Duet Web Control 2.0 released
Duet Web Control
12
22
1.7k
    smoki3
    I see today chrishamm released DWC 2.0.
    https://github.com/chrishamm/DuetWebControl/releases
    Whats the difference between the SD and the SBC version?
      kraegar
      SD runs on the duet itself (like on a duet2). The SBC runs on a pi, like when paired with the duet3.
        littlehobbyshop
        This is very nice, I like the modern layout with the burger menu and collapsible categories.
        Quick access to the height map is good too.
        The dark mode is great but personally I think the blue text could do with being a little brighter:
        Maybe it's just me.
        BLV MGN Cube w/Hemera, K8200, Sunlu S8
        undefined 1 Reply Last reply 2 Oct 2019, 00:10 Reply Quote 0
          NeoandGeo @littlehobbyshop
          @littlehobbyshop said in Duet Web Control 2.0 released:
          Maybe it's just me.
          A bold white font would be ideal, imo. Is there any way to change the color/size?
            chas2706
            Nice to see some bugs ironed out but still annoying that copy and paste still does not work! Cant copy gcode from one file to another.
            undefined 1 Reply Last reply 4 Oct 2019, 07:19 Reply Quote 0
              DeltaCon @chas2706
              @chas2706 said in Duet Web Control 2.0 released:
              Try 2 instances / tabs of the interface?
              I fail to see why you can't copy from a browser tab to the clipboard and copy back to the same tab. In fact, I am pretty sure I do that regularly without thinking about it (just to make commented-out backup lines of things I change).
              If you think trial and error is dangerous, try routine. That's even more so!
                DeltaCon
                Is this a Duet3 only thing or wil it work on my 0.6 as well?
                  burtoogle
                  The 2.0.0 release seems to have removed the "Print Another" button. Why is that?
                  undefined 1 Reply Last reply 4 Oct 2019, 11:48 Reply Quote 0
                    chas2706
                    @DeltaCon In DWC1 I can open a macro for instance, copy some selected content by individually highlighting it and then paste it into a new macro.
                    In any version of DWC2 I can not do this. The content I wish to copy will not individually highlight.
                    I don't know why you fail to see.
                    If I right click on the page, the options I get are:
                    Paste
                    Select All
                    Print
                    Read Aloud
                    Selecting Select All highlights everything then right clicking I can select Copy.
                    I can then paste everything into the new macro but I only want to copy selections that I needed to highlight not the hole lot.
                    undefined undefined undefined 3 Replies Last reply 4 Oct 2019, 11:50 Reply Quote 0
                      burtoogle @burtoogle
                      @burtoogle said in Duet Web Control 2.0 released:
                      I should have made clear that this is a change from 2.0.0-RC7, not from 1.22.
                        Dougal1957 @chas2706
                        Paste
                        Select All
                        Print
                        Read Aloud
                        it works ok for me
                          tekkydave @chas2706
                          @chas2706 I have found that sometimes selection doesn't work if dragging from the start of a line. Try starting at the end of the last line you want to select.
                          ~ tekkydave ~
                          D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                          FreeCAD, PrusaSlicer
                          undefined 1 Reply Last reply 4 Oct 2019, 11:52 Reply Quote 0
                            Dougal1957 @tekkydave
                            @tekkydave said in Duet Web Control 2.0 released:
                            that could well be it as that is the way I always do it.
                              chas2706
                              Oh right. No bug then you just have to select backwards.
                                tekkydave
                                No bug as far as I can tell. I've just tested it on my Duet2 using DWC V2.0. It just seems very fussy about where you click to start the selection. If you start in the margin area to the left of the first character the selection doesn't work. If you are spot on the first character it works as expected. It is sometimes easier to select backwards then you don't need to be so accurate with your mouse positioning.
                                ~ tekkydave ~
                                  T3P3Tony administrators
                                  @chrishamm I think it would be a good idea if we could increase the margins for cut and paste. I also get a bit frustrated by not being able to select from the left of the first character in a line unless i am very careful with mouse positioning.
                                    chas2706
                                    @T3P3Tony Thanks for recognising this. It is frustrating and I don't like backward highlighting!
                                    BTW when you do scroll backwards the DWC is not fussy at all where you start!
                                    undefined 1 Reply Last reply 4 Oct 2019, 12:47 Reply Quote 0
                                      T3P3Tony administrators @chas2706
                                      @chas2706 yep, its just the margin settings in that box are too strict.
                                      • Nuramoriundefined
                                        Nuramori
                                        I'm not entirely sure it's related, or would be, but I'll ask just to make sure. Since updating, I am having connection issues with my network. The update is the only thing that has changed, nothing in terms of my printer has been modified that may contribute to the error. My network checks out, and also hasn't changed.
                                        My network DOES now show that the connection to the printer has a high level of WiFi retries, which isn't happening with any of the other devices on the same network. Thoughts in what I can do to try and ascertain the issue and remove the printer or the update as the cultrpit?
                                          DeltaCon @chas2706
                                          Because of the word "still" in your phrase:
                                          I falsly assumed it already did not work for you in DWC 1.x, hence my comment. I have not used DWC 2.x myself so I can't comment on that. I would try DWC with pleasure but I don't know if that is going to be problematic since I use the old Duet 0.6...
                                          DocTruckerundefined 1 Reply Last reply 9 Oct 2019, 06:20 Reply Quote 0
                                          3 out of 22
