    Duet 3 Mainboard 6HC - initial production run.
    243
    33.3k
      dc42 administrators @JoergS5
      @JoergS5 said in Duet 3 Mainboard 6HC - initial production run.:
      There was a blog some time ago how to destroy a Duet 2, information how to avoid it. I would find it helpful to have the same information for the new Duet 3: what should one avoid in any case (wrong voltage at pin x/connecting pin x with y, connection cable etc.). It can be a short list which can be print out and hang it over the board while one wires it up. A cheat sheet with a caution list and the Duet 3 board as image with the dangerous places marked red.
      We've tried to make the Duet 3 even tougher than Duet 2 by including additional protection mechanisms. In particular, it's designed to survive a short between the external +5V and/or +3.3V rails and +24V. But I haven't tested these protection mechanisms yet, because Duet 3 boards are too scarce to risk writing off.
      One thing we didn't include protection against is reverse polarity VIN. So be sure to get the polarity right! If you get it wrong, then the board may survive, depending on the short circuit current of the power supply. I "tested" reverse polarity a couple of weeks ago and the board was OK afterwards.
        dc42 administrators @mundsen
        @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
        Does the Duet3/Raspberry support USB Camera (connected to the PI) for integration in the Web interface?
        I have a Logitech 1080P USB camera - possible to use?
        I'm not sure whether this is implemented yet, but if not then it certainly will be. We chose a dedicated SPI bus for connecting the Pi to the Duet so as to keep the USB subsystem free for high bandwidth devices such as cameras.
        • mundsenundefined
          mundsen
          One more thing - should I get a speaker for my PI? Does the web server use sounds for warnings, autolevel ready..?
            T3P3Tony administrators @mundsen
            @mundsen it does not currently
              A Former User @mundsen
              @mundsen
              A quick Google....
              returned the following result.
              USB Camera on a Rpi
              mundsenundefined 1 Reply Last reply Reply Quote 0
              • mundsenundefined
                mundsen @A Former User
                @CaLviNx I know you can use a USB camera in combination with the pi - but the web server need to support/use it to get video in the duet web interface
                • JoergS5undefined
                  JoergS5 @dc42
                  @dc42 Thank your for your information about what to avoid.
                  • NoSkillzEngineerundefined
                    NoSkillzEngineer
                    Was it an RJ11 port??? Whoops! Clearly I didn't look at it particularly closely 😆
                    My bad!!!
                    • JoergS5undefined
                      JoergS5
                      The Raspberry Pi 4 has an official current supply of 5.1 volt and 3 ampere. According to https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram I can empower it by the 26 pin cable also (the note for the 26 pin header in the diagram), but is it sufficient for the Pi 4 or should I better use the official supply?
                      And if I shall use a separate supply, I suspect I have to connect the grounds?
                      • Dougal1957undefined
                        Dougal1957 @JoergS5
                        Mine is running quite happily of the 26 way cable mind it is only idling at the moment but has been switched on for about 2-3 days constantly
                        • JoergS5undefined
                          JoergS5 @Dougal1957
                          @Dougal1957 thank you for confirmation.
                          • mundsenundefined
                            mundsen
                            First initial test
                            Duet 3 6HC
                            Raspberry Pi 4 2GB
                            7 inch 1024x600 capacitive touch LCD
                            24V PSU
                            SD card that came with the Duet
                            All seems to work fine 🙂
                            Next, I`ll connect steppers, fans, configure WiFi/Ethernet..
                            • mundsenundefined
                              mundsen
                              I got a question about duet 3 and pi - is the code transfered to the duet before the print Job starts or is it controlled real time by the pi during the print?
                              wilrikerundefined 1 Reply Last reply Reply Quote 1
                              • gtj0undefined
                                gtj0
                                Should the underside of the drivers and mosfets be completely soldered to the board or is there enough contact to dissipate the heat the way they are?
                                • wilrikerundefined
                                  wilriker @mundsen
                                  It is controlled real time. This also allows to implement plug-ins to do arbitrary modifications while the print is in progress. For example I have implemented a first version of an Object Skipper, i.e. a plug-in that is given the information on how to identify a certain object in the GCode (many slicers put specific comments in the GCodes) and then will filter out any commands related to this object (or multiple).
                                  This allows for a print to continue where you have multiple objects on the platform but printing fails for whatever reason for one of them.
                                  I will probably release this early next week.
                                  Manuel
                                  My Tool Collection
                                  1 Reply Last reply Reply Quote 5
                                    A Former User
                                    Much ❤
                                    @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
                                    Fur example I have implemented a first version of an Object Skipper
                                      dc42 administrators @gtj0
                                      @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
                                      The connectors should be soldered, but not the thermal vias under the stepper drivers and mosfets.
                                      • gtj0undefined
                                        gtj0
                                        So the partially filled vias are OK?
                                          Yes.
                                          • Cataundefined
                                            Cata
                                            Will there be a variant that does not use a raspberry?
