup is much more economical, no?
                                    No diode is even more economical.
