    Think its broken...
    1.4k
    • Shaunundefined
      Shaun
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
      Used output buffers: 1 of 24 (24 max)
      Static ram: 25680
      Dynamic ram: 93644 of which 0 recycled
      Exception stack ram used: 304
      Never used ram: 11444
      Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3844) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:06:45 ago, cause: reset button or watchdog
      Last software reset at 2019-09-11 08:23, reason: User, spinning module GCodes, available RAM 11436 bytes (slot 2)
      Error status: 4
      Free file entries: 10
      MCU temperature: min 35.3, current 36.4, max 36.5
      Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 816394668
      Slowest loop: 100.03ms; fastest: 0.06ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === DDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "m122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 200.84ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is changing mode
        WiFi module is idle
        Failed to get WiFi status
        ok
        Error retrieving WiFi status message: bad reply format version
        WiFi module is idle
        Failed to change WiFi mode (code -4)
      themelleundefined 1 Reply Last reply Reply Quote 0
      • Shaunundefined
        Shaun
        m122
        Static ram: 25680
        Dynamic ram: 93688 of which 0 recycled
        Never used ram: 11400
        Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3744) IDLE(ready,160)
        Owned mutexes:
        Last reset 00:09:54 ago, cause: reset button or watchdog
        Error status: 4
        MCU temperature: min 36.0, current 36.4, max 36.5
        Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
        Cache data hit count 1195047035
        Slowest loop: 1.08ms; fastest: 0.06ms
        === DDARing ===
        Segments left: 0
        === Network ===
        Slowest loop: 1.95ms; fastest: 0.00ms
        • WiFi -
          WiFi module is trying to connect
          WiFi firmware version 1.23
          WiFi MAC address 84:f3:eb:41:4e:f8
          WiFi Vcc 3.40, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 26240
          ok
          Have you tried re-flashing the WiFi firmware?
          Shaunundefined 1 Reply Last reply Reply Quote 0
          • Shaunundefined
            Shaun @dc42
            @dc42 said in Think its broken...:
            DC i have, all went through fine. Was one of the 1st threads i read on here where you suggested that.
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
            • Shaunundefined
              Shaun
              This doesn't look healthy or right to me.
              m552 s0
              ok
              m552
              WiFi module is changing mode
              ok
              WiFi reported error: Timed out while trying to connect to Spiffy
              WiFi module is idle
                T3P3Tony administrators @Shaun
                @Shaun on this thread:
                https://forum.duet3d.com/post/107352
                It appeared that you were at the point where the wifi module was working. what changed since then?
                Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
                • Shaunundefined
                  Shaun @T3P3Tony
                  @T3P3Tony said in Think its broken...:
                  Thats just it, i started checking the settings as per the links sent to me when i lost connection to the web console. Wifi light was then slowly flashing on and off. Thought it was my router and checked everything. Eventually plugged the board into my PC and ran some checks. The researched the errors on the forums and tried everything i could. Nothing worked, wifi kept saying changing mode. ive posted the outputs and ive now even re-installed the firmware and the WiFi. Nothing seems to change.
                  Im happy to try anything else you want to throw my way.
                    What do you currently have in your config.g?
                    • Shaunundefined
                      Shaun
                      Still getting an error
                      m552
                      WiFi module is idle
                      ok
                      m122
                      Static ram: 25680
                      Exception stack ram used: 288
                      Never used ram: 11416
                      Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
                      Owned mutexes:
                      Last reset 00:09:08 ago, cause: software
                      Error status: 4
                      MCU temperature: min 36.5, current 37.1, max 37.3
                      Cache data hit count 1085375973
                      Slowest loop: 1.10ms; fastest: 0.06ms
                      === DDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 2.02ms; fastest: 0.00ms
                      • WiFi -
                        Network state is running
                        WiFi module is idle
                        ok
                        m552
                        WiFi module is idle
                        ok
                      • Shaunundefined
                        Shaun @Phaedrux
                        @Phaedrux said in Think its broken...:
                        ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time)
                        M550 P"CR10" ; set printer name
                        M350Z16 I0 ; configure microstepping without interpolation
                        M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                        M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X300 Y300 Z400 S0 ; set axis maxima
                        M574 X1 Y1 Z1 S1 ; set active high endstops
                        M574 Z1 S3 ; set endstops controlled by motor stall detection
                        M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
                        G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
                        M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                          Phaedrux Moderator @Shaun
                          @Shaun said in Think its broken...:
                          Unrelated, but you're missing a space between the M350 and the axis letter.
