    Can't get BL Touch working
    733
      T3P3Tony administrators
      could it be a faulty BL touch?
      • Adam - V3Dundefined
        Adam - V3D
        I guess its a possibility. If the code is all correct, and i'm confident hardware is ok, then there aren't many other options.
        • Vetiundefined
          Veti
          @Adam-V3D said in Can't get BL Touch working:
          the pin also doesnt jump back into the retracted position.
          that tells me there is a problem with your bltouch.
          after issuing the deploy probe a small push on the pin should cause the bltouch to pull up the pin.
            Adam - V3D
            Looks like i'm going to have to try and get a replacement probe then. I feel like that's going to be easier said than done.
            Feeling like this might be my first and last experience with BL touch...
            • Vetiundefined
              Veti
              i am using this as an alternative to the bltouch.
              https://www.thingiverse.com/thing:3303618
                Adam - V3D
                well thats another project added to the list! Thanks.
                • JoergS5undefined
                  JoergS5 @Veti
                  @Veti There is a version 2 of it: https://www.thingiverse.com/thing:3756428
                  Thank you for your information about the thing.
                  • giostarkundefined
                    giostark
                    Please don't shot me if is not related but missing here your bed.g can you try to give a look here:
                    https://forum.duet3d.com/topic/10455/solved-bl-touch-deploy-only-one-time-with-2-03rc1
                    If you have this in your bed.g:
                    M98 Pdeployprobe.g ;
                    Try removing this as stated in that link.
                    • Vetiundefined
                      Veti @giostark
                      @giostark
                      any help that people are trying to give is appreciated.
                      we are here to learn from each other.
                      he stated that
                      When I send G30 the probe deploys but pin contact doesn't trigger, the pin also doesnt jump back into the retracted position.
                      the G30 command however does not execute the bed.g file.
                      The G32 command executes the bed.g.
                      see
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_G32_Probe_Z_and_calculate_Z_plane
                      • Vetiundefined
                        Veti
                        Firmware Version: 2.04RC1 (2019-07-14b1)
                        please update to the latest 2.04RC4. There were some fixes regarding BLtouch V3
                          Adam - V3D
                          Board: Duet WiFi 1.02 or later
                          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC4 (2019-10-19b1)
                          Duet WiFi Server Version: 1.23
                          Updated as above. no change to bltouch functionality
                            Adam - V3D
                            Flipped over the two pins that go to the Z probe header and now it works. Bit odd because i'm sure it was wired correctly.
                            • fcwiltundefined
                              fcwilt @Adam - V3D
                              Glad to hear it's working.
                              But clearly it wasn't wired correctly and is now 😉
