Can't get BL Touch working
733
    Adam - V3D
    When I power up the printer the probe deploys and retracts a couple of times before staying retracted and lit up red. When I send G30 the probe deploys but pin contact doesn't trigger, the pin also doesnt jump back into the retracted position. Notably, the z probe information on the web control never moves away from zero.
    i've tested the cables for continuity from the back of the probe to the control board and connection is just fine.
    deploy command works fine using m401 or M280 P3 S10 I1
    retract command works fine using m402 or M280 P3 S90 I1
    (its connected to pwm heater 3 btw)
    if it helps, i've modifying my firmware from a fully working inductive probe setup so wondering if something i'd configured for that is causing this issue.
    I started with this article: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
    and also went over to this one to double check things. https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
    INFO:
    bltouch v3.1 genuine
    Firmware Version: 2.04RC1 (2019-07-14b1)
    WiFi Server Version: 1.21
    Web Interface Version: 1.22.6
    TIA for any help, this has been driving me up the wall since 10am this morning.
      Veti
      post your config.g
        Adam - V3D
        config.g
          Veti
          @Adam-V3D said in Can't get BL Touch working:
          config looks fine regarding bltouch.
          the z probe information only pulses once very quickly upon triggering with a bltouch. most of the time you will not see it in the ui.
          check the wiring for the z probe pin. a lot of users hard problems with the extension cable and the crimps of the bltouch.
            Adam - V3D
            I did continuity test and seems to be just fine
              T3P3Tony administrators
              could it be a faulty BL touch?
                Adam - V3D
                I guess its a possibility. If the code is all correct, and i'm confident hardware is ok, then there aren't many other options.
                  Veti
                  that tells me there is a problem with your bltouch.
                  after issuing the deploy probe a small push on the pin should cause the bltouch to pull up the pin.
                    Adam - V3D
                    Looks like i'm going to have to try and get a replacement probe then. I feel like that's going to be easier said than done.
                    Feeling like this might be my first and last experience with BL touch...
                      Veti
                      i am using this as an alternative to the bltouch.
                      https://www.thingiverse.com/thing:3303618
                      undefined 1 Reply Last reply 27 Oct 2019, 14:50 Reply Quote 0
                        Adam - V3D
                        well thats another project added to the list! Thanks.
                          JoergS5 @Veti
                          @Veti There is a version 2 of it: https://www.thingiverse.com/thing:3756428
                          Thank you for your information about the thing.
                            giostark
                            Please don't shot me if is not related but missing here your bed.g can you try to give a look here:
                            https://forum.duet3d.com/topic/10455/solved-bl-touch-deploy-only-one-time-with-2-03rc1
                            If you have this in your bed.g:
                            M98 Pdeployprobe.g ;
                            Try removing this as stated in that link.
                            undefined 1 Reply Last reply 27 Oct 2019, 15:26 Reply Quote 0
                              Veti @giostark
                              @giostark
                              any help that people are trying to give is appreciated.
                              we are here to learn from each other.
                              he stated that
                              the G30 command however does not execute the bed.g file.
                              The G32 command executes the bed.g.
                              see
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_G32_Probe_Z_and_calculate_Z_plane
                                Veti
                                please update to the latest 2.04RC4. There were some fixes regarding BLtouch V3
                                  Adam - V3D
                                  Board: Duet WiFi 1.02 or later
                                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC4 (2019-10-19b1)
                                  Duet WiFi Server Version: 1.23
                                  Updated as above. no change to bltouch functionality
                                    Adam - V3D
                                    Flipped over the two pins that go to the Z probe header and now it works. Bit odd because i'm sure it was wired correctly.
                                    fcwiltundefined 1 Reply Last reply 9 Nov 2019, 20:17 Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @Adam - V3D
                                      Glad to hear it's working.
                                      But clearly it wasn't wired correctly and is now 😉
