    Behavior of drivers at high speeds
    39
    2.7k
    • mrehorstdmdundefined
      mrehorstdmd @NitroFreak
      @nitrofreak Do they take step/direction inputs?
      Do you have a link to a manual for these motors?
      NitroFreakundefined 1 Reply Last reply Reply Quote 0
      • NitroFreakundefined
        NitroFreak @mrehorstdmd
        @mrehorstdmd said in Behavior of drivers at high speeds:
        Yes they do. wiring them and tuning is a breeze. Really easy
          @nitrofreak I think I'll order a couple and try them in the sand table. if I like them enough, I'll put a couple of them in my 3D printer.
          In the sand table, the belts are running on relatively small diameter smooth pulleys. I'm thinking some of the noise is due to the belt teeth contacting the pulleys at high speed.
            NitroFreak
            Yes good just watch out, these servos have a little lower torque than a comparable stepper, but they can rev up to 3000 rpm´s and have the same torque up to 2000. (the nema17 go up to 4000 rpm).
            The nema23 180W version has a torque of 0.57Nm.
            If i were you i would just get the 180W nema23 version since it doesnt cost much more and you can also run it on 24V.
            There are also shorter 140 and 100W versions available if you have space constraints
              deckingman @mrehorstdmd
              @mrehorstdmd I 99% sure that the Duet WiFi interpolation only works if you use 16x microstepping.
                Two suggestions:
                1. Use the back emf calculator at reprapfirmware.org to check that the driver supply voltage is high enough to maintain torque at those speeds. If it isn't, not only will you lose torque but also the motors will be noisy because the current waveform will be clipped.
                2. If that isn't the problem, try x32 or x64 microstepping instead. Interpolating isn't accurate during acceleration.
                mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                  mrehorstdmd @dc42
                  @dc42 Does the Duet board support 32 or 64:1 ustepping without interpolation?
                  • botundefined
                    bot @mrehorstdmd
                    @mrehorstdmd interpolation on the 2660 drivers can only be used with 16x microstepping. To enable interpolation, you must select 16x and set I to 1. If you select 32, 64, or 256 stepping, you are selecting true 1/256th microstepping, etc.
                    *not actually a robot
                      mrehorstdmd @bot
                      @bot Great! I will try tweaking the config file. Thanks!
                        mrehorstdmd @dc42
                        @dc42 Is there any reason to use interpolated microstepping if the drivers can do uninterpolated microstepping to 256:1?
                          Depends on the travel speed and your steps per mm, but if you use 256x (non-interpolated) then you could run into the maximum step pulse frequency of the board/firmware. I think that's currently around 120Khz but check because it used to be 200 Khz.
                          If it helps, using 256x on my extruders which have around 400 steps per mm, I hit the limit using retraction speed above 1800mm/min (30mm/sec) so with say 80 steps per mm you should be OK up to around 150mm/sec.
                            mrehorstdmd
                            I used the back EMF calculator to calculate speed limits based on the motors I am using, current, pulleys, etc. and found that with a 12V power supply, torque slip is the main limiting factor in maximizing speed at all microstep settings from 16:1 up to 128:1. At those settings, maximum speed is limited to about 350 mm/sec. At 256:1 the pulse rate exceeds the controller's 120 KHz limit.
                            I composed a gcode file to move the mechanism at 100 mm/sec and 350 mm/sec at 16, 32, 64, and 128:1 ustepping. Video of the test is here.
                            Here's the test gcode:
                            ; filename: '12V 100 350 mmps'
                            M564 H0 S0 ; enable motion without homing
                            M350 X16 Y16 Z16 I0 ; Configure 16:1 microstepping with no interpolation
                            M92 X40.00 Y40.00 Z40.00 ; Set steps per mm
                            G28 Y F3000
                            G28 X
                            G01 F6000; 100 mm/sec
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 F21000; 350 mm/sec
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            M350 X32 Y32 Z16 I0 ; Configure 32:1 microstepping with no interpolation
                            M92 X80.00 Y80.00 Z40.00 ; Set steps per mm
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            M350 X64 Y64 Z16 I0 ; Configure 64:1 microstepping with no interpolation
                            M92 X160.00 Y160.00 Z40.00 ; Set steps per mm
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            M350 X128 Y128 Z16 I0 ; Configure 128:1 microstepping with no interpolation
                            M92 X320.00 Y320.00 Z40.00 ; Set steps per mm
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            G01 X0 Y1025
                            G01 X725 Y1025
                            G01 X725 Y300
                            I hear a definite decrease in noise at 100 mm/sec when it goes from 16:1 to 32:1 or higher, but 32;1, 64:1, and 128:1 all sound about the same. At 350 mm/sec I don't hear any differences at any microstepping levels.
