    Hotend temp question
    • PaulHewundefined
      PaulHew
      In my temp chart the hotend is displayed by a wavy line which I presume the Duet2 is turning the hotend on/off continuely
      I have tuned the temp for the hotend and used the results it gave me.
      I thought I saw a post the other day about this, but cannot find it.
      My other printer is a continuous flat line for temp on the hotend.
      Paul
        T3P3Tony administrators @PaulHew
        @paulhew have you tuned the hotend PID loop using M303?
        See: https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        • PaulHewundefined
          PaulHew
          Yes I did use the M303 command, I will however try again.
          • JamesMundefined
            JamesM
            If you don't have a silicone sock around the heater block on your hotend I would suggest doing your heater tuning with the part cooling fan turned on and the nozzle fairly close to the bed.
              Can you show a picture of the graph? What kind of wavy is it?
              • peirofundefined
                peirof
                After calibration... You have saved results? Think M500...
                What post calibration message in console?
                • PaulHewundefined
                  PaulHew
                  After re doing the PID tuning, it came back with different parameters than I had the first time.
                  I manually change the values in my config.g as opposed to using the shortcut.
                  I now get a consistent temp.
                  @Phaedrux I cannot show you now, now that I have fixed it. 🙂
