Unsolved PEI surface without adhesive?
But wouldn't you want rigidity while surface and part cools?
@Nxt-1 Not sure if the frame permits it but how about simple clips like the overly used fold-back clips or something like in this (German) shop? There are variants that span 8+mm and would only take marginal amounts of space at 3-5 points around the perimeter.
@nxt-1 said in PEI surface without adhesive?:
The issue is that if it does not work without adhesive, I would need to come up with another solution to keep it removable.
I am using this stack: insulation, 3mm aluminum with printed heater, adhesive, magnetic sheet, sprint steel plate, adhesive, 1mm PEI, and it works quiet well. Down side is that the magnetic sheet will lose it's properties if I will go above ~80C (at least this is what I heard).
There are magnetic sheets that will work up to 120C if I recall correctly.
@wilriker said in PEI surface without adhesive?:
That might actually be the most elegant solution if just the 3 locating holes and pins I planned are not sufficient.
My concern was more that when it heats up it will expand and soften, making it difficult to keep flat in the center even if you pin or clamp the edge. But its an interesting approach, please do report how you get on.
@bearer It will be at least a couple of weeks before I order all the materials, if not months. But if I have experiences to share, I will add them here
@bearer said in PEI surface without adhesive?:
Very interesting link. Thanks. I plan to upgrade my bed to 5/16" mic-6 and may use this magnetic sheet.
@nxt-1 I've tried exactly the same for my Wasp 60100 delta (60 cm buildplate). Got a 60 cm 1 mm thick sheet of PEI without adhesive and initially taped it down with kapton on the fringe. However, the PEI does warp when heated (even at 60C, more so at 100C) and not only pulled off the tape on the fringe but also bulged in the centre area. I then added spokes of double-sided kapton tape which mostly prevented the bulging in the centre: But, even then, it still lifted off the kapton tape at the fringe by several mm after a couple of hours, which would ruin the very large prints I want to do. There might be better/smarter solutions using other types of tape (better adhesive) or other ways of placing the tape but at this point the work to tape it down sufficiently somehow is way too much work. I'm wondering if I should have gone with a much thinner sheet thickness b/c the warping is probably less (?) but I don't know how thin is still practical and I'm not about to spend another $150 to find out. No sure what I'll do with the 1 mm sheet I have but I either have to perma glue it to the bed or find a springsteel/magnetic solution for it ...
I think it would work fine if the tape wrapped under whatever the PEI is sitting on. Just holding down flat like that requires very little force to peel it up.
@charding said in PEI surface without adhesive?:
Well that is exactly what I did not want to hear haha. Thanks for your experience.
I assume 'loose' PEI is off the table now sadly. The only alternative I can think off right now is to glue the PEI to a thin-ish flat aluminium tooling plate and consider that the removable part. The bed stack would become (optional) insulation -> aluminium tooling plate heat spreader -> aluminium tooling plate -> 3M -> PEI. I would hope to locate the alu/PEI combo in XY direction with locating pins/holes on the base heat spreader and unconstrained for the Z.
Before I planned to use a 6mm thick plate as heat spreader. I wonder what thicknesses I should plan now. Maybe something like 4-5mm for the base heat spreader and 2-3mm for the part the PEI will be attached to.
I also wonder whether the base heat spreader still needs to be tooling plate and regular flat-ish aluminium will suffice. Any thoughts? -
flat-ish
Since you want to transfer heat evenly between the two plates I would think you'd want it more than just flat-ish.
I think you would want the base that the heater is attached to to be tooling plate for the flatness and thermal conductivity, and then use a simple piece of aluminum sheet which will conform to whatever it sits on for the other piece. If you do it the other way, the base won't be flat and thermal performance will suffer.
@mrehorstdmd said in PEI surface without adhesive?:
This might be the way I will have to do it as finding tooling plate available to Belgium, EU as a consumer seems to be no easy feat. Best I could find was https://www.aluminiumwarehouse.co.uk/ and the thinnest they cary is 5mm. Doing two sheets of 5mm would be to much thermal mass I believe as well as rather expensive.
you can do it with a vacuum bed.
That´s the way I´m doing it.
Works perfectly with all kinds of sheets. Here is me printing ABS on a PEI sheet
Here is PPSU being printed on a PEI sheet
You just have to remember that you shouldn´t go above 190°C on the bed/chamber temp with the PEI sheet, otherwise this will happen
You will basically thermoform the PEI onto the build plate and it will flow into the channels.
For this reason most of the time i use borosilicate glass plates for printing high temperature stuff.
I can´t use magnets because at those high temperatures they would demagnetize.Cheers
Max -
@nitrofreak Holy crap, that is amazing. I have vacuum clamping in metal machining centers, but never on a 3D-printer. A quick Google leads me to believe that ready made tables are quite expensive though. Also, I am not sure if I would want a vacuum pump running for hours on end in my room. I love the idea though.
If the system didn't leak (much) and had some pressures control the pump would not run continuously. In an ideal setup it would just pull the vacuum and turn off, but I suspect in the real world some leakage would be expected, but I don't think it would require constant running.
Yes exactly you can just turn on the pump, pull a vacuum (takes only a second) and switch it off. it holds around two hours more or less. In future i want to include a small reservoir and a digital pressure gauge that kicks the pump on once it goes above the threshold pressure. For long prints i just let the pump run while i´m away.
you can get machining vacuum plates relatively inexpensively.
https://www.ebay.de/itm/Vakuumtisch-VT2020-R-20mm-Raster-aus-Gussaluminium-fur-CNC-Frase/292939802580?hash=item443492a7d4:g:aVcAAOSwPVFcUX7o
This is a 20x20cm bed, but it is available in all kinds of sizes. It even has the side mounted vacuum connectors.
I just made my own out of a 15mm cast aluminum plate because i have acess to a cnc, and i can mill it to size.
I also used brake line and crimp connectors that can handle the heat going into the chamber. Outside it is connected to the Z axis and changes to a PU tube which goes to the vacuum pump. -
I finally found a local source for 6mm cast and milled aluminium plate. Could you guys agree with the following layer stack (bottom to top):
1 - Silicone heater
2 - 6mm cast aluminium plate
3 - 3mm regular 1050 aluminium plate
4 - 3M glue sheeth
5 - 0.2mm PEI sheetFeedback welcome, especially on the thickness of layer 3. I am also still kind of unsure how good of a thermal contact and flatness I can expect between the two sheets of aluminium.
