    [SOLVED] Heated bed PID auto tune failed.
    7.5k
    • vapvapundefined
      vapvap
      How do I calibrate heated bed PID correctly? My attempts give errors.
      Regards.
      11:43:19 AM
      Warning: Auto tune of heater 0 failed due to bad curve fit (G=118.2, tc=794.1, td=-0.6)
      11:31:13 AM
      Auto tune phase 3, peak temperature was 85.0
      11:31:05 AM
      Auto tune phase 2, heater off
      11:22:41 AM
      Auto tune phase 1, heater on
      11:22:35 AM
      M303 H0 S85
      Auto tuning heater 0 using target temperature 85.0°C and PWM 1.00 - do not leave printer unattended
        The problem is that the measured dead time is negative. I suggest you use the gain and time constant values given by auto tuning, but measure the dead time manually. It is approximately the time between turning the heater on and seeing the temperature start to rise significantly. It's typically 2 seconds for a hot end, somewhat more for a bed heater.
        • vapvapundefined
          vapvap
          Sorry, but I'm new to these settings.
          Could you show an example of such a code command?
          I'm afraid that without you I will not deal with this.
            Your tuning run reported:
            So the M307 command you need based on these values would be:
            M308 H0 A118.2 C794.1 D-0.6
            However, the dead time can't be negative. So measure the time it takes from turning the bed heater on to the indicated temperature starting to rise. For example, if it is 4 seconds, use:
            M308 H0 A118.2 C794.1 D4.0
            I have it on my work list to improve the measurement of dead time during auto tuning.
            HTH David
            deckingmanundefined vapvapundefined 2 Replies Last reply Reply Quote 0
            • deckingmanundefined
              deckingman @dc42
              @dc42 said in Heated bed PID auto tune failed.:
              👍 I've always struggled in that respect with my big thick lump of aluminium tooling plate and have to manually change the auto tune value. No big deal as it's not something that needs to be done often, but it would be nice to see that improved if it's possible.
                dc42 administrators @deckingman
                @deckingman said in Heated bed PID auto tune failed.:
                Can you tell me what value auto tuning reports, what happens if you use that value, and what value you actually use to get good results?
                  deckingman @dc42
                  Now you've got me. I made a note in my config of the date I last ran auto tune and it was 17-08-2017, so over a year ago. Thinking about it, (and my memory is a bit hazy) I seem to remember that prior to that time, I really struggled to get a successful tune, but you made some changes which fixed the problem that I had - it was something to do with the check it makes after the heater turns off (can't remember what that check is). So now that I think about, you may have fixed the dead time issue too.
                  I'll run another auto tune when I get chance - bed is hot at the moment and it'll take about 3 to 4 hrs to get down to ambient. I can say that I'm using D16.4 so that would indicate that it came from auto tune and not a post tune manual entry (I'd have rounded it to a whole second).
                  • vapvapundefined
                    vapvap @dc42
                    I'm sorry, but I think I'm doing something wrong...
                    7:43:07 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=133.8, C=839.5, D=-0.5)
                    7:30:11 PM
                    Auto tune phase 3, peak temperature was 90.0
                    7:30:04 PM
                    7:22:08 PM
                    7:22:02 PM
                    M303 H0 S90
                    Auto tuning heater 0 using target temperature 90.0°C and PWM 1.00 - do not leave printer unattended
                    7:21:45 PM
                    M307 H0 A83.9 C552.1 D20.0
                    6:46:16 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=83.9, C=522.1, D=-0.3)
                    6:38:16 PM
                    Auto tune phase 3, peak temperature was 90.1
                    6:38:09 PM
                    6:31:45 PM
                    6:31:39 PM
                    M303 H0 S90
                    6:31:15 PM
                    M307 H0 A102.6 C642.0 D17.0
                    6:22:21 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=102.6, C=642.0, D=-0.1)
                    6:12:29 PM
                    Auto tune phase 3, peak temperature was 90.2
                    6:12:22 PM
                    6:05:14 PM
                    6:05:08 PM
                    M303 H0 S90
                    6:04:45 PM
                    M307 H0 A102.0 C633.4 D15.0
                    5:48:31 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=102.0, C=633.4, D=-0.9)
                    5:38:47 PM
                    5:38:40 PM
                    5:31:40 PM
                    5:31:34 PM
                    M303 H0 S90
                    5:31:22 PM
                    M307 H0 A163.0 C1031.9 D12.0
                    5:21:56 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=163.0, C=1031.9, D=-0.3)
                    5:06:05 PM
                    5:05:58 PM
                    4:57:09 PM
                    4:57:04 PM
                    M303 H0 S90
                    4:56:48 PM
                    M307 H0 A78.8 C487.0 D10.0
                    2:26:11 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=78.8, C=487.0, D=-0.9)
                    2:18:43 PM
                    2:18:36 PM
                    2:12:24 PM
                    2:12:19 PM
                    M303 H0 S90
                    2:12:01 PM
                    M307 H0 A141.7 C892.4 D7.0
                    2:08:46 PM
                    Warning: Auto tune of heater 0 failed due to bad curve fit (A=141.7, C=892.4, D=-0.7)
                    1:55:02 PM
                    1:54:55 PM
                    1:46:39 PM
                    1:46:33 PM
                    M303 H0 S90
                    1:45:29 PM
                    Connection established!
