    BLTouch V3.0 Reassemble
    1.8k
    • jaurandundefined
      jaurand @infiniteloop
      @infiniteloop i misunderstood, I have a set of macros for deploy and retract labeled bltouch. looking under system editor, deployprobe.g and retractprobe.g are in the sys/ directory
      • jaurandundefined
        jaurand
        still confused why the bltouch is not performing the self test at start up. other than that it appears to be operating correctly
        • lucundefined
          luc
          I say mine, maybe it has been tried but you never know.
          If with the machine off you pull out the pin and then turn it on, does the Bltouch work? Yes?
          If yes, make the extension wiring new from scratch ... I change wires I used the Cat5 ones for network cables and above all crimp the terminals well (and with the pliers).
          jaurandundefined 1 Reply Last reply Reply Quote 0
          • jaurandundefined
            jaurand @luc
            @luc said in BLTouch V3.0 Reassemble:
            The BLTouch works, just does not perform the default self test when it printer is turned on
              Do you have the alarm release at the start of config.g?
              • jaurandundefined
                jaurand @Phaedrux
                @Phaedrux I've got it right under general preferences
                ; generated by RepRapFirmware Configuration Tool v2 on Sun Mar 17 2019 11:31:51 GMT-0400 (Eastern Daylight Time)
                M575 P1 B38400 S1 ; Baudrate for Paneldue 38400
                M667 S1 ; Select CoreXY mode
                M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
                M280 P7 S160 I1 ; Alarm Release and Push pin Up
                When I power it up the BLTouch will blink its read, but running Alarm Release and Push Pin Up (M280 P7 S160 I1) results in no change.
                Only running Alarm Release & Touch SW Mode (M280 P7 S60 I1) stops the blinking, but then I have to run Push Pin Up (M280 P7 S90) so that it works correctly after.
                  Maybe move alarm release to the end of config. G to give it time to finish the self test.
                  • jaurandundefined
                    jaurand @Phaedrux
                    @Phaedrux But the BLTouch is not even doing the self test
                    • jaurandundefined
                      jaurand
                      Well new problems creeping up. Pin will not retract at start of print but print starts regardless.
                      I'm going to try a fresh install of firmware and start that from scratch to ensure updating did not cause any issues. What is the best method for this?
                        Phaedrux Moderator @jaurand
                        @jaurand Upload the firmware on the system tab of DWC and it should update automatically.
                        • jaurandundefined
                          jaurand @Phaedrux
                          @Phaedrux that is how i've been updating firmware before. My thought is something did not stick right causing my issues. Hence why delete it all and start from a fresh build is my thought
                            Can you post your config.g, homeall.g, and your deployprobe.g and retractprobe.g files from the /sys folder?
                            • jaurandundefined
                              jaurand @Phaedrux
                              @Phaedrux
                              config.g
                              M550 P"My Printer" ; Set machine name
                              M552 S1 ; Enable network
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M569 P0 S1 ; X-Axis Drive 0 goes backwards
                              M569 P1 S1 ; Y-Axis Drive 1 goes backwards
                              M569 P2 S0 ; Z-Axis Drive 2 goes forwards
                              M569 P3 S0 ; Extruder Drive 3 goes backwards
                              M92 X81 Y81 Z396 E415 ; Set steps per mm
                              M566 X600.00 Y600.00 Z100.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
                              M201 X3000.00 Y3000.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
                              M906 X1430.00 Y1430.00 Z1430.00 E1440 I35 ; Set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X330 Y330 Z415 S0 ; Set axis maxima
                              M574 X1 Y1 S0 ; Set active low and disabled endstops
                              M574 Z1 S2 ; Define Z to use Probe. Home to Min
                              M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves
                              G31 X0 Y0 Z3.467 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                              ;MeshGrid
                              M557 X50:300 Y50:300 S25 ; Define mesh grid
                              M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                              M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                              M307 H1 A306.6 C114.2 D3.6 V23.8 S1 B0
                              M570 H1 P10 T15 S15 ; Configure heater fault detection (H# heater number, P time in seconds for anomaly to persist, T temp
                              excursion setpoint, S time in mins before print cancelled)
                              M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M563 P0 D0 H1 ; Define tool 0
                              ; Automatic power saving
                              M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                              M501 ; Load saved parameters from non-volatile memory
                              homeall.g
                              ; homeall.g
                              ; called to home all axes
                              G91 ; relative positioning
                              M280 P7 S160 I1 ; Alarm Release and Pin Up
                              G1 S1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                              G1 S1 X-335 ; home X axis
                              G1 S1 Y-335 ; home Y axis
                              G1 S1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                              G1 S1 Y-335 ; then move slowly to Y axis endstop
                              G90 ; absolute positioning
                              G1 X171 Y112 F6000 ; go to first bed probe point and home Z
                              ;G91 ; relative positioning
                              ;G1 S2 Z5 F100 ; lift Z relative to current position
                              ;G90 ; absolute positioning
                              Deployprobe.g
                              M280 P7 S10 I1
                              Retractprobe.g
                              M280 P7 S90 I1
                              Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                @jaurand said in BLTouch V3.0 Reassemble:
                                Remove the X0 Y0 Z1 from this command. Those parameters are no longer used.
                                You're missing the X and Y offset between the nozzle and the BLTouch.
                                Neither of those should be show stoppers however.
                                All I can suggest at this point if you're 100% confident that your wiring is good, is to try switching to heater pin 3 of the expansion header instead of using heater pin 7.
                                You'll need to change the heater unbinding to reflect H3 instead of H7
                                And check config-override.g to remove any entry for H3.
                                As well as change the servo commands to target P3 instead of P7.
                                Deployprobe.g
                                M280 P7 S10 I1
                                Retractprobe.g
                                M280 P7 S90 I1
                                • jaurandundefined
                                  jaurand @Phaedrux
                                  @Phaedrux I don't have config-overide.g is that a problem?
                                  When I switched to H3 I get no response
                                  • jaurandundefined
                                    jaurand
                                    Here is what is in my sys folder
                                      I assumed you had a config-override.g since you have an M501 in your config.g to load it. It's fine if you don't have it thought. It just means you haven't used M500 to save any PID tuning values.
                                      • jaurandundefined
                                        jaurand @Phaedrux
                                        @Phaedrux ah yes since I typed my values directly in.
                                        So since H3 doesn't work is that a bigger problem?
                                          I'm still inclined to think it's a wiring issue.
                                          Can you make up a brand new very short wiring harness to test with?
                                            I have had many instances lately of the push pin breaking off many times as well as unresponsiveness from the BLTouch itself.
                                            It could also be a bad probe. Perhaps time to get another to try?
                                            jaurandundefined 2 Replies Last reply Reply Quote 0
