    Think its broken...
    1.4k
      T3P3Tony administrators @Shaun
      @Shaun on this thread:
      https://forum.duet3d.com/post/107352
      It appeared that you were at the point where the wifi module was working. what changed since then?
      Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
      Shaunundefined 1 Reply Last reply Reply Quote 0
      • Shaunundefined
        Shaun @T3P3Tony
        @T3P3Tony said in Think its broken...:
        Thats just it, i started checking the settings as per the links sent to me when i lost connection to the web console. Wifi light was then slowly flashing on and off. Thought it was my router and checked everything. Eventually plugged the board into my PC and ran some checks. The researched the errors on the forums and tried everything i could. Nothing worked, wifi kept saying changing mode. ive posted the outputs and ive now even re-installed the firmware and the WiFi. Nothing seems to change.
        Im happy to try anything else you want to throw my way.
          What do you currently have in your config.g?
          • Shaunundefined
            Shaun
            Still getting an error
            m552
            WiFi module is idle
            ok
            m122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
            Used output buffers: 1 of 24 (24 max)
            Static ram: 25680
            Dynamic ram: 93688 of which 0 recycled
            Exception stack ram used: 288
            Never used ram: 11416
            Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:09:08 ago, cause: software
            Last software reset at 2019-09-11 08:23, reason: User, spinning module GCodes, available RAM 11436 bytes (slot 2)
            Error status: 4
            Free file entries: 10
            MCU temperature: min 36.5, current 37.1, max 37.3
            Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Cache data hit count 1085375973
            Slowest loop: 1.10ms; fastest: 0.06ms
            Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
            === DDARing ===
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "m122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 2.02ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is running
              WiFi module is idle
              Failed to get WiFi status
              ok
              Error retrieving WiFi status message: bad reply format version
              m552
              WiFi module is idle
              ok
            • Shaunundefined
              Shaun @Phaedrux
              @Phaedrux said in Think its broken...:
              ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time)
              M550 P"CR10" ; set printer name
              M350Z16 I0 ; configure microstepping without interpolation
              M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
              M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X300 Y300 Z400 S0 ; set axis maxima
              M574 X1 Y1 Z1 S1 ; set active high endstops
              M574 Z1 S3 ; set endstops controlled by motor stall detection
              M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
              G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
              M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
                Phaedrux Moderator @Shaun
                @Shaun said in Think its broken...:
                Unrelated, but you're missing a space between the M350 and the axis letter.
                I understand the frustration. Let's see if we can nail down the issue.
                The config looks ok.
                Can you send M587 by itself to get a list of saved SSIDs? This will confirm that the SSID has been properly added.
                The error message network scan failed would indicate that it's unable to identify a network SSID in range to connect to and it's given up. In your other thread we did identify that the signal strength was rather weak. In order to diagnose if this is in fact the case, I suggest temporarily relocating the wireless access point or the printer so that they are both in close proximity with very little obstruction and seeing if you can then in fact connect.
                • Shaunundefined
                  Shaun @Phaedrux
                  Remembered networks:
                  Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                  ok
                  Signal is 100%
                  How do i clear any config for network. maybe a clean slate would be a good idea.
                  • Shaunundefined
                    Shaun
                    I have redone the config.
                    ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 09:04:56 GMT+0100 (British Summer Time)
                    M552 S0 ; enable network
                    M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M106 P0 S0 I0 F300 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P1 S0 I0 F300 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                      From the previous thread:
                      From the console can you please send the following:
                      M552 S0
                      M588 S"*"
                      M587 s"Spiffy" p"Password1"
                      M552 S1
                      M122
                      This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
                      • Shaunundefined
                        Shaun @Phaedrux
                        M552 S0
                        M588 S"*"
                        M552 S1
                        M122
                        I’ve done all of that, same problem. Ill set up my old router tonight and see if I can connect to that. Just in case it’s my current router.
