    Question delta steps calibration..
    856
    • peirofundefined
      peirof
      After discover that the last print issues comes for axis steps calibration...
      And after try to recalibrate steps for mm, with partial exit. I have a dude. The methods I have read, are clear... But they are relative a cartesiano printer...
      The process of steps of axis calibration, its the same that a cartesian?
      I think remember in M92, in config.g.
      I am using the cartesian system.... And, close, but no I the hole
      mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        on a delta printer the dimension of a print come mainly from a correct rod length.
        see http://boim.com/DeltaUtil/CalDoc/Calibration.html
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @Veti
          @veti thanks.... Bufff, its very good.
          • mrehorstdmdundefined
            mrehorstdmd @peirof
            @peirof A long time ago I was learning to speak Japanese and I made many mistakes in word selection and usage and always appreciated it when someone corrected me, so I hope you feel the same way. I have noticed your use of the word "dude" in many posts.
            When you have been using "dude", you should be using the word "question". This post, for example, should be titled something like "Questions about delta steps calibration".
            "Dude" has several uses- many listed here: https://www.wordnik.com/words/dude and here: https://www.merriam-webster.com/dictionary/dude , but none of them means anything like "question".
            This short video clip illustrates another use of "dude": https://www.youtube.com/watch?v=xJjCnWm5cvE
            peirofundefined richardmckennaundefined 2 Replies Last reply Reply Quote 0
            • peirofundefined
              peirof @mrehorstdmd
              @mrehorstdmd thanks for the warning....
              • richardmckennaundefined
                richardmckenna @mrehorstdmd
                @mrehorstdmd I love this forum everyone is always so helpful. I don’t think I’ve ever had a question go unanswered or a problem not resolved. Definitely one of the best 3d printing forums out there.
                  @peirof, assuming all 3 towers are built the same and have similar belt tension, then all 3 should have the same steps/mm. You should can calculate this value, or measure it from the Z height of your prints.
                  • peirofundefined
                    peirof
                    hi,
                    i will recheck....
