    Cold-end Extruder which works great
    1274
    • dvmourik
      dvmourik last edited by
      Hi guys,
      just want to share this thing for the ones that don't know it yet:
      A belt friction extruder:
      http://www.thingiverse.com/thing:1247952
      We are using it now on many printers and with normal PLA 1.75mm getting printspeeds over 120mm/s on the delta's with volcano and 1.0mm nozzle.
      With PRO1 from inofill we get 150mm/s easy without loosing quality.
      We are also using spools of 20kg which he can unroll without any support motor. Really a strong very strong way of extrusion.
      Also you won't have any stipped filament anymore… only once in a while you need to change a belt.
      The belts and 50T pulley are available from Motedis. We made some small changes in the original files. If you want those drop me a message.
      I am curious what you guys think of this cold-end extruder. It's not my design so the credits would be for andreasL.
      Bigger and bigger… sky is the limit.
      • briangilbert
        briangilbert last edited by
        that looks like it's going to cause a lot of bend stress on the filament, I reckon some filaments would snap with that much bend, especially older filaments
        Co-creator of the Zesty Nimble direct drive extruder
        • antoine.voiry
          antoine.voiry last edited by
          Hello
          I have tried the BONDTECH some months ago and love it since.
          This is more expensive but it works very well.
          ANTOINE
          • DjDemonD
            DjDemonD last edited by
            I liked the look of the vaeder v-struder http://forums.reprap.org/read.php?1,610779 but it was much hyped and then never really materialised but the idea is sound why pull filament through with tiny sharp teeth when a long section of belt is more effective. That being said I can't fault the titan, rock solid, so good I've stopped looking for a better product. Biggest spool I use is only 2.3kgs though.
            www.precisionpiezo.co.uk
            • briangilbert
              @DjDemonD The Nimble is half the weight of a Titan 🙂
              • InSanity
                InSanity last edited by
                To the belt drive system, Old PLA…..snap snap snap. Nuff said.
                Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                • DjDemonD
                  @briangilbert:
                  I know 🙂 and I'm eagerly awaiting mine to try it out.
                  • DjDemonD
                    @(In)Sanity:
                    But that belt drive system features a fairly sharp (for filament) bend, perhaps it would work with a much straighter path and longer belts to grip the filament. The idea is sound perhaps the implementation can be improved.
                    • briangilbert
                      @(In)Sanity:
                      Yeah thats what I was thinking with my first comment.
                      • briangilbert
                        @DjDemonD:
                        @(In)Sanity:
                        Yes I was thinking about a straight belt like approach just the other day, but I was thinking single sided belt not both sides.
