Simplify3D Configuration Question
  • Does anyone know how to get Simplify3D to use G10 and M116 in place of M104 and M109?
  • As a workaround, can you change M104 and M109 so they only set the active temperature and leave the standby temperature alone?
  • I am using this start sequence, on both Slic3r and S3D (the [this_depends_on_slicer_software] code changes!), regarding the temperature:
    This is for Slic3r:
    T0 ; Duet documentation asks for tool selection at your start gcode
    M140 S[first_layer_bed_temperature] ; Slic3r [] code!
    M116 H0 This forces the printer to wait for the bed FIRST instead of turning o both heaters at the same time.
    M104 S[first_layer_temperature_0] ; Also Slic3r [] code!only after the bead is heated it starts to heat the hotend while homing and measuring leveling
    G32
    G1 X17 Y0 F10000; This is my ooze corner to wait the hotend to reach temperature.
    M116 ; Now it waits for the hotend to achieve temperature.
    M98 P/macros/SubMacros/beep.g ; this beeps me to clean the ooze
    G4 P30000 ; and waits 30seconds so I can jump from the chair 😄
    For S3d:
    T0
    M140 S[bed0_temperature]
    M116 H0
    M104 S[extruder0_temperature]
    G32
    G1 X2 Y0 F10000; Vai para X2Y0
    M116 P1;
    G4 P30000
  • After reading more about the script handling in Simplify3D I see that it will not output the initial temperatures if the associated commands are in the startup script. The problem is that it doesn't seem to recognize bed0_temperature as a variable and passes it, unchanged, into the code output. I also tried just bed_temperature but that didn't work either.
    @mperdue apparently it should be bed0_temperature. At least according to this:
    https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/
    But s3d are particularly terrible at documenting this sort of thing.
  • @mperdue
    M140 S[bed1_temperature] ;Start heating bed
    M190 S[bed1_temperature] ;Wait for bed to reach temp before proceeding
    and
    M104 S[extruder0_temperature] ;Start heating extruder
    M109 S[extruder0_temperature] ;Wait for extruder to reach temp before proceeding
    Work fine for me
  • @mperdue under "FFF" tab in the firmware configuration tab will allow you to edit these.
    Build a new .frm file and edit the appropriate values.
    Also my start up script if you're still having issues:
    G28 ; home all axes
    G90;
    G29 S1; load bed leveling
    M106 S0; Turn fan off
    M140 S[bed0_temperature] ; set bed heat
    M141 S48; Set chamber heat
    G0 X20 Y10 F9000 ;
    M204 P700 T2000 ; set acceleration
    M207 S5.0 R-.25 F1800 T1500 Z1.0 ;set retraction settings(f1500)
    M190 S[bed0_temperature]; wait for bed heat
    M191 S48; wait for chamber heat
    G10 P1 S0 R190
    G10 P0 S[extruder0_temperature] R190;
    T1;
    T0;
    G10 P1 S[extruder1_temperature] R190;
    ;G12 P0; Clean Nozzle
    ;M109 S[extruder0_temperature] T0; wait for temp
    ;M109 S[extruder1_temperature] T1; wait for temp
    M116 ;used instead of M109
    M572 D0 S0.25 ;pressure advance for tool 0
    M572 D1 S0.25 ;pressure advance for tool 1
    M106 P6 S255; turn tool light on
Locked