                            The single motor motion (diagonal) is a lot quieter than the dual motor motion (X and Y), but only one motor is turning, so less vibration as expected.
                            I'm trying to make the mechanism run quietly at speeds like 350-500 mm/sec. Maybe that's just not possible using 2 phase stepper motors?
                              0.9deg motors may be quieter, but they also need more drive voltage.
                              Have you tried reducing the motor current? If the calculator estimates the drive voltage runs out at 350mm/sec then it might happen at a lower speed. There should be a noticeable increase in noise when the speed exceeds the limit. You could also try turning your 12V PSU up to 14V if it is adjustable.
                                mrehorstdmd @dc42
                                @dc42 I played with motor current and found that if I set it to 500 mA, the torque is a bit too low to drive the mechanism reliably. At 600 mA it seems to work well. The motors are rated for 2A.
                                I've tried using 24V and found not much change in noise level, though it lets the mechanism run faster.
                                I have some 3 phase stepper drivers so may look for some cheap 3 phase motors and see if things improve. Otherwise, maybe going to 5 phase steppers will drive it quietly at high speed.
                                  mrehorstdmd
                                  It occured to me that since I have excess torque and excess resolution available from the motors, and that they run quietly if I keep the speed down to <2 revs/sec, I can use pulleys to gear the mechanism up so that 1 rev per sec or so will drive the mechanism at 500 mm/sec. Motor torque is higher at lower rotation speeds and I can crank up the current if necessary to get enough torque to drive the mechanism.
                                  I ordered a set of pulleys with a closed loop belt that will provide a 1:5 step up in speed. I'm redesigning the motor mounts to accommodate the 80 tooth drive pulleys. There will be separate pulley mounts that drive the corexy mechanism- a 16 tooth driven pulley from the motor, and using the 40 tooth drive pulleys that the mechanism is currently designed around. 1 rev of the motor will spin the 40 tooth drive pulley 5x, for 400 mm displacement. The motor and corexy drive pulley mounts will be separate pieces, so I'll tension the corexy belts by moving the corexy drive pulley mounts, then tension the loop belts by moving the motor mounts.
                                  I'm trying to get this done in time for the Milwaukee Makerfaire in mid September, but parts are coming from China, so who knows if they will arrive in time.
                                    @mrehorstdmd This is an idea that I've been thinking about for a long time, although not for the same reasons. My thinking is that it would allow one to use higher belt tension on the main belt that the stepper motor bearings might not otherwise tolerate. Whether or not this would be beneficial, is of course not known. So I will be following your journey with interest.
                                      T3P3Tony administrators @deckingman
                                      @deckingman can you support the motor shaft with an appropriate bearing at the other end or is it not long enough?
                                        deckingman @T3P3Tony
                                        @t3p3tony said in Behavior of drivers at high speeds:
                                        I could maybe just about do it with the Alpha motors but not the Beta motors because I have stacked belts and the pulleys are at the end of the shafts on those motors.
                                          mrehorstdmd @deckingman
                                          @deckingman if you make the motor mounts with different vertical dimensions, by about 12-15 mm, the pulleys can mount right up against the motors.
                                          I used off-the-shelf 2" x 2" and 2" x 1.5" tubing.
                                          The pulley is mounted in the same position relative to the motor on the B motor.
                                            @mrehorstdmd Can't be done on my machine. Or rather, it could be done but I'd have to find a different method to tension the belts, as well as redesign the idler pulley mounts and gantries. All in all, it would likely be easier to mount the motors "remotely".
                                            It'll have to wait in any case because I've got far too many other things to get on with right now.