                    1:45:29 PM
                    Page Load complete!
                      deckingman @vapvap
                      @vapvap It's the negative dead time that's screwing it up but I don't know why you are getting that. Are you starting from a low ambient or are things really hot in your part of the world?
                      vapvapundefined 1 Reply Last reply Reply Quote 0
                      • vapvapundefined
                        vapvap @deckingman
                        @deckingman Normal room temperature (~20C).
                          What happens if you use a lower target temperature such as 70C?
                          The bed needs to be allowed to cool down completely to room temperature between tuning attempts.
                          • vapvapundefined
                            vapvap @dc42
                            11:20:51 PM
                            M307 H0 A181.2 C1041.0 D4.0 P0.5
                            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 206C.
                            11:20:43 PM
                            M307 H0 A181.2 C1041.0 D4.0 P0.6
                            10:39:52 PM
                            M307 H0 A181.2 C1041.0 D4.0 P0.7
                            10:39:27 PM
                            M307 H0 A181.2 C1041.0 D4.0 P0.8
                            10:38:52 PM
                            10:21:55 PM
                            Warning: Auto tune of heater 0 failed due to bad curve fit (A=181.2, C=1041.0, D=-0.8)
                            10:05:55 PM
                            Auto tune phase 3, peak temperature was 70.3
                            10:05:48 PM
                            10:00:36 PM
                            10:00:30 PM
                            M303 H0 S70
                            Auto tuning heater 0 using target temperature 70.0°C and PWM 1.00 - do not leave printer unattended
                            10:00:00 PM
                            M307 H0
                            Heater 0 model: gain 90.0, time constant 700.0, dead time 30.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
                            Computed PID parameters for setpoint change: P46.3, I0.319, D971.8
                            Computed PID parameters for load change: P46.
                            9:59:31 PM
                            9:59:31 PM
                            Page Load complete!
                              Try with those M307 settings. The warning message is usual when using a high-power bed heater.
                              • vapvapundefined
                                vapvap
                                This post is deleted!
                                  What type of heated bed is it?
                                  • vapvapundefined
                                    vapvap @Phaedrux
                                    @phaedrux Aluminum disc 220mm (Delta Printer).
                                    • vapvapundefined
                                      vapvap @dc42
                                      In the end, I achieved a positive value.
                                      But what to do next?
                                      After all, the "auto tune" still does not work.
                                      7:20:11 PM
                                      Warning: Auto tune of heater 0 failed due to bad curve fit (A=183.8, C=1042.4, D=0.1)
                                      7:04:11 PM
                                      7:04:04 PM
                                      6:58:52 PM
                                      6:58:46 PM
                                      M303 H0 S70
                                      6:58:30 PM
                                      M307 H0
                                      Heater 0 model: gain 188.4, time constant 1070.6, dead time 5.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
                                      Computed PID parameters for setpoint change: P202.9, I2.773, D710.0
                                      Computed PID parameters for load change: P2
                                      6:58:23 PM
                                      M307 H0 A188.4 C1070.6 D5.0
                                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 213C.
                                        Phaedrux Moderator @vapvap
                                        @vapvap said in Heated bed PID auto tune failed.:
                                        And what is the heating element?
                                        • vapvapundefined
                                          vapvap @Phaedrux
                                          @phaedrux said in Heated bed PID auto tune failed.:
                                          https://www.amazon.co.uk/anycubic-MK3-Round-Aluminium-Diameter-Printers/dp/B01LZ36INV
                                            Ok, now is it wired as 12v or 24v? What is your power supply voltage and wattage?
