    Duet 3 Mainboard 6HC - initial production run.
    243
    33.4k
      T3P3Tony administrators @mundsen
      @mundsen it does not currently
        A Former User @mundsen
        @mundsen
        A quick Google....
        returned the following result.
        USB Camera on a Rpi
        mundsenundefined 1 Reply Last reply Reply Quote 0
        • mundsenundefined
          mundsen @A Former User
          @CaLviNx I know you can use a USB camera in combination with the pi - but the web server need to support/use it to get video in the duet web interface
          • JoergS5undefined
            JoergS5 @dc42
            @dc42 Thank your for your information about what to avoid.
            • NoSkillzEngineerundefined
              NoSkillzEngineer
              Was it an RJ11 port??? Whoops! Clearly I didn't look at it particularly closely 😆
              My bad!!!
              • JoergS5undefined
                JoergS5
                The Raspberry Pi 4 has an official current supply of 5.1 volt and 3 ampere. According to https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram I can empower it by the 26 pin cable also (the note for the 26 pin header in the diagram), but is it sufficient for the Pi 4 or should I better use the official supply?
                And if I shall use a separate supply, I suspect I have to connect the grounds?
                • Dougal1957undefined
                  Dougal1957 @JoergS5
                  @JoergS5 said in Duet 3 Mainboard 6HC - initial production run.:
                  Mine is running quite happily of the 26 way cable mind it is only idling at the moment but has been switched on for about 2-3 days constantly
                  • JoergS5undefined
                    JoergS5 @Dougal1957
                    @Dougal1957 thank you for confirmation.
                    • mundsenundefined
                      mundsen
                      First initial test
                      Duet 3 6HC
                      Raspberry Pi 4 2GB
                      7 inch 1024x600 capacitive touch LCD
                      24V PSU
                      SD card that came with the Duet
                      All seems to work fine 🙂
                      Next, I`ll connect steppers, fans, configure WiFi/Ethernet..
                      • mundsenundefined
                        mundsen
                        I got a question about duet 3 and pi - is the code transfered to the duet before the print Job starts or is it controlled real time by the pi during the print?
                        wilrikerundefined 1 Reply Last reply Reply Quote 1
                        • gtj0undefined
                          gtj0
                          Should the underside of the drivers and mosfets be completely soldered to the board or is there enough contact to dissipate the heat the way they are?
                          • wilrikerundefined
                            wilriker @mundsen
                            @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
                            It is controlled real time. This also allows to implement plug-ins to do arbitrary modifications while the print is in progress. For example I have implemented a first version of an Object Skipper, i.e. a plug-in that is given the information on how to identify a certain object in the GCode (many slicers put specific comments in the GCodes) and then will filter out any commands related to this object (or multiple).
                            This allows for a print to continue where you have multiple objects on the platform but printing fails for whatever reason for one of them.
                            I will probably release this early next week.
                            Manuel
                            My Tool Collection
                            1 Reply Last reply Reply Quote 5
                              A Former User
                              Much ❤
                              @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
                              Fur example I have implemented a first version of an Object Skipper
                                dc42 administrators @gtj0
                                @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
                                The connectors should be soldered, but not the thermal vias under the stepper drivers and mosfets.
                                • gtj0undefined
                                  gtj0
                                  So the partially filled vias are OK?
                                    Yes.
                                    • Cataundefined
                                      Cata
                                      Will there be a variant that does not use a raspberry?
                                      • gtj0undefined
                                        gtj0 @Cata
                                        @Cata said in Duet 3 Mainboard 6HC - initial production run.:
                                        The current 6HC board has an SD card slot and an ethernet port that allows you to use it in standalone mode.
                                        Cataundefined 1 Reply Last reply Reply Quote 1
                                        • Cataundefined
                                          Cata @gtj0
                                          @gtj0 Thanks, i re-read again the wiki and its fine for my use.
                                          • gtj0undefined
                                            gtj0 @Cata
                                            No worries. There was some talk about the boards not having the SD card holder or the ethernet jack populated at first so there was a little confusion.
