    New RepRapFirmware config tool
    79
    10.3k
      dc42 administrators @steevebecker
      Please note, the nine IO_ connectors don't all have the same capabilities. I have documented them at https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO. Summary:
      • Don't use IO_0 for now
      • Don't connect an analog Z probe or a BLTouch to IO_0, IO_1 or IO_2
      steevebeckerundefined 1 Reply Last reply Reply Quote 0
      • steevebeckerundefined
        steevebecker @dc42
        @dc42 thanks for this. I need a lot of I/O so it's good to know.
        plant your ideas, water suggestions and questions, collect progress and do great things.
          @steevebecker said in New RepRapFirmware config tool:
          i don't how the .g will be different between duet E vs Duet 3.
          Apart from pin names, the main difference is that there are some default pin assignments for endstops, zprobe and fans in RRF3 for Duet 2, but none in RRF3 for Duet 3. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Default_pin_assignments. So on Duet 2, you may need to use GCode commands to free up some of those pins if you want to use them for something else; whereas on Duet 3 you always need to declare what pins to use for fans, endstops and Z probe.
          PS - I am starting to add Duet 3 pin connections to the documentation pages on wiring. For example, I have already added them to the page on connecting Z probes.
            A Former User @steevebecker
            @smece hi taht could be good as a first step 🙂
            don't know anything about duet3 so can't help there, just recently tried the duet2 myself (was sitting in a drawer for year+, I'm mostly smoothieware user and was delaying duet3d testing as I dislike the structure of RRF source code and I love to tinker with the code, now I'm at a place where with 2 kids time is so darn scarce that I just need something that works and I don't care to tinker if I don't have to so for those type of projects duet looks like ideal solution hence me digging in) and I started out with RRF3 figuring, if I'm diving into it, better start with latest, especially if a lot changed so RRF2 knowledge will have to be scrapped anyhow 😄 ... so hopefully this will help you and not lead you astray
            • XYZ moves, homes..
            • BED, E0, E1 heats
            • E0, E1 extrudes (have not calibrated yet steps but I'm mounting dual flex3drive here so exact steps_per_mm values would not be useful for you anyhow)
            • bltouch works in terms of - deploy, retract, have not yet tested actual probing and mesh compensation since I just designed the holder for flex3drive + bltouch for ender5 so hopefully I'll be testing it today (just printed, hopefully it's properly designed 😄 )
            • have not yet tried actually printing!!!
            config.g
            deployprobe.g
            retractprobe.g
            homey.g
            homex.g
            homeall.g
            homez.g
            super important note to be aware of - I never used duet before, I just mounted it recently on this ender5 and started with RRF3 so while this "moves" and "heats" and "extrudes" I have not yet started printing with it (still working out mount for flex3 drive and waiting on some connectors for hexagon hotends) so make sure these do not lead you astray instead of helping you out!!!!
              steevebecker @A Former User
              @smece Thanks for you time and file, i ll digg in 😉
                you are welcome, I'm sure there's much to be done there so post progress here 😄 so we can both learn from it 😄
                  steevebecker
                  Hi Duet Forum.
                  I have spent 2 days on RRF3 and Duet 3. I was my first hours on it ... It's a pleasure, i like this board. I'm moving from another board + Marlin to this one.
                  Of course it was not so obvious, but with the Documentations (already great) and the forum postsss, I made good progress.
                  3 Axis+ Endstops / 2 extruders + Sensors + Fans / BED / Heated Chamber / ... everything works. few things are not working yet, i'll write other posts about them.
                  I share here my config.g, hopes it could help :
                  ; Configuration file for Duet 3 (firmware version ?.0??)
                  ; oct 2019 : X/Y/Z E1/E2 BED/CHAMBER OK - BL (not ready) SERVO (not ready)
                  ; DUET 3 6HC + 1 extension board 3HC (address 1.)
                  G90			; send absolute coordinates...
