    Configuring 12864 LCD on Maestro?
    79
    24.0k
    • JRDMundefined
      JRDM
      The Maestro docs say nothing about how to turn on the 12864. I haven't actually tried "just plugging it in" but I assumed there's something to configure as it seems like everything else on Duet needs to be configured before using.
      Apart from one page on how to write your own menus, this seems to be the only meaningful thing in the Maestro docs about the 12864:
      The Duet 2 Maestro also support the PanelDue colour touchscreen. Connectors for a 12864-type mono graphics display and rotary encoder are also provided (these are not yet fully supported in firmware).
      ( https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Hardware_Overview )
      I haven't actually started setting up the Maestro but I've set up a DuetWifi and DuetEthernet a year ago.
      • incogizmoundefined
        incogizmo
        I am running a Maestro with 12864 LCD. I can confirm there is no real configuration required to enable the LCD appart from plugging in the display and creating menus.
        The menus I am using are from the M3D Crane that dc42 linked in another post. I will see if I can track it down.
        edit: https://forum.duet3d.com/post/68888
        • Vetiundefined
          Veti
          The Menu system with example is here
          https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
          The Display can be configure using M918 P1
          However for me there is a problem where the device does not get initialized correctly
          Try pressing the rest button on the display
          dc42undefined 1 Reply Last reply Reply Quote 1
          • JRDMundefined
            JRDM
            OK, thank you. That's probably the first thing I will try.
            • Agniusmundefined
              Agniusm
              I am testing clone maestro before I get the real deal. I have ender 3 and it comes with 12864 lcd. Its different than is advised that it does not have sd card. It has 3 exp connectors. Exp3 matched pins on duet lcd but will it work with only one cable as I have menus on but lcd is blank? Would be good to get it working as that would save me some money as I need lcd's for 12 printers.
              dc42undefined arnd13undefined 2 Replies Last reply Reply Quote 1
                dc42 administrators @Veti
                @veti said in Configuring 12864 LCD on Maestro?:
                Try firmware 2.02RC5 is you are not already using it. In this version, the 12864 display initialisation is deferred until the M918 command is processed. This gives the display more time to self-reset. Also, you can put a G4 delay command before the M918 command if necessary.
                  dc42 administrators @Agniusm
                  @agniusm said in Configuring 12864 LCD on Maestro?:
                  The schematic is at https://github.com/T3P3/Duet/blob/master/Duet2/Duet2Maestro_v1.0/Duet2Maestro_Schematic_v1.0.pdf. The connections for the LCD are all on connector P2. Connector P1 carries the connections for the SD card (which you can leave out) and the ENC_A and ENC_B connections for the rotary encoder.
                  • arnd13undefined
                    arnd13 @Agniusm
                    @Agniusm
                    I just got the Ender-3 display working with Duet Maestro running firmware 2.02RC5. You have to activate the display as described by dc42 with gcode M918 P1 E4
                    (I used E4 because the response to the encoder was better).
                    Here ist the wiring:
                    Agniusmundefined 2 Replies Last reply Reply Quote 1
                      Thanks! May I add your diagram to the wiki documentation?
                      deckingmanundefined arnd13undefined 2 Replies Last reply Reply Quote 0
                      • Agniusmundefined
                        Agniusm @arnd13
                        @arnd13 thought i read somewhere that command is not necessary, well, great news then.
                        • Agniusmundefined
                          Agniusm @arnd13
                          @arnd13
                          Just tried wiring it according to your pinout and its still blank. I updated firmware to 2.02RC5.
                          Does M918 goes to config.g?
                          Where did you get your menu files? Should not make a difference bu still...
                          • deckingmanundefined
                            deckingman @dc42
                            @dc42 said in Configuring 12864 LCD on Maestro?:
                            Is that wise? Given that this is another clone? Can you be sure that the pinouts are the same as an original?
                            Agniusmundefined 1 Reply Last reply Reply Quote 0
                            • Agniusmundefined
                              Agniusm @deckingman
                              @deckingman said in Configuring 12864 LCD on Maestro?:
                              e same a
                              Mine is clone until i fry it and make it all good.
                              @arnd13 may have genuine, i dont know.
                              I have just made jumper wires and wend wire by wire but its still blank. It might be clone pinout as deckingman mentioned, have no clue.
                              • Agniusmundefined
                                Agniusm
                                I went poking wires all over and can confirm it is working now. Pinouts given by @arnd13 did not match. I have tested Reparapdiscount display which came in at the time i was doing this today. It worked strait out of the box so clone maestro pinouts for LCD and SD(confirmed) are correct.
                                If you like to add it to wiki here is wiring diagram i made. Cheers
                                0_1543846754679_wiring.jpg ,
                                arnd13undefined 1 Reply Last reply Reply Quote 2
                                • arnd13undefined
                                  arnd13 @dc42
                                  @dc42 Yes, no problem.
                                  • arnd13undefined
                                    arnd13 @Agniusm
                                    @agniusm That's fine. The only difference ist that LCD_CS (EXP1) and SPIO_CS0 (EXP2) are swapped.
                                    Strange but my Display is working too ๐Ÿ™‚
                                    My configuration is original ENDER-3 (no PRO) with display like shown above.
                                    arnd13undefined 1 Reply Last reply Reply Quote 0
                                    • arnd13undefined
                                      arnd13
                                      Now I'm playing around with the display files (absolute beginner) and found something strange.
                                      I tested the examples from here https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
                                      and the linked files from CraneQuadMenuFiles here https://forum.duet3d.com/post/68888
                                      With both configuration submenus could not be opened/started. I realized that it must be the "menu" entry in the files. For example:
                                      button R15 C5 F0 T"Temperature ยป" A"menu" L"x_temp"
                                      ist NOT working.
                                      button R15 C5 F0 T"Temperature ยป" A"menu x_temp" L"x_temp"
                                      is WORKING.
                                      I edited the whole "menu xx" entries in the CraneQuadMenuFiles in the same way as above and now the menus are working.
                                      Am I thinking wrong or is it necessary to add the corresponding filename in the "menu" entry?
                                      russellundefined 1 Reply Last reply Reply Quote 0
                                      • arnd13undefined
                                        arnd13 @arnd13
                                        @arnd13 said in Configuring 12864 LCD on Maestro?:
                                        I made a short test and can confirm:
                                        Swapping LCD_CS (EXP1) and SPIO_CS0 (EXP2) makes no difference. Both possibilities are working ๐Ÿ™‚
                                        But the diagram with photos from @Agniusm looks better ๐Ÿ‘
                                          Does the Ender with the original electronics have anything connected to the EXP1 and EXP2 connectors? I am wondering whether those connectors might duplicate the pins on EXP3 but in a manner compatible with the RepRapDiscount display. You could use a multimeter to check whether the pins on EXP3 are also connected to EXP1 and EXP2, and if so what the pinout is.
                                          • arnd13undefined
                                            arnd13
                                            The Ender display has 3 connectors EXP 1 to EXP 3. Some of th pins of EXP 1 and EXP 3 are named.
                                            EXP 1 from the pcb side:
                                            EXP 3 from the pcb side:
                                            Some pins are have the same signals. EXP 2 has no named pins.
                                            Maybe it's possible to use 2 standard 10pin cable to connect EXP 1-3 from the Display to Maestro EXP 1 and EXP 2. But until now I didn't have the time to measure and check if it's possible. I'll try to do the next days.
