    motor phase A may be disconnected reported by driver(s) 1
    1.7k
    • keithundefined
      keith @Phaedrux
      @phaedrux
      Yea all the same issues. But it's acting like a bad connection. I'm thinking there has to be bad wire somewhere even though all the connections look good. I'll deal with it tomorrow.
        Yeah a bad wire could fit the description. A continuity tester / multimeter may be helpful. Redoing the crimps/replacing the wire hopefully helps. Hopefully the issue isn't in the motor. But at least it doesn't seem like the issue is on the board.
        keithundefined 1 Reply Last reply Reply Quote 0
        • keithundefined
          keith @Phaedrux
          @phaedrux
          I hope its not the board. I really like the Duet2Wifi. I just don't have the tools here so I'll have to look at it again tomorrow. Tried 3 different LDO motors that I know work and it's all the same, so I'm thinking a bad wire somewhere since it did the same thing on the E1 driver.
          • tekkydaveundefined
            tekkydave
            You could also try swapping the cable with one of the others (if possible) to see if the fault also moves.
            ~ tekkydave ~
            D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
            FreeCAD, PrusaSlicer
            • mrehorstdmdundefined
              mrehorstdmd
              Be careful about swapping cables. If you do have an intermittent connection, you may kill the motor driver. It's best to test the cables off the board- use a meter and move the cable as you read the resistance- it should remain constant. Visually inspect the connector(s) to make sure that all looks right there.
              tekkydaveundefined 1 Reply Last reply Reply Quote 1
                tekkydave @mrehorstdmd
                @mrehorstdmd said in motor phase A may be disconnected reported by driver(s) 1:
                That's a good point. I would remake or replace the cable completely just to be sure. Intermittent faults, by their nature can be hard to track down especially if you have no test equipment (DVM etc).
                ~ tekkydave ~
                • HarveySundefined
                  HarveyS
                  @keith
                  What version of the reprap firmware are you running? I am / was having the same "phase A" problem you have, but on the extruder stepper drive(s). Replaced the cabling and stepper motor with known good units and tried both E0 & E1 stepper drivers on my DuetWiFi board.
                  I made the mistake of doing multiple simultaneous upgrades to my delta printer without incrementally testing the changes. While I was waiting on a Zesty Nimble extruder I tore down my delta printer and upgraded the firmware on the DuetWiFi from version 1.19.2 to version 2.03 (also tried 2.04RC1) and on the PanelDue from version 1.17 to version 1.22.1 while I was waiting. Now I get / got the same "phase A" error with both sets of wiring, stepper motors or stepper drivers.
                  Managed to downgrade the firmware on the DuetWifi to 1.21 with some difficulty(?)
                  Firmware Version: 1.21 (2018-03-21)
                  WiFi Server Version: 1.23
                  Web Interface Version: 1.21
                  Completed more testing and with version 1.21 I do not get "phase A" errors on either E0(Drive 3) or E1(Drive 4) stepper drivers with previously good Titan Aero wiring & motor. Re-tested again with the wiring and stepper motor I ordered to go with the Zesty nimble and again there are no "phase A" errors, even driving the extruder to the point where it starts chewing the filament. (The Zesty Nimble has a fixed drive "tension".)
                  At this point (at least to me,) the problem seems to reside in the version 2.0+ firmware. Which is a shame as Christian Hammacher's new Duet web control 2 interface which works with it is really nice. I haven't been able to run it with RepRapFirmware version 1.21.
                    Please post a link to the specification for your stepper motors you were using when you had the warning messages, and tell us what motor current you had set.
                    The "motor open circuit" warning is new in recent firmware versions. We are aware that it is unreliable in some situations, which is why it is disabled at low motor current settings.
                    • HarveySundefined
                      HarveyS
                      I had the same problem with the e3d stepper motor supplied with my Titan Aero (Genuine) extruder and the stepper motor I ordered to use with the new Zesty Nimble.
                      Titan Aero supplied stepper motor - P/N MT1703HSM168RE Current set to 1000ma.
                      Ordered for the Zesty Nimble:
                      Stepperonline - P/N 70HS10-0704S Current (set to various values) up to 700ma. "phase A" errors at all values.