                  M83			; ...but relative extruder moves
                  M550 P"QualupQ3"	; set printer name Qualup Q3 http://www.spiderbot.eu/qu3-high-temperature/?lang=en
                  M552 P0.0.0.0 S1	; enable network and acquire dynamic address via DHCP
                  M553 P0.0.0.0		; netmask
                  M554 P0.0.0.0		; gateway
                  M586 P0 S1		; enable HTTP
                  M586 P1 S0		; disable FTP
                  M586 P2 S0		; disable Telnet
                  ;M569 P0 S1		; physical drive 0 goes forwards / driver 0 unable on this board
                  M569 P1 S1		; X physical drive 1 goes forwards
                  M569 P2 S1		; Y physical drive 2 goes backwards
                  M569 P3 S1		; Z0 physical drive 3 goes forwards
                  M569 P4 S1		; Z1 physical drive 4 goes forwards
                  M569 P1.0 S1		; E0 physical drive 1.0 on expansion board goes forwards
                  M569 P1.1 S1		; E1 physical drive 1.1 on expansion board goes forwards
                  M584 X1 Y2 Z3 E1.0:1.1				; set drive mapping 1 stepper on X, Y and 2 Steppers (Z3 instead of Z3:4 because Moteur Z1 not plug on Driver 4 at this time) on Z and Extruder
                  M350 X16 Y16 Z16 E16:16 I1			; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z400.00 E4074.37:4074.37      ; set steps per mm
                  M566 X900 Y900 Z120 E150:150			; set maximum instantaneous speed changes (mm/min)
                  M203 X6000 Y6000 Z1200 E1200:1200		; set maximum speeds (mm/min)
                  M201 X500 Y500 Z100 E250:250			; set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1200 E800:800 I30		; set motor currents (mA) and motor idle factor in per cent
                  M84 S30					; Set idle timeout
                  M208 X0 Y0 Z0 S1			; set axis minima
                  M208 X300 Y250 Z300 S0			; set axis maxima
                  M574 X1 S1 P"io6.in"			; X min active high endstop switch / pin io3.in doesnt work use 6 instead
                  M574 Y1 S1 P"io4.in"			; Y min active high endstop switch
                  M574 Z1 S1 P"io5.in"			; Z min active high endstop switch
                  ;Servo				;not working for the moment
                  ;M950 S0 C"io7.out"		;not working for the moment
                  ;M280 P0 S1500 I1		;not working for the moment
                  ; Z-Probe					;not working for the moment
                  ;M558 P9 C"zprobe.in" H5 F120 T3000           	; FW v3 BLTouch connected to Z probe IN pin
                  ;M950 S0 C"exp.heater3"                       	; FW v3 create servo/gpio 0 on heater 3 pin on expansion connector
                  ;G31 P500 X10 Y20 Z2.5                        	; set Z probe trigger value, offset and trigger height
                  ;M557 X15:6 Y15:195 S20                      	; define mesh grid
                  ; TEMPERATURE Sensors
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950			; BED temperature sensor
                  M308 S1 P"1.temp1" Y"thermistor" T4606017 B5848 C0 R4700 H0 L0	; head 0 temperature sensor on expansion board ==> DYZE 500
                  M308 S2 P"1.temp2" Y"thermistor" T4606017 B5848 C0 R4700 H0 L0	; head 1 temperature sensor on expansion board ==> DYZE 500
                  M308 S3 P"temp1" Y"thermistor" T100000 B3950			; Chamber temperature sensor
                  M308 S4 P"temp2" Y"thermistor" T100000 B3950			; CAMERA IR temperature sensor
                  M950 H0 C"out0" T0 Q100				; BED heater 3 uses the out0 pin, sensor 0
                  M950 H1 C"1.out1" T1				; HEAD heater 1 uses the out1 pin on expansion board and sensor 1
                  ;M950 H1 C"1.out1" T1 A584.4 C256.6 D6.4 S0.50	; HEAD heater 1 uses the out1 pin on expansion board and sensor 1 ==> DYZE PID Cartbridge
                  M950 H2 C"1.out2" T2                            ; HEAD heater 2 uses the out2 pin on expansion board and sensor 2
                  M950 H3 C"out1" T3                             	; CHAMBER heater 3 uses the out1 pin and sensor 3
                  M950 H4 C"out2" T4                             	; IR Camera heater 4 uses the out2 pin and sensor 4
                  ; Maximum Temperatures 	Currently (September 2019), RRF3 does not support M143.
                  ;M143 H0 S380 C0	; BED max Temp 300°C
                  ;M143 H1 S500 C0	; Extruder 1 max Temp 500°C
                  ;M143 H2 S500 C0	; Extruder 2 max Temp 500°C
                  ;M143 H3 S380 C0	; Chamber max Temp 300°C
                  ; Minimum Temperatures
                  ;M302 P1 S240 R240	; minimun extruder 1 Temperature 240°C extrusion and retract
                  ;M302 P2 S240 R240	; minimun extruder 2 Temperature 240°C extrusion and retract
                  M950 F0 C"1.out7"      	; Extruder 1 fan 0 !F1 don t work ... ???  on pin out 7 pwm on expansion board
                  M950 F2 C"1.out8"      	; Extruder 1 fan 2 on pin out 8 pwm on expansion board
                  M950 F3 C"out7"      	; Chamber fan 3 on pin out 7 pwm
                  M950 F4 C"out8"        	; IR Camera fan 4 on pin out 8 pwm
                  M563 P1 D0 H1 F0 S"Extruder 1"	; define tool 1 - F1 don t work... ???
