    Core XY weired behavior of the Z-Axis and Endstop config
    1.4k
    • Bipotronicundefined
      Bipotronic
      I put in the G-code "G0 Z295" in the console and nothing hapend. No error Messages only "G0 Z295" cloered in Green.
      Also weired, if i send "G1 X20 Y20 F2000" the X-axis and Y-axis move, but if they are positioned the Z-axis moves also.
      Vetiundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @Bipotronic
        @philipp-r said in Core XY weired behavior of the Z-Axis and Endstop config:
        what do you mean by positioned?
        your M92 has Z650.00. this is a unusual number.
        what lead screw do you have?
        Bipotronicundefined 1 Reply Last reply Reply Quote 0
        • Scachiundefined
          Scachi
          Where is your M584 drive mapping line ?
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
          • Vetiundefined
            Veti
            the M584 is not required if the default mapping is used.
            Scachiundefined 1 Reply Last reply Reply Quote 0
            • Scachiundefined
              Scachi @Veti
              @veti said in Core XY weired behavior of the Z-Axis and Endstop config:
              Ah, thank you for this information 👍
                Bipotronic
                I use a precision Ballscrew with a 5mm pitch without a gear.
                  Bipotronic @Veti
                  @veti i ment, when i send the G-code "G1 X20 Y20 F2000" the X and Y-axis move to the position X20 Y20... after they reached this position the Z-axis will also begin to move without any commend used.
                  • Vetiundefined
                    Veti @Bipotronic
                    @philipp-r
                    that is very strange behavior. in which direction does it move? how far does it move?
                    do you have a config-overwrite file?
                    how many motors does your z axis have. how are they connected to the duet?
                      deckingman @Bipotronic
                      The lack of Z axis movement can be explained by the fact that you have set the maximum limit to 0 and the minimum limit to 300.
                      "M208 X425 Y343 Z0 S0 ; Set axis maxima
                      M208 X0 Y0 Z300 S1 ; Set axis minima"
                      Change that to be:
                      M208 X425 Y343 Z300 S0 ; Set axis maxima
                      You have defined the Z axis end stop to be at the high end (Z max)
                      M574 X1 Y1 Z2 S0
                      Is that intentional? Do you really have that end stop at Z max?
                      Bipotronicundefined 1 Reply Last reply Reply Quote 2
                      • Vetiundefined
                        Veti
                        @deckingman said in Core XY weired behavior of the Z-Axis and Endstop config:
                        good catch. but why would that cause z movement after x and y movement?
                          deckingman @Veti
                          I didn't say it would - I was very careful in my choice of words ☺
                          I suspect that Z movement may be something else, but the OP should at least put the axis limits right first.
                            Bipotronic @deckingman
                            @deckingman thanks for your answer.
                            Your right i changed it and the lack is gone.
                            Yes i did thet intentionaly, because the endstop is at the lowest position the bed can reach. Related to the printhead this is the max Position. I also chose the right hand rule for thze coordinate frame.
                            I want to tell the machine if the Z-axis hits the endstop, it is position 300mm. But however i change the M208 command i did not get the right position.
                            When i home the Z-axis and type in 300mm into the Machine setting/Headposition at the left corner at the Web interface, the machine behaves like i want it to.
                            Does anybody know if i can save this kind of input or which M-command i should use to get the same Result.
                              Bipotronic @Veti
                              @veti
                              • list itemit will move downwards until it hits the endstop again.
                              • no i don't have an config-overwrite file
                              • i use only one motor and its puged in at the Z-axis spot on the duet2ethernet
                              • Vetiundefined
                                Veti
                                i would suggest you start without the z max for now and try and get the machine working.
                                use the probe for now to determine z=0.
                                determining z=0 from a z max endstop is not that easy.
                                  Do you have the direction of your Z motor correct? If the bed moves in the Z direction (not the print head), then increasing Z should move the bed down. The Z coordinate is the distance between the print head reference point and the bed.
                                    0_1563819506187_e5c637cd-7710-416e-93d6-eefb576f0824-image.png dbot axis.png
                                    Does this make more sense?
                                      Bipotronic @dc42
                                      @dc42 yes when i increase the Z value the bed moves down. I checked the direction of all axis they are correct.
                                      is there a change that there is something wrong with the board?
                                        Bipotronic @Phaedrux
                                        @phaedrux said in Core XY weired behavior of the Z-Axis and Endstop config:
                                        Thank you for the picture. This is exactly like i set up the Z-axis.
                                        • oliofundefined
                                          oliof
                                          So if you have M208 Z0:300 (or the moral equivalent), if you run G1 Z350 H1, what happens?
                                            Bipotronic @oliof
                                            @oliof said in Core XY weired behavior of the Z-Axis and Endstop config:
                                            First i homed teh Z-axis (M208 Z0:300 is configured). At the Webinterface in the field "Machinestatus/Headposition" the Z value is = 0.
                                            Then i type in your G-Code "G1 Z300 H1". Than it changes the value at Headposition from 0 to 300mm.
                                            This is the status i need to work. Also wehn i press the Z=-25mm button at the interface the Bed moves form the lowest position up 25mm further. So it seems to work just fine.
                                            But if i home again the Z axis the value will be overwritten and i have the same problem again.
