Pressure Advance Calibration
The main interaction of pressure advance and jerk is that if the extruder jerk is set too low, then increasing pressure advance may cause acceleration to be reduced in order to satisfy the extruder jerk limit.
@dc42 said in Pressure Advance Calibration:
Yup, my printer is completely different since disabling pressure advance. Unfortunately the jerk can't be that high on E3D Titan because it makes very strange noises (K0.2, bowden, Titan jerk set at 400).
I was always wondering why bumping speeds, jerk and acceleration didn't make the printer more noisy/abrupt, until it struck me that it has to be related to pressure advance (i.e. extruder jerk).Now the printer hardly sits on the table with XY accel at 5000. The quality didn't drop enough with the new real acceleration and pressure advance disabled to warrant enabling it again.
Titan extruders seem to vary, perhaps because they have varying amounts of backlash in the years. The one on my delta works well with pressure advance 0.2, but some other users report that they become noisy.
@deckingman all the firmwares handle start/stop jerks a little differently and I don’t know what RRF does specifically. Repetier uses half the jerk for starts/stops/reversals as it does for corners iirc. Sailfish treats every axis separately (axis speed change not tool vector velocity jump) and uses zero jerk when an axis reverses direction, full jerk at starts/stops. But all extruders across all non-S-Curve firmwares to my knowledge use start/stop jerks regularly as they retract, reprime, etc.
There’s nothing wrong with velocity jumps on starts/stops. If you just think about XY Cartesian motion, there’s no difference to the Y axis if it’s doing a right turn from +20 X motion to +20 Y motion versus starting+20 Y motion from a dead stop.
@rcarlyle Ah OK. I bow to your superior knowledge - I only have experience of using RRF. I do recall David saying that "jerk" is not applied at the start of print head moves from a standstill and can confirm that this is the behaviour that I have observed.
@deckingman fair enough, firmware-specific info always trumps, but what does RRF do on reprime between a travel move and a printing move? That’s just another corner as far as XYZ is concerned, but it’s starting from a standstill for the extruder.
@rcarlyle said in Pressure Advance Calibration:
For extruder jerk? I have no idea. The moves are a bit short and fast to say that I've ever paid much attention. Interesting thought though. Also, I use firmware retraction so I wonder if that behaves any differently to slicer generated E moves. Guess we need DC to step in here.
RRF doesn't apply jerk at the join between a printing move and a non-printing move. A printing move is one that has both forward extrusion and XY movement.
Geez I haven't posted in a long long time, connected my Duet to new delta printer, since my previous printer which housed it got disassembled, but speaking of pressure advance calibration - are there types of prints where it shouldn't be used?
I've spent last 2 day testing pressure advance, settings of jerk/acceleration etc, got to the point where a cube would print ok, but other shapes had issues. It's a Bowden tube, 65cm-ish, quite long, after temperature calibration of the PLA I'm using, I've found the sweet spot for retraction and S value of 0.18 gave me best edges.
Now, I have used Marlin K factor calibration tool as my basis ( http://marlinfw.org/tools/lin_advance/k-factor.html ), modified it to suit Duet, removed what I didn't need etc, came up with a code to test the best S value this way - and it's S 0.65 where the line is most uniform right across.
Printing geometric shapes like cubes, polygons etc looks much worse than with lower value, thick seams, bit rounded corners etc, now to make it even stranger, I'm printing a twisted tower model as I'm writing this, which is an "organic" shape, not just technical straight shapes - started it off with S value of 0.18 but the quality was shocking, extruder was having a seizure, each layer looked inconsistent compared to the previous one etc... after 10mm I've disabled it - model from there on looks perfect.
Is it not recommended to use PA for organic shapes? Sorry if it's something that was discussed to death, haven't visited this forum for a good year by now.
Here's the gcode I've used to test S value: 0_1539501893621_sfactor0.5.gcode
To see if I could separate extrusion from motion effects, as an experiment, I built a small jig to measure the thickness of a single-walled print. I then printed a 150 mm long print with uniform print speed (50 mm/s), but varying extrusion volume (0.7 -> 0.4 -> 0.7 mm extrusion width) as a step function. One caliper of the jig measures thickness (mechanically magnified 4x) and another the x position along the test print. Manually measuring a number of positions gave the following result. I'm treating
wall thickness
*layer height
*linear distance
as an approximation for extrusion volume here (ignoring the fine layer induced surface structure).For a first quick experiment, I'm pretty happy with how nice the data looks. Interfacing digitally with the calipers would make this a lot quicker though.