                        • themelleundefined
                          themelle @Shaun
                          Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                          Is it just me or are those 1.6-1.8V VIN indeed usable? 😮
                            T3P3Tony administrators @themelle
                            @themelle if just powering off USB (fine for WIFI tests) you don't need VIN
                            themelleundefined 1 Reply Last reply Reply Quote 0
                            • themelleundefined
                              themelle @T3P3Tony
                              @T3P3Tony Ah ok, I see 🙂
                              (I thought powering off USB would show up as VIN around 5V)
                              Thanks for clarifying!
                              • Shaunundefined
                                Shaun
                                OK so ive done the following.
                                Changed WiFi SID, no change
                                Changed WiFi Password. no change
                                Tried old router, no change
                                I get the same result each time.
                                Used output buffers: 1 of 24 (10 max)
                                Static ram: 25680
                                Dynamic ram: 93644 of which 0 recycled
                                Exception stack ram used: 256
                                Never used ram: 11492
                                Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3808) IDLE(ready,160)
                                Owned mutexes:
                                Last reset 00:08:56 ago, cause: power up
                                Error status: 0
                                MCU temperature: min 34.9, current 35.9, max 36.1
                                Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                                Cache data hit count 1062453510
                                Slowest loop: 46.87ms; fastest: 0.06ms
                                === DDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 77.22ms; fastest: 0.00ms
                                • WiFi -
                                  Network state is changing mode
                                  WiFi module is trying to connect
                                  WiFi firmware version 1.23
                                  WiFi MAC address 84:f3:eb:41:4e:f8
                                  WiFi Vcc 3.39, reset reason Hardware watchdog
                                  WiFi flash size 4194304, free heap 26560
                                  ok
                                I am now totally exhausted.
                                • Shaunundefined
                                  Shaun
                                  Did i mention that im also getting this.....
                                  Failed to change WiFi mode (code -7)
                                  m587
                                  M587: Failed to retrieve network list
                                  ok
                                    A Former User
                                    Are you powering the board off USB now? If so what type of USB power supply are you using, could be its insufficient current from USB as the ESP8266 wifi module is somewhat power hungry.
                                      T3P3Tony administrators @A Former User
                                      @bearer don't think its that in this case, the ESP is reporting >3.3V VCC.
                                      @Shaun thanks for the thorough investigation. What is not clear is if this is conducted from where it previously worked, or in your printer.
                                      Nevertheless we should arrange a replacement, and test this board. Please can you submit a warranty request and reference this forum topic.
                                      https://www.duet3d.com/warranty
                                        dc42 administrators @Shaun
                                        @dc42 said in Think its broken...:
                                        Have you tried re-flashing the WiFi firmware?
                                        DC i have, all went through fine. Was one of the 1st threads i read on here where you suggested that.
                                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                                        That doesn't say anything about the WiFi firmware version. If you already have DuetWiFiServer.bin in /sys and it is dated this year, you can just send M997 S1 to re-install it (even better, download a fresh copy from https://github.com/dc42/RepRapFirmware/releases/tag/2.03). Preferably, send that command from PanelDue or from a PC running YAT, then you can watch the progress and verify that it completes successfully.
                                        If you have already done this, no need to do it again, fill in the warranty form. The hardware watchdog reset message in the M122 report suggests either corrupt firmware or faulty hardware.
                                        • Danalundefined
                                          Danal
                                          Board swap is on the table form Duet... and may be a good idea... just to possibly avoid the time/hassle, try hooking up VIN (in addition to USB) to a solid 12V or more supply, and re-flash wifi firmware, and re-test, with that power hooked up.
                                          These guys know MUCH more than I... but... something is just itching my brain about power, flash, wifi module, etc, etc, etc. Probably I'm wrong, but it is something quick to try, before getting into a full board swap.
                                          Shaunundefined 1 Reply Last reply Reply Quote 1
                                          • Shaunundefined
                                            Shaun @dc42
                                            Hi
                                            Ive actually re-installed the firmware, wifi and web a nuber of times in an attempt to get this working.
