    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    52.8k
    • 3dprinting meatheadundefined
      3dprinting meathead
      5. True bed levelling using 2, 3 or possibly 4 independently-driven Z motors and a Z probe
      would that square up the x axis to the bed? like for an i3, probe z at left and right, and then move each z motor independently to make the x axis parallel to the points probed?
      If this question is too off topic, just disregard.
      If I can learn it, than anyone can learn it.
      • roboduetundefined
        roboduet
        1. WiFi server, specially FTP support. I'm missing it after moving from Duet 0.6
        3. Logging.
        7. Dynamic microstepping to switch from x16 interpolated mode.
        15. Support for 12864 displays.
        16. Better temperature control
        XX. Automatic firmware update from web interface (download firmware directly from internet, check md5 or sha hash and update if hashsum is ok). Plus check for updates button in DWC.
        • tomasfundefined
          tomasf
          19
          20
          16
            3dprinting meathead
            14
            8
            in no particular order
            • hairy_kiwiundefined
              hairy_kiwi
              3. Logging… of Temperature values also?
              15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays. Especially if useful/required for controlling a machine away from its usual WiFi network?
              5. True bed levelling... The 2 z-motor solution would be sufficient for my current setup.
              1. Reworked WiFi server code... Not sure I understand the limitations of the current code base well enough, but anyway.
              17. Filament and printing time odometers.
              • Huguesundefined
                Hugues
                …And a filament monitor support based from rotary encoder
                • caphectorundefined
                  caphector
                  I'd love to see support for the Prometheus-style multi-filament hot ends as well. Both Prometheus and Prusa have made them. They retract filament when it's not in use and then advance the alternate filament. I think the only big change would be to filament movement distances.
                  • demonio669undefined
                    demonio669
                    • Allow M117 to send message via email
                    • start and stop printing macros (o allow to send email when the print begins and ends)
                    • tomwang256undefined
                      tomwang256
                      18 - i accidently broke off my usb connector on the paneldue 😞
                      • windieselundefined
                        windiesel
                        19
                        • T3P3Tonyundefined
                          T3P3Tony administrators
                          @caphector:
                          13, 1, 7, 2, 15
                          These are already supported. The retraction length can be set either in the slicing software or the tool change gcode.
                          www.duet3d.com
                          • pjr3Dundefined
                            pjr3D
                            My vote(s):
                            1 - There is a need to be more tenacious about finding and then keeping a connection where there are many competing wifi routers. It is the most frustrating aspect at the moment especially in the evening when everyone in the area is going online!
                            7 - Dynamic stepping for my delta …
                            16 - Better temp control is always good.
                            18 - This is mostly a convenience but would be handy.
                            17 - Helps to keep track of usage for maintenance etc.
                            • larsundefined
                              lars
                              My vote:
                              • appjawsundefined
                                appjaws
                                I have been trying to implement a fail safe switch which will stop Z homing and move the bed down 5mm.
                                I am using your mini probe but want to test a piezo version I have constructed but I am worried that if it fails, nothing will stop the bed moving and damaging the hotend or bed surface.
                                I originally tried "M581 Z S1 T2 C0 ; Set Z stop as fail safe for Z zeroing and run /sys/trigger2.g"
                                and a /sys/trigger2.g file with the following entries G91, G1 Z5 F200
                                This works when moving the bed manually but has no effect when homing Z.
                                Deckingman suggested using the spare E0 connection "M581 E0 S1 T2 C0" this did not solve the issue and performed the same as the Z connection.
                                Does the firmware lock the system until homing has completed?
                                If so would it be possible to change that so the process can be interrupted in the way shown above or is their another way to protect the hotend and bed from probe failure?
                                appjaws - Core XYUV Duet Ethernet Duex5
                                firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                Ormerod 1-converted to laser engraver, Duet wifi
                                OpenSCAD version 2024.03.18
                                Simplify3D 5.1.2
                                • lolorcundefined
                                  lolorc
                                  my vote is : 1, 6, 7, 8, 14
                                  • jacksatundefined
                                    jacksat
                                    16
                                    14
                                    • Ntesla66undefined
                                      Ntesla66
                                      Hello, Love what you've done already! Just amazing.
                                      Cast vote as : 1, 3, 6, 8, 16.
                                      Best Regards.
                                      • Merlinundefined
                                        Merlin
                                        Vote of a 'simple' user
                                        14,
                                        13,
                                        16,
                                        17
                                        • jmjcoke2undefined
                                          jmjcoke2
                                          11
                                          14
                                          12
                                          • Loffy770undefined
                                            Loffy770
                                            4..being able to utilize 5v switches on Duex for XYZ