I'm not sure why the first segment didn't converge to the same value as the last one – but I can see some minor ripples that look like the print needs a bit more cooling towards the end of the first segment that may pollute the measurements a bit. I'll retry with some delay between each layer to allow for more cooling next time.
@dc42, when running at constant linear speed but varying extrusion rate like this pressure advance doesn't seem to have any effect. Is that expected?
I'll redo this for a few different extrusion rate pairs and see how well I can get the current model to fit.
@mo said in Pressure Advance Calibration:
Please explain what you mean by "extruder was having a seizure". High values of pressure advance cause the extruder to retract filament before the end of some printing moves. For this to work well, the extruder must have low backlash. With some geared extruders, the gears don't mesh tightly enough, resulting in high backlash and a lot of noise.
@digitalvision said in Pressure Advance Calibration:
wall thickness
*layer height
*linear distance
That graph is close to what I expect when there is no pressure advance. The measured extrusion rate approaches the commanded extrusion rate exponentially with a time constant of about 0.2 seconds. So I would expect the measured extrusion to look a lot squarer with 0.2sec of pressure advance.
Good evening sir!
Hehe by having a seizure I didn't mean anything erroneous on the side of Duet or pressure advance - I'd say it was doing exactly what it was supposed to, adjusting the pressure of extrusion according to speed and turns/corners, it was just doing it at a frequency I wasn't expecting, it hardly stopped, I have a small gear shaped knob placed on the shaft for decoration and to see retractions better and it was in constant back and forth motion, paired with the sound it makes. Hence the 'seizure' reference
From what I'd assume after lurking on forums and browsing previous posts and threads, I didn't think that S0.18 was a particularly high value, especially for a bowden with a tube that's over 60cm long.
It's an ungeared extruder feeding directly into the ptfe tube (Anycubic Kossel Linear Plus), current settings M566 E1800, M203 E1800 , M201 E1000.
Not sure what happened there to be honest, when it was tracing the rock base of this statue (3 outlines) it would regulate the pressure on every turn, change of direction or corner, but whether it's the hardware not keeping up or just jitter induced by so many adjustments, the bottom layers are all messy and misaligned, I'll post a picture soon, 4% left.
If it's applying pressure advance between the short segments of a curve, there are two reasons why this may happen:
- Your XY jerk setting is too low, so the machine is having to slow down at the junctions between segments;
- Your slicer is generating moves with changing extrusion rates instead of a uniform extrusion rate. S3D used to be particularly bad at doing this.
Hmm, S3D it is indeed, that I've used to slice it up.And I've been tackling some ringing issues today and have drastically lowered the jerk values, this model now is printing at 120 value only.
Your comment answers something that I'm observing, PA is disabled, value 0, beside retractions the gear should be moving uniformly forward while extruding - but it's not, it does have moments of speeding up and slowing down, so what you've just said about S3D seems to be at play in here.
Also made a python-script to generate test pattern for pressure advance. I use a cylinder printed in spiral vase mode instead. Plan to extend it into generating a square pattern and Marlin-like pattern as well. Feel fre to try it out if you like. Just rename it to pa_cal.py and run the command:
python pa_cal.py > pa_cal.gcode
0_1539520976520_pa_cal.py.txtAnyone running into problems with Jerk on a Zesty Nimble above 0.1 when tuning pressure advance?
I don't want to appear to be spamming these forums but I've just posted something elsewhere that has a bearing on this thread. https://forum.duet3d.com/topic/7276/high-speed-high-volume-flow-rate-printing
A g-code question...
Will these produce a different result for calibrating pressure advance, if so, which of them is best?
G1 X0 Y0 F12000
G1 F4200
G1 X0 Y30 Ex.xx
G1 X0 Y60 Ex.xx F1200
G1 X0 Y90 Ex.xx F4200or
G1 X0 Y0 F12000
G1 F4200
G1 X0 Y30 Ex.xx F4200
G1 F1200
G1 X0 Y60 Ex.xx
G1 F4200
G1 X0 Y90 Ex.xxWill the top one be interpreted as a linear interpolation of the feedrate between the start and end point and the second one be a more instant acceleration?
They should both be treated exactly the same.
