    Configuring 12864 LCD on Maestro?
    79
    23.1k
    • Agniusmundefined
      Agniusm
      Sorry, what?
      3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
      • 3dmntbighkerundefined
        3dmntbighker @Agniusm
        @agniusm said in Configuring 12864 LCD on Maestro?:
        Sorry, what?
        Kidding dude 😉
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
          3dmntbighker
          Are the menu files that M3D ships on the Maestro available zipped somewhere? My SD card bit the dust today, and I had no backup. Yeah, so a backup admin for NASA had no backup. Ughhh. I got the ones agniusm linked, but I'd like the original ones, or for that matter a zip file of the entire SD card. All I could find was the generic one without the menu directory.
            dc42 administrators @3dmntbighker
            I've put a copy on the ones that came on my Crane at https://www.dropbox.com/s/f6jthzr7vh8619g/MenuFiles.zip?dl=0. They may not be up to date, and they could almost certainly be simplified.
            3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
              3dmntbighker @dc42
              @dc42 said in Configuring 12864 LCD on Maestro?:
              Thanks bro
              • Cataundefined
                Cata
                I'm tired of waiting support in the duet for this lcd, buy 2 maestro to enjoy a simple lcd on my printers
                  dc42 administrators @Cata
                  @cata, the Duet WiFi and Ethernet do not have the hardware needed to level shift the LCD signals to 5V and gate the SPI clock for compatibility with common 12864 LCD/encoder combos. That's the main reason why the firmware builds for those boards don't include the 12864 support.
                  Cataundefined 1 Reply Last reply Reply Quote 0
                  • Cataundefined
                    Cata @dc42
                    @dc42 a level shifter is too basic to implement, not the same with the firm support. Why not implement in the firm and let the users works with the level shifter?
                    • Vetiundefined
                      Veti
                      considering you need an adapter for the ramps to connect an lcd this would not be much different
                        3dmntbighker
                        Is anyone working on the print from SD card functions? It seems like the most glaring thing that's missing from what ships with a Maestro. I'm fully aware that this a back burner project for the devs.
                        Vetiundefined 1 Reply Last reply Reply Quote 0
                        • Vetiundefined
                          Veti @3dmntbighker
                          @3dmntbighker
                          not sure what you mean.
                          the files uploaded to the maestro are stored on the sd card. you can select those and print them.
                          also you can select them from the lcd and print them
                            3dmntbighker @Veti
                            @veti said in Configuring 12864 LCD on Maestro?:
                            @3dmntbighker
                            My Maestro SD card failed a week ago. It arrived with a non-functional set of menu files for the 12864. I don't recall seeing any gcode models on the card out of the box either. I managed to get some portion of the menu to work between firmware updates and doing some editing. DC42 sent me the Crane files he had to get me functional again, but the stuff for navigating the card and printing has not worked for me so far since the card failure. I got a missing file error. I'll look it over again when the printer isn't busy.
                            edit: For whatever reason it failed yesterday and it works now? Go figure.
                            • zanoneundefined
                              zanone
                              just received my Maestro board and took the 12684 lcd from my ramps board.
                              After powering the Maestro the lcd shows just a blue screen 😞
                              I have setup the "main" file with just the follwing line
                              text R0 C0 F1 T"My 3D Printer "
                              I tried upgrading the firmware to the latest , but the lcd is still not working.
                              Is there anything i i'll have to do to make it work?
                              Firmware Name: RepRapFirmware for Duet 2 Maestro
                              Firmware Electronics: Duet Maestro 1.0
                              Web Interface Version: 1.22.6
                              • Vetiundefined
                                Veti
                                M918 P1 ; 128x64 Reprap Display
                                russellundefined 1 Reply Last reply Reply Quote 1
                                • russellundefined
                                  russell @Veti
                                  @veti Hi i have M918 P1 E2
                                  • zanoneundefined
                                    zanone
                                    Thank you guys , it is working !
                                    I am afraid i will bomb you soon with some more noob questions 🙂
                                    • jottesmanundefined
                                      jottesman
                                      If you haven't found it already, you may find this post of interest.
                                      There are some nice examples (shameless plug: Including my own) of menu files there
                                      • secretmanundefined
                                        secretman
                                        tank you guys for the work i got my lcd to work
                                        helse than here i never saw that i needed to add G4 P200 M918 P1 any where
                                        lcd are not necessery but i luv to see what is going on when i pass by 🙂
                                          dc42 administrators @secretman
                                          @secretman said in Configuring 12864 LCD on Maestro?:
                                          What happens if you leave out the G4 P200 bit ?
                                          secretmanundefined 2 Replies Last reply Reply Quote 0
                                            secretman
                                            will try tonight and report
