    Tevo little monster duet conversion
    1749
    • andrewjames13
      andrewjames13 last edited by
      Hello my name is Andrew I have a tevo little monster I have converted it to a duet wifi with a paneldue 7i I've had some issues my Y motor is not working after troubleshooting I came to the conclusion the board is faulty I have a new one coming I added a filament run out sensor to e1 I have rgb LEDs to finish adding my next step is adding nema .9 motors I need configuration help with them motors also I have a smart effector haydn Huntley custom 400mm arms e3d volcano with pt100 board both e3d an duets not sure what one I should use an going berd air for cooling
      • Robocop
        Robocop last edited by
        I will be interested to see how you go with the mods. Some pics of prints of small objects would be appreciated 🙂
        andrewjames13 1 Reply Last reply Reply Quote 0
        • andrewjames13
          andrewjames13 @Robocop last edited by
          @robocop I will post pictures in a bit I just got my second duet wifi board an I'm still having issues my "Y" motor led on the board isnt lighting up.
          • adavidm
            adavidm last edited by
            It would be useful to have a bit more info about your setup. There's a list of useful information in the posting guide:
            https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
            adavidm
            • andrewjames13
              0_1534939404617_20180822_065017.jpg 0_1534939435118_20180822_065025.jpg 0_1534939475971_20180822_065033.jpg 0_1534939513708_20180822_065044.jpg 0_1534939544731_20180822_065055.jpg
              • andrewjames13
                I have these motors I plan on using them here is the link: https://www.ultibots.com/nema-17-0-9-degree-stepper-motor/
                0_1534939696984_Screenshot_20180822-080752_Chrome.jpg 0_1534939707175_Screenshot_20180822-080758_Chrome.jpg
                • andrewjames13
                  I need to know what I need to change in my configurator to make this run the little monster comes with nema 17 1.8 degree motors I am still having homing issues my "Y" motor isnt working the LEDs on the board where the motors plug in is not lit up for the "Y" motor I believe it maybe a faulty endstop wire I'm changing it when I get back home I know the motor works I plugged it into the second "z" slot an it will home an I plugged a different endstop into the "Y" endstop an the led comes on
                  T3P3Tony dc42 2 Replies Last reply Reply Quote 0
                  • T3P3Tony
                    T3P3Tony administrators @andrewjames13 last edited by
                    @andrewjames13 said in Tevo little monster duet conversion:
                    ...I believe it maybe a faulty endstop wire I'm changing it when I get back home I know the motor works I plugged it into the second "z" slot an it will home an I plugged a different endstop into the "Y" endstop an the led comes on
                    looks like you have found at least one issue - if the endstop is not working but putting a different one on that port works then that endstop or wiring has a fault or is disconnected.
                    www.duet3d.com
                    • andrewjames13
                      andrewjames13 @T3P3Tony last edited by
                      @t3p3tony I'm using them motors I have them. I have a smart effector volcano block an a pt100 e3d sensor I need to know how to configure my:
                      -im swapping to a zesty nimble for the extruder motor
                      -filament run out sensor
                      -.9 degree motors from 1.8 degree
                      -configure the smart effector
                      -also I'm going to use berd air for part cooling
                      I ordered a 12v berd air because the 24v isnt available for a month I'm gonna switch the motor to a 24v when I'm on reprap configurator in the motor tab so double all the settings I have for X,Y, an Z?
                      • andrewjames13
                        andrewjames13 @adavidm last edited by
                        @adavidm do you have more info for what I'm looking to do now ? So everyone knows this is my first delta 3d printer build an first time with duet after this is done I'm going to build a kissel xl
                        • adavidm
                          Have you read the guide I linked to? You're asking for us to suggest changes to your configuration but, unless I've missed something, you've not posted your current configuration files.
                          Tony, one of the Duet3D partners, has suggested you fix your known issue with an endstop. Rather than try too many things at once let's get that sorted, post your configs and then report back the behaviour you are seeing.
                          Happy to help.
                          andrewjames13 2 Replies Last reply Reply Quote 0
                            dc42 administrators @andrewjames13 last edited by dc42
                            To allow for changing from 1.8 to 0.9deg XYX motors, double the XYZ steps/mm in the M92 command in config.g.
                            • andrewjames13
                              @adavidm I didnt see the link sorry also my endstop is fixed yes bad wire now when I turn it on an try an home I hear terrible sound from the motors am I kick it off so it doesnt destroy itself I'll post configuration now
                              • andrewjames13
                                • andrewjames13
                                  andrewjames13 @andrewjames13 last edited by
                                  • andrewjames13
                                    This post is deleted!
                                    • andrewjames13
                                      0_1534980110970_config.g
                                      • andrewjames13
                                        andrewjames13 @dc42 last edited by
                                        @dc42 where it says x80 y80 z80 e399 for me? double all them to 160? except for e of course
                                        • andrewjames13
                                          update my tevo is working thank god i ended up swapping my motors to the .9 degree motors i changed M92 i doubled it i ran the new wires from the motors to the duet wifi 1.04 i have i ran a new wire to my "Y" endstop i ohmed the wire there was i short within the wire an go figure this was a brand new 3d printer a week ago i added the duet wifi to it an still havent done a first print yet. next is my smart effector i messaged haydn huntley he custom made me 400mm arms i have everything except my berd air. i have the volcano heat block pt100 e3d and duet board idk what one is best to use im gonna need help configuring this theres no videos on youtube to use as a guide