                          I understand the frustration. Let's see if we can nail down the issue.
                          The config looks ok.
                          Can you send M587 by itself to get a list of saved SSIDs? This will confirm that the SSID has been properly added.
                          The error message network scan failed would indicate that it's unable to identify a network SSID in range to connect to and it's given up. In your other thread we did identify that the signal strength was rather weak. In order to diagnose if this is in fact the case, I suggest temporarily relocating the wireless access point or the printer so that they are both in close proximity with very little obstruction and seeing if you can then in fact connect.
                          • Shaunundefined
                            Shaun @Phaedrux
                            Remembered networks:
                            Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                            ok
                            Signal is 100%
                            How do i clear any config for network. maybe a clean slate would be a good idea.
                            • Shaunundefined
                              Shaun
                              I have redone the config.
                              ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 09:04:56 GMT+0100 (British Summer Time)
                              M552 S0 ; enable network
                              M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M106 P0 S0 I0 F300 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M106 P1 S0 I0 F300 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                                From the previous thread:
                                From the console can you please send the following:
                                M552 S0
                                M588 S"*"
                                M587 s"Spiffy" p"Password1"
                                M552 S1
                                M122
                                This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
                                • Shaunundefined
                                  Shaun @Phaedrux
                                  M552 S0
                                  M588 S"*"
                                  M552 S1
                                  M122
                                  I’ve done all of that, same problem. Ill set up my old router tonight and see if I can connect to that. Just in case it’s my current router.
                                  • themelleundefined
                                    themelle @Shaun
                                    Is it just me or are those 1.6-1.8V VIN indeed usable? 😮
                                      T3P3Tony administrators @themelle
                                      @themelle if just powering off USB (fine for WIFI tests) you don't need VIN
                                      • themelleundefined
                                        themelle @T3P3Tony
                                        @T3P3Tony Ah ok, I see 🙂
                                        (I thought powering off USB would show up as VIN around 5V)
                                        Thanks for clarifying!
                                        • Shaunundefined
                                          Shaun
                                          OK so ive done the following.
                                          Changed WiFi SID, no change
                                          Changed WiFi Password. no change
                                          Tried old router, no change
                                          I get the same result each time.
                                          Used output buffers: 1 of 24 (10 max)
                                          Static ram: 25680
                                          Exception stack ram used: 256
                                          Never used ram: 11492
                                          Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3808) IDLE(ready,160)
                                          Owned mutexes:
                                          Last reset 00:08:56 ago, cause: power up
                                          Error status: 0
                                          MCU temperature: min 34.9, current 35.9, max 36.1
                                          Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                                          Cache data hit count 1062453510
                                          Slowest loop: 46.87ms; fastest: 0.06ms
                                          === DDARing ===
                                          Segments left: 0
                                          === Network ===
                                          Slowest loop: 77.22ms; fastest: 0.00ms
                                          • WiFi -
                                            WiFi Vcc 3.39, reset reason Hardware watchdog
                                            WiFi flash size 4194304, free heap 26560
                                            ok
                                          I am now totally exhausted.
                                          • Shaunundefined
                                            Shaun
                                            Did i mention that im also getting this.....
                                            Failed to change WiFi mode (code -7)
                                            m587
                                            M587: Failed to retrieve network list
                                            ok
