    Think its broken...
    1.4k
      Have you tried re-flashing the WiFi firmware?
      Shaunundefined 1 Reply Last reply Reply Quote 0
      • Shaunundefined
        Shaun @dc42
        @dc42 said in Think its broken...:
        DC i have, all went through fine. Was one of the 1st threads i read on here where you suggested that.
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
        • Shaunundefined
          Shaun
          This doesn't look healthy or right to me.
          m552 s0
          ok
          m552
          WiFi module is changing mode
          ok
          WiFi reported error: Timed out while trying to connect to Spiffy
          WiFi module is idle
          Error retrieving WiFi status message: bad reply format version
            T3P3Tony administrators @Shaun
            @Shaun on this thread:
            https://forum.duet3d.com/post/107352
            It appeared that you were at the point where the wifi module was working. what changed since then?
            Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
            • Shaunundefined
              Shaun @T3P3Tony
              @T3P3Tony said in Think its broken...:
              Thats just it, i started checking the settings as per the links sent to me when i lost connection to the web console. Wifi light was then slowly flashing on and off. Thought it was my router and checked everything. Eventually plugged the board into my PC and ran some checks. The researched the errors on the forums and tried everything i could. Nothing worked, wifi kept saying changing mode. ive posted the outputs and ive now even re-installed the firmware and the WiFi. Nothing seems to change.
              Im happy to try anything else you want to throw my way.
                What do you currently have in your config.g?
                • Shaunundefined
                  Shaun
                  Still getting an error
                  m552
                  WiFi module is idle
                  ok
                  m122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
                  Used output buffers: 1 of 24 (24 max)
                  Static ram: 25680
                  Dynamic ram: 93688 of which 0 recycled
                  Exception stack ram used: 288
                  Never used ram: 11416
                  Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
                  Owned mutexes:
                  Last reset 00:09:08 ago, cause: software
                  Last software reset at 2019-09-11 08:23, reason: User, spinning module GCodes, available RAM 11436 bytes (slot 2)
                  Error status: 4
                  Free file entries: 10
                  MCU temperature: min 36.5, current 37.1, max 37.3
                  Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                  Driver 0: ok, SG min/max not available
                  Driver 1: ok, SG min/max not available
                  Driver 2: ok, SG min/max not available
                  Driver 3: ok, SG min/max not available
                  Driver 4: ok, SG min/max not available
                  Cache data hit count 1085375973
                  Slowest loop: 1.10ms; fastest: 0.06ms
                  Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === DDARing ===
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is ready with "m122" in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 2.02ms; fastest: 0.00ms
                  HTTP sessions: 0 of 8
                  • WiFi -
                    Network state is running
                    WiFi module is idle
                    Failed to get WiFi status
                    ok
                    m552
                    WiFi module is idle
                    ok
                  • Shaunundefined
                    Shaun @Phaedrux
                    @Phaedrux said in Think its broken...:
                    ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time)
                    M550 P"CR10" ; set printer name
                    M350Z16 I0 ; configure microstepping without interpolation
                    M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                    M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X300 Y300 Z400 S0 ; set axis maxima
                    M574 X1 Y1 Z1 S1 ; set active high endstops
                    M574 Z1 S3 ; set endstops controlled by motor stall detection
                    M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
                    G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
                    M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                      Phaedrux Moderator @Shaun
                      @Shaun said in Think its broken...:
                      Unrelated, but you're missing a space between the M350 and the axis letter.
                      I understand the frustration. Let's see if we can nail down the issue.
                      The config looks ok.
                      Can you send M587 by itself to get a list of saved SSIDs? This will confirm that the SSID has been properly added.
                      The error message network scan failed would indicate that it's unable to identify a network SSID in range to connect to and it's given up. In your other thread we did identify that the signal strength was rather weak. In order to diagnose if this is in fact the case, I suggest temporarily relocating the wireless access point or the printer so that they are both in close proximity with very little obstruction and seeing if you can then in fact connect.
                      • Shaunundefined
                        Shaun @Phaedrux
                        Remembered networks:
                        Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                        ok
                        Signal is 100%
                        How do i clear any config for network. maybe a clean slate would be a good idea.
                        • Shaunundefined
                          Shaun
                          I have redone the config.
                          ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 09:04:56 GMT+0100 (British Summer Time)
                          M552 S0 ; enable network
                          M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                          M106 P0 S0 I0 F300 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P1 S0 I0 F300 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                            From the previous thread:
                            From the console can you please send the following:
                            M552 S0
                            M588 S"*"
                            M587 s"Spiffy" p"Password1"
                            M552 S1
                            M122
                            This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
                            • Shaunundefined
                              Shaun @Phaedrux
                              M552 S0
                              M588 S"*"
                              M552 S1
                              M122
                              I’ve done all of that, same problem. Ill set up my old router tonight and see if I can connect to that. Just in case it’s my current router.
                              • themelleundefined
                                themelle @Shaun
                                Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                                Is it just me or are those 1.6-1.8V VIN indeed usable? 😮
                                  T3P3Tony administrators @themelle
                                  @themelle if just powering off USB (fine for WIFI tests) you don't need VIN
                                  themelleundefined 1 Reply Last reply Reply Quote 0
                                  • themelleundefined
                                    themelle @T3P3Tony
                                    @T3P3Tony Ah ok, I see 🙂
                                    (I thought powering off USB would show up as VIN around 5V)
                                    Thanks for clarifying!
                                    • Shaunundefined
                                      Shaun
                                      OK so ive done the following.
                                      Changed WiFi SID, no change
                                      Changed WiFi Password. no change
                                      Tried old router, no change
                                      I get the same result each time.
                                      Used output buffers: 1 of 24 (10 max)
                                      Static ram: 25680
                                      Dynamic ram: 93644 of which 0 recycled
                                      Exception stack ram used: 256
                                      Never used ram: 11492
                                      Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3808) IDLE(ready,160)
                                      Owned mutexes:
                                      Last reset 00:08:56 ago, cause: power up
                                      Error status: 0
                                      MCU temperature: min 34.9, current 35.9, max 36.1
                                      Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                                      Cache data hit count 1062453510
                                      Slowest loop: 46.87ms; fastest: 0.06ms
                                      === DDARing ===
                                      Segments left: 0
                                      === Network ===
                                      Slowest loop: 77.22ms; fastest: 0.00ms
                                      • WiFi -
                                        Network state is changing mode
                                        WiFi module is trying to connect
                                        WiFi firmware version 1.23
                                        WiFi MAC address 84:f3:eb:41:4e:f8
                                        WiFi Vcc 3.39, reset reason Hardware watchdog
                                        WiFi flash size 4194304, free heap 26560
                                        ok
                                      I am now totally exhausted.
                                      • Shaunundefined
                                        Shaun
                                        Did i mention that im also getting this.....
                                        Failed to change WiFi mode (code -7)
                                        m587
                                        M587: Failed to retrieve network list
                                        ok
                                          A Former User
                                          Are you powering the board off USB now? If so what type of USB power supply are you using, could be its insufficient current from USB as the ESP8266 wifi module is somewhat power hungry.
                                            T3P3Tony administrators @A Former User
                                            @bearer don't think its that in this case, the ESP is reporting >3.3V VCC.
                                            @Shaun thanks for the thorough investigation. What is not clear is if this is conducted from where it previously worked, or in your printer.
                                            Nevertheless we should arrange a replacement, and test this board. Please can you submit a warranty request and reference this forum topic.
                                            https://www.duet3d.com/warranty
