    Non planar layers
    55
    4.0k
    • NitroFreakundefined
      NitroFreak @T3P3Tony
      @t3p3tony said in Non planar layers:
      @nitrofreak said in Non planar layers:
      The mechanics is not the problem, it´s just that the software is lacking.
      specifically the slicer to generate the tool paths.
      Yes exactly, Sorry that is what i meant. For the Duet it would be just another axis, although for simultaneous 5 axis you need a pretty powerful processor that can calculate the Dynamic Work offsets realtime. As long as that is not a given, a 3+2 positioning is probably more likely. Also, as long as the duet can´t handle true sinusoidal G2/G3 computing, the simultaneous 5 axis is off the table.
      I found a video of a 3+2 axis 3D printer, even running duet electronics:
      https://www.youtube.com/watch?v=JdsR7nNDN3w
      Anyways, slicers need to step it up to generate the toolpaths for a 5 axis printer.
      First of all, they would need to implement slicing from .step files. This would allow a feature selection, especially for round holes. You could then also easily select planar surfaces to print features perpendicularly from.
      There are CAM module suppliers that sell the toolpath generation algorithms to the CAM software suppliers. Just like moduleworks:
      https://www.moduleworks.com/de/cam/
      I bet they have some 5 axis generation algorithms that could be adapted to 3d printing. However this is not likely to happen in the open source world, as these CAM modules are $$$.
      When i was at the Formnext 2018, i was at the HAGE sondermaschinenbau booth and they had a 5 axis 3d printer. It was this one:
      https://www.youtube.com/watch?v=qYE-WDh3NQM
      They showed me their workflow and they used Siemens NX for the toolpath generation. However they could only use this for pipes and the sort. They partnered with siemens to adapt a "simple" 5 axis swarf to output the gcode for a 3d printer.
      • JoergS5undefined
        JoergS5 @NitroFreak
        @nitrofreak Thank you for the video links, those are interesting samples what is possible. I think the sinusoidal discussion is only the "tip of the iceberg", the problem is, that the drive movement planning should be flexible for all drives, not only for the extruder. Maybe the current firmware extended by the possibility to define algorithms between the driver movements as dynamic parameters (e.g. G-Code at the beginning). E. g. if the heatbed is to be pivoted and is a hexpod, the movements will be nonlinear and complex.
        Problems aside, I am sure an open software community can develop the same quality as commercial firms. There must be a driving group of people (or one person) however who are motivated enough to implement the solution. Maybe we can start with such an effort here with the enhanced Duet 3 capabilities.
        If you look into the kernel of algorithms, they are in general very short, e.g. for Delta, for sinusoidal etc. in the different firmwares, so implementing is not a big effort. A correct model of behaviour is the most important point to start with.
          NitroFreak
          I just found another example of non planar printing all the way back from 2014. It seems to do the same thing
          https://www.youtube.com/watch?v=Qkwkk1S-_Ek
          • JoergS5undefined
            JoergS5 @NitroFreak
            I am thinking about whether Delta has advantages printing rapid changing Z. Cartesian, CoreXY, Prusa, Ultimaker are designed to print layer after layer, whereas Delta prints Z with 3 actuators, this may be an advantage in the case of non-planar prints. Especially because some of the Z layer printers have backlash when changing from move-up to move-down and vice versa.
            • fmaundefined
              fma
              If David implements a 6 axis delta firmware, it will definitly be my next 3D printer! For now, I'm working on my 2 axis tilt bed in order to print portions of sphere (https://forum.duet3d.com/topic/10934/5-axis-3d-printing).
              Frédéric
                T3P3Tony administrators
                @NitroFreak Thanks for the videos. I can add diabase to the list (https://www.diabasemachines.com/home) they use Duet to achieve 5 axis but in a different way.
                More generally if the slicer was able to output X Y Z U V W, where U, V and W are the other three axis (e.g. a tilting/rotating bed) then there is no change required or special kinematics. If you want X Y Z A B C where A,B and C are the tool head rotations, then also no issues in RRF.
                What do you mean by "sinusoidal G2/G3 computing", in this case? surely to implement G2/G3 in this case you would need to define an arc center in each axis that the arc would move on?
                In general tool path generation is going to be an issue. Not just the path in 5 or 6 axis but also a path that avoids collisions with parts of the object already printed.
                • DeltaConundefined
                  DeltaCon
                  This is really cool!
                  Wonder if it wil make it to the home/hobbyist scene.
                  If you think trial and error is dangerous, try routine. That's even more so!
                  • fmaundefined
                    fma
                    Did anyone tried this non-planar-Slic3r edition? I can't get something out of it, just messy G-Code...
                    Frédéric
                    • peirofundefined
                      peirof
                      @dc42... Do you think this can be implemented in Duet?
                      These movement, requires especial slicer and firmware?
                      dragonnundefined 1 Reply Last reply Reply Quote 0
                      • dragonnundefined
                        dragonn @peirof
                        @peirof said in Non planar layers:
                        It only needs special slicer. No changes in firmware needed
                        • Danalundefined
                          Danal
                          And that's what is exciting about it, as vs. prior efforts: It is available in a "mainstream" slicer.
                          • peirofundefined
                            peirof
                            I have found another video/guide
                            Slic3r non plannar layers
                              A Former User
                              Before everyone gets the underwear too messed up with excitement...
                              There is a possible issue of this already having being patented by another company which might stop it being used freely............
                              peirofundefined fmaundefined 2 Replies Last reply Reply Quote 0
                              • peirofundefined
                                peirof @A Former User
                                @calvinx what company?
                                  A Former User @peirof
                                  @peirof
                                  Cant remember, i will try to find the article again, i read it last night on one of the 3d printing blogs.
                                  • sinned6915undefined
                                    sinned6915
                                    and how different is this than a hexapod with 5 axis?
                                    sounds like someone is trying to patent the ESC key again
                                    • fmaundefined
                                      fma @A Former User
                                      @calvinx said in Non planar layers:
                                      Are you sure this will stop us for non commercial use?
                                      Frédéric
                                      • JoergS5undefined
                                        JoergS5 @fma
                                        @fma I had the same idea, and a question: how about building a DIY 3D printer with patented technology and then printing and selling 3D printed parts in a shop. Is this allowed?
                                        • fmaundefined
                                          fma
                                          Good question ; I don't know...
                                          Frédéric
                                            A Former User
                                            Hi
                                            I found the Article.
                                            Possible patent infringement
                                            peirofundefined 1 Reply Last reply Reply Quote 1