                  G10 P1 X0 Y0 Z0			; set tool 1 axis offsets
                  G10 P1 R0 S0			; set initial tool 1 active and standby temperatures to 0C
                  M563 P2 D1 H2 F2 S"Extruder 2"	; define tool 2
                  G10 P2 X0 Y0 Z0			; set tool 2 axis offsets
                  G10 P2 R0 S0			; set initial tool 2 active and standby temperatures to 0C
                  M563 P3 H3 F3 S"Chamber"	; define tool chamber
                  G10 P3 R0 S0			; set initial tool 3 active and standby temperatures to 0C
                  M563 P4 H4 F4 S"Camera IR"      ; define tool IR Camera
                  G10 P4 R0 S0			; set initial tool 4 active and standby temperatures to 0C
                    steevebecker
                    Hey !
                    I missed the announcement ?? Duet 3 available on ==> RRF Cofiguration tool here : RRF Config Tool
                    Thanks for that !!!!
                      T3P3Tony administrators @steevebecker
                      @steevebecker give it a go, feedback requested 😄
                        steevebecker @T3P3Tony
                        @T3P3Tony first test works well:
                        My conf:
                        On 6HC:
                        • X-Y-Z steppers
                        • endstop X-Y-Z NC/low end
                        • Bed heater + T°
                        • Chamber heater + Fan + T°
                        • Filament compartiment T°
                        • Electronic compartiment T°+ Fan
                          then on 3HC
                        • 2 Extruders - 2 Fans- 2 Thermocouples
                        • 1 Servo
                        • 2 filaments presence
                        • IR Camera T°+ Fan
                        Just a Question How to add a T° sensor with out a heater ? Bed/Chamber/Nozzle Heaters are possible but can I add a sensor alone on a I/O with the RRFCT ? same for a Servo 😉
                          AFAIK you need to add these manually to your config.g as the config tool does not set them up for you.
                          See https://duet3d.dozuki.com/Wiki/Gcode#Section_M308_Set_or_report_sensor_parameters
                          Uf you give the sensor a name it should show up in the "extras" tab in DWC
                          • Vetiundefined
                            Veti
                            the tool tabs does not allow to select anything else that E0 for extruder, heater and fan
                              steevebecker @Veti
                              @Veti I have partially the same problem
                              in the I/O Mapping Tab, I have added : +1 Driver for the second extruder, +1 Heater, +1 Fan
                              pin out everything
                              but then in the Tool Tab, tools there is only FAN0 available for any tool.
                              I/O TAB:
                              Fan TAB seems ok:
                              But then in the Tool TAB
                              • Vetiundefined
                                Veti
                                ignore my comment above its working.
                                @steevebecker
                                you need to disable thermostatic control for another fan.
                                  steevebecker
                                  @Veti Make sense ! It works
                                  • jlipavsky79undefined
                                    jlipavsky79
                                    is this stable for duet3 config?? Also..... im setting up a duet3 as a cnc controler...
                                    How about cnc stuff???? A tab for cnc config like for the spindle speed output setting, for turning on and forward and reverse. Configuring for a vac system for triggering through gcode.... maybe for coolant pumps through gcode..... probing like digitizer probe.....
                                      T3P3Tony administrators @jlipavsky79
                                      @jlipavsky79 that's a good point, we do need to extend the config tool for CNC and Laser modes of operation. I hope some of the CNC experienced on the forum can suggest good options and reasonable defaults.
                                      • renehundefined
                                        reneh @chrishamm
                                        @chrishamm Hi, great work. I try to use this tool in safari browser 13.04 bud I can not open/edit XYZ Offsets in the too tab. Could you tell me please how can I fix this?
                                        • Danalundefined
                                          Danal
                                          You should get a "popup" or "overlay" like this:
                                          Does safari have any way to turn off popup blocking?
                                          renehundefined 1 Reply Last reply Reply Quote 0
                                          • PaulHewundefined
                                            PaulHew
                                            Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
                                            It is currently greyed out and is unselect-able.
                                            I mentioned it in a previous post and DC42 informed me he would look into it.
                                            Veti gave me the lines I need for it to work, mapping the pins.
                                            Thanks
                                            Paul
