    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.3k
    • Sindariusundefined
      Sindarius
      Not quite yet the code is up on github but I want to add a couple more things. For larger models it does switch to a wire render mode but maintains the colors. More than happy to have it incorporated into the dwc2. I like being able to double check gcode and the colors based on loaded filament.
      • Eumldeumlundefined
        Eumldeuml
        Looks really cool and professional!
        But I have a possibly stupid question (which is by no means intended to talk down your creation): What is this used for when there's a layer preview in the slicer? For production runs to check whether you selected the right file?
        Sindariusundefined 1 Reply Last reply Reply Quote 0
        • robmundefined
          robm
          Would be especially nice if can link to current layer being printed.
          • john parkundefined
            john park @Sindarius
            @sindarius Whoa... awesome !!
            • Nuramoriundefined
              Nuramori
              This is the only thing I was missing from octoprint. Having the gcode viewer would close the door on my need for it. .
                Sindarius @robm
                @robm That's something I am looking at adding later, my main concern was making sure that I could get a good view working.
                  Sindarius @Eumldeuml
                  @eumldeuml I do a lot of multi-material & color mixing printing and one of the biggest problems I have is knowing how the extruders or m567 was setup on the print. Also this gives me the opportunity to setup the filament colors on each of the extruders to get an approximation of what the final result will roughly look. The code I wrote supports T# tool changes and M567 extruder %'s. Beyond that sometimes it's nice to see what you're about to print 🙂
                  Eumldeumlundefined 1 Reply Last reply Reply Quote 1
                    Eumldeuml @Sindarius
                    @sindarius I understand! Sounds very practical for your purposes 🙂
                    • TLASundefined
                      TLAS
                      Great implementation, well done.
                      Gave me a though I might start another thread in - why not incorporate a slicer in at this point? You’ve got the 3D viewer, and on a pi, you could fairly easily run a slic3r program in the background from the server.
                      Thoughts?
                      • JimPBarberundefined
                        JimPBarber
                        That is too awesome! Yes, Yes, Yes.....
                          Sindarius
                          I have a branch set up here for anyone interested in playing with this.
                          https://github.com/Sindarius/DuetWebControl/tree/3DViewer
                          and you can download a test version from here
                          https://juan-rosario.com/DuetWebControl.zip
                          I brought this up to date with the new master.
                          • JoergS5undefined
                            JoergS5
                            This is really great, please keep going!
                              Sindarius
                              I've been playing around with the code a little bit while I wait for a plugin system to be put in place. Recently added the ability to change the bed size and have the release on GitHub for anyone who wants to play with this. I use it fairly often at this point.
                              https://github.com/Sindarius/DuetWebControl/releases
                              hestiahuangundefined 1 Reply Last reply Reply Quote 3
                                Sindarius
                                Forgot to mention that I am looking at adding a toggle to move the layer height slider based off the current print height this weekend hopefully.
                                • Exerqtorundefined
                                  Exerqtor
                                  Awesome! This is getting installed right after the ongoing print is done for sure!
                                  Hope it get's integrated to the master asap!
                                  • AS-3D Druckundefined
                                    AS-3D Druck
                                    This is awesome
                                    Is this Client or DWC based?
                                    Best regards
                                    AS-3D Druck / Andre
                                      Sindarius @AS-3D Druck
                                      @AS-3D-Druck this is DWC based. Opens a new browser window to launch the 3D viewer but no special installation beyond the branch I have with it integrated.
                                      AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
                                        AS-3D Druck @Sindarius
                                        @Sindarius Ok, what i tryed to say is does it get calculated by a Script on the Client or Duet Side?
                                        Best regards
                                        AS-3D Druck / Andre
                                          @AS-3D-Druck it’s javascript based so it is client side. The viewer downloads the file and renders it.
                                          AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                                            @Sindarius Cool so it can be used even during a print Job right?
                                            (without negative effecting the print Job)
                                            Best regards
                                            AS-3D Druck / Andre
