Requests for help: Gcode cam follower/ tangential knife control.
wow, that's all i have to say...
https://www.youtube.com/watch?v=yPXUmXTCtok
https://www.youtube.com/watch?v=aq7Zv-7jEf8
~Russ
47.5 AWG wire. about 1000 turns, 4.186 Kohms. That's a lot of resistance!
Its funny you cant even see the wire going in to the tool...
not to bad. got a bit of a slip there in the center.... more to tune still. also the roller play's a roll. Get it... ha,
on i'm slap happy...God Bless,
~Russ -
Nice! Anyone have any ideas of applications for flat coils? Wireless charging perhaps?
...yes, wireless charging coils. See https://uk.farnell.com/w/c/passive-components/inductors/charging-coils/prl/results?st=wireless+charging+coils.
Off the top of my head, besides wireless charging: VLF radio. Magnetic radio for underground (cave, tunnel, etc) to surface communication. With larger gauge and some spacing, bed heat for a delta or polar, or induction heating. Metal detector coil.
Hi @Russ-Gries ,
Fantastic topic.
So, you use Duet3d wifi with RepRapFirmware correct ?
What is your gcode generator /slicer ?
You create a script to run your gcode and change the values ? Do you have more information about your post processor ?
Thanks
Just about everything is documented on this playlist. :
https://www.youtube.com/playlist?list=PLsiIKXpZfLKI-UXGFdXYS2groWniI-Eh5
If you want to know why i built it. Its to build this:
And test some theories...
~Russ
Yes, I follow you on YouTube
so, in this video you use Fusion 360, after that you use Simplify3D correct ? But you create a script to adjust the xyz to xyzU correct (U/A the angle of extruder 1), do you have some documentation ? or a start point for me (forum/ paper etc.. ?) I need to do the same for a concrete 3D printer.
I know that it is possible to do it automatically with Mach3 but I would like to try to do it myself.
At this moment I use Autodesk Inventor + PrinterRun (www.pronterface.com/) , it's possible to create scripts / macros with python to create the "final GCode".
My idea is change the rapms 1.4 (3d printer mainboard) by Duet3D and adjust this code to create the "tangential control" .
How do you adapt the Duet3D to create a U axis ? (the new "Extruder" axis ) ?
Thanks.
undefined resam referenced this topic
undefined Phaedrux referenced this topic
undefined deme referenced this topic
