    Duet 3 Mainboard 6HC - initial production run.
    243
    32.8k
      A Former User @NoSkillzEngineer
      @NoSkillzEngineer said in Duet 3 Mainboard 6HC - initial production run.:
      (4) there's two RJ45 ports on it?? Hmmm, okay, cool.
      Thank you!
      x2 RJ 45 port's ?
      I received mine today and I thought it was an RJ45 & an RJ11
        A Former User
        Should be a RJ45 (8 pin) for Ethernet* and a RJ11 (6pin) for the CAN bus on the production board, but at a glance they look somewhat similar
        *) when used standalone firmware and SD card instead of RaspberryPi
        • JoergS5undefined
          JoergS5
          There was a blog some time ago how to destroy a Duet 2, information how to avoid it. I would find it helpful to have the same information for the new Duet 3: what should one avoid in any case (wrong voltage at pin x/connecting pin x with y, connection cable etc.). It can be a short list which can be print out and hang it over the board while one wires it up. A cheat sheet with a caution list and the Duet 3 board as image with the dangerous places marked red.
          • mundsenundefined
            mundsen
            Does the Duet3/Raspberry support USB Camera (connected to the PI) for integration in the Web interface?
            I have a Logitech 1080P USB camera - possible to use?
            dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
              dc42 administrators @JoergS5
              @JoergS5 said in Duet 3 Mainboard 6HC - initial production run.:
              We've tried to make the Duet 3 even tougher than Duet 2 by including additional protection mechanisms. In particular, it's designed to survive a short between the external +5V and/or +3.3V rails and +24V. But I haven't tested these protection mechanisms yet, because Duet 3 boards are too scarce to risk writing off.
              One thing we didn't include protection against is reverse polarity VIN. So be sure to get the polarity right! If you get it wrong, then the board may survive, depending on the short circuit current of the power supply. I "tested" reverse polarity a couple of weeks ago and the board was OK afterwards.
                dc42 administrators @mundsen
                @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
                I'm not sure whether this is implemented yet, but if not then it certainly will be. We chose a dedicated SPI bus for connecting the Pi to the Duet so as to keep the USB subsystem free for high bandwidth devices such as cameras.
                • mundsenundefined
                  mundsen
                  One more thing - should I get a speaker for my PI? Does the web server use sounds for warnings, autolevel ready..?
                    T3P3Tony administrators @mundsen
                    @mundsen it does not currently
                      A Former User @mundsen
                      @mundsen
                      A quick Google....
                      returned the following result.
                      USB Camera on a Rpi
                      mundsenundefined 1 Reply Last reply Reply Quote 0
                      • mundsenundefined
                        mundsen @A Former User
                        @CaLviNx I know you can use a USB camera in combination with the pi - but the web server need to support/use it to get video in the duet web interface
                        • JoergS5undefined
                          JoergS5 @dc42
                          @dc42 Thank your for your information about what to avoid.
                          • NoSkillzEngineerundefined
                            NoSkillzEngineer
                            Was it an RJ11 port??? Whoops! Clearly I didn't look at it particularly closely 😆
                            My bad!!!
                            • JoergS5undefined
                              JoergS5
                              The Raspberry Pi 4 has an official current supply of 5.1 volt and 3 ampere. According to https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram I can empower it by the 26 pin cable also (the note for the 26 pin header in the diagram), but is it sufficient for the Pi 4 or should I better use the official supply?
                              And if I shall use a separate supply, I suspect I have to connect the grounds?
                              • Dougal1957undefined
                                Dougal1957 @JoergS5
                                Mine is running quite happily of the 26 way cable mind it is only idling at the moment but has been switched on for about 2-3 days constantly
                                • JoergS5undefined
                                  JoergS5 @Dougal1957
                                  @Dougal1957 thank you for confirmation.
                                  • mundsenundefined
                                    mundsen
                                    First initial test
                                    Duet 3 6HC
                                    Raspberry Pi 4 2GB
                                    7 inch 1024x600 capacitive touch LCD
                                    24V PSU
                                    SD card that came with the Duet
                                    All seems to work fine 🙂
                                    Next, I`ll connect steppers, fans, configure WiFi/Ethernet..
                                    • mundsenundefined
                                      mundsen
                                      I got a question about duet 3 and pi - is the code transfered to the duet before the print Job starts or is it controlled real time by the pi during the print?
                                      wilrikerundefined 1 Reply Last reply Reply Quote 1
                                      • gtj0undefined
                                        gtj0
                                        Should the underside of the drivers and mosfets be completely soldered to the board or is there enough contact to dissipate the heat the way they are?
                                        • wilrikerundefined
                                          wilriker @mundsen
                                          It is controlled real time. This also allows to implement plug-ins to do arbitrary modifications while the print is in progress. For example I have implemented a first version of an Object Skipper, i.e. a plug-in that is given the information on how to identify a certain object in the GCode (many slicers put specific comments in the GCodes) and then will filter out any commands related to this object (or multiple).
                                          This allows for a print to continue where you have multiple objects on the platform but printing fails for whatever reason for one of them.
                                          I will probably release this early next week.
                                          Manuel
                                          My Tool Collection
                                          1 Reply Last reply Reply Quote 5
                                            A Former User
                                            Much ❤
                                            @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
                                            Fur example I have implemented a first version of an Object Skipper