                      0_1567974400991_Stepper-Motor_MT1703HSM168RE.pdf
                      0_1567974463817_StepperMotor_70HS10-0704S.pdf
                      (Made many successful prints with the Titan Aero on RRF version 1.19.2 before starting the updates.)
                      • keithundefined
                        keith @dc42
                        NEMA 17.
                        1.8° Step Angle.
                        200 Steps Per Revolution.
                        1A Phase.
                        0.48Nm Holding Torque.
                        40mm Body.
                        19mm Output Shaft (5mm diameter)
                        750mm wire lead with Molex connector
                        Motor current set to .8 amp.
                        I think I have it sorted out. One of the wires in the cable has a short. I cut the connectors off and checked the wires without any connectors which is surprising considering the Y axis motor and motor wires never move. I might expect a wire to wear down on something like the direct drive motor over time but not the Y axis. Seems to be working now with a new cable. What Molex connectors are these? I want to order some backup connectors.
                          Phaedrux Moderator @keith
                          @keith said in motor phase A may be disconnected reported by driver(s) 1:
                          https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers
                          • keithundefined
                            keith @Phaedrux
                            @phaedrux
                            Thanks phaedrux. BTW it is cartesian I designed for IDEX, I only have one X head setup on it for now though.
                              @keith, I'm glad you solved it.
                              @HarveyS, do you get the error reports only when loading or retracting filament at high speed? Or at low speed?
                              HarveySundefined 1 Reply Last reply Reply Quote 0
                              • HarveySundefined
                                HarveyS @dc42
                                I think its related to speed also. Manual extrusion / retraction with DWC > ~15 mm/s or greater and > 5~ 10 mm length with a Zesty Nimble, e3dv6 hot end with a 0.4 mm nozzle and a 30 W heating element. PLA @ 200 C. Tried Both stepper motors and had basically the same results. The inductance on the 17HS10-704S. is a little higher ~ 5.5 mH and the current rating a little lower, but the e3d stepper motor yields about the same results. (And yes prior to testing I had completed a PID tune and a measured 100m extrusion to set the steps/mm correctly.)
                                When trying to print a real gcode file I get multiple errors and the filament basically retracts right up out of the nimble even though retractions were set to 1 mm. Now the strangeness. After aborting a print I sometimes had something strange occur. It looks / acts like the direction of the stepper was reversed afterwards(!) and I had to cycle power on the printer to recover... (Weird right?)
                                Just for the heck of it I have a 17HS08-1004 (~$8) on order that others have reported to work correctly ( 4 mH, 1000 ma rating, and lower inertia) when set to 500 ma with the Duet WiFi.
                                • HarveySundefined
                                  HarveyS @HarveyS
                                  @HarveyS
                                  Just a quick reply to myself for anyone reading further on this thread.
                                  Replaced the stepper motor with a 17HS08-1004S, set the current to 500 ma as others have used and low and behold - no phase A disconnect errors with Reprap version 2.04RC1. Even when over driving the extruder to the point where it chews filament, so problem solved. Now I can go on and start tuning / tweaking my slicer settings for best prints.
                                  Thanks everyone.....
                                    Thanks for the update. I think the issue is that fast retractions using a highly-geared extruder such as the Nimble require high motor speeds. I see that Trinamic says on one of their recent datasheets that open load detection shouldn't be relied on at high speeds. So in the next firmware version I'll set an upper speed limit for open load detection, in addition to the existing lower speed limit.
                                    • HarveySundefined
                                      HarveyS @dc42
                                      Good to know. I also think that the detection is also sensitive to the resistance & inductance of the stepper motor. There was nothing really wrong with the wiring or the original stepper motor I tried(Or the e3d one from my Titan Aero.). With a nimble we wind up with ~2700 steps/mm or ~40K steps/sec at 15 mm/sec which I've been told is about the max. theoretical for an e3dv6 with a 0.4 mm nozzle. (And I don't think with the nimble we can do that for more than short bursts.) Continuous or long duration extrusion on my rig the max is more in the ~10 mm/sec range(Maybe ~12 mm.sec). Can you post a link to the latest documentation for the Trinamic driver?
                                        T3P3Tony administrators @HarveyS
                                        @HarveyS https://www.trinamic.com/products/integrated-circuits/details/tmc2660-pa/
