    Installing Duet Maestro in FlashForge Creator Pro (2016)
    62
    3.2k
    • Fireflyundefined
      Firefly
      Well I finally had the guts to try the "clone backwards" issue. And it worked! That is very weird that it worked on the Ramps set up fine but not on the Maestro.
      • Fireflyundefined
        Firefly
        So I think I figured out why some of these clone RepRap discount smart graphic controllers have backwards connectors, you see two different connector types, some of these PCB has the marking of a 90 degree bend connector and are fitted with a straight connector which will reverse the pins.
        https://drive.google.com/file/d/0B7O0wmhFYwlGOHpac243Wm5IN0dfQ01yajdURmdxb0F0dXBv
        https://drive.google.com/file/d/0B7O0wmhFYwlGRDhjZ1FzbnZSbUlBcDFDZ1M3R2VOTk1oZDFV
        https://drive.google.com/file/d/0B7O0wmhFYwlGQmo0VUVUdC1LMmxqdUxPaHRVLVJKOE84cHcw
        trying to get the pictures in post. upload is not working, I keep getting parsing server error
          dc42 administrators @Firefly
          The 12864 display pinout used on the Duet Maestro conforms to the pinout used on the original RepRapDiscount display. The clones of that controller that are widely sold on Amazon and eBay mostly use the same pinout. Sadly, there are some semi-clones that use the reverse connection.
          • Fireflyundefined
            Firefly
            edit . . . , removed because I made an error
            • Fireflyundefined
              Firefly
              Ok, so this is the homing file that was generated, it is using H1 instead of S1?
              what is the deal with that?
              ; homey.g
              ; called to home the Y axis
              ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 14 2019 11:58:35 GMT-0500 (Eastern Standard Time)
              G91 ; relative positioning
              G1 H1 Y150 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 H2 Y-5 F6000 ; go back a few mm
              G1 H1 Y150 F360 ; move slowly to Y axis endstop once more (second pass)
              G1 H2 Z-5 F6000 ; lower Z again
              G90 ; absolute positioning
                Phaedrux Moderator @Firefly
                @Fireflynj said in Installing Duet Maestro in FlashForge Creator Pro (2016):
                ; homey.g
                S is being used for laser mode, so H has taken it's place.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                • Fireflyundefined
                  Firefly
                  Thank you for that info!
                  so now I got an issue where my stepper motors on extruder creating interference to the Thermocouplers. I am looking for some kind of shielding now. but I thought i'll ask what did anyone else do to fix this? which option best or works, shielding thermocoupler wires or stepper motor wires?, or twisted pair wires on stepper motors?
                  Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    I try to keep all wire pairs twisted. If you can get shielding or distance between the wires that's even better.
                    It can also help to ground the motors and printer frame.
                      Thermocouples are most sensitive to inductive interference, so use twisted pair stepper motor cables, 1 pair for each phase. I assume your thermocouple wires are already twisted pair.
                      • Fireflyundefined
                        Firefly
                        Ok, I made progress. I took the time to pull stepper wires out and twisted each pair, tedious task that needed to be done, Whew! I also lowered the stepper motors amps but, I still had to pull the Thermocoupler wires out of the umbilical cord, as it was still picking up noise, yes it was also twisted. I thought of using shielded Ethernet wire but I don't have anymore crimps left.
                        Thank you.
                          Crimps are readily available in most countries on eBay and Amazon. See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers. At least one of or distributors (Filastruder) sells a kit of spare connectors.
                          • Fireflyundefined
                            Firefly
                            I stalled on this project, looking at finishing it.
                            JadonMundefined 1 Reply Last reply Reply Quote 0
                            • JadonMundefined
                              JadonM @Firefly
                              If you need any help, feel free to tag me! I just successfully finished my conversion, except for some annoying blobs!
                              Fireflyundefined 1 Reply Last reply Reply Quote 0
                              • Fireflyundefined
                                Firefly @JadonM
                                @JadonM Hi, thank you for the post, hmm I didn't get notified and I need to check on that. So another 7 months has past, but I am sitting in front of it now reviewing stuff trying to figure out where I left off. so looks like I need get code setup for priming and do a test print.
                                • Fireflyundefined
                                  Firefly
                                  it's working, printed a 20cm cube, it's so nice to have variable speed part cooling fan!, something the FlashForge Creator Pro couldn't do before , just on/off.
                                  so now I think I want to do the BLTouch tool on this printer next. I do find my nozzle gap differs from middle of print bed to edges, even with the 6.5mm glass, so my smooth rods must not be straight, is this what the BLTouch can help with?
                                    Yes if you use mesh compensation to create a heightmap of the bed.
                                    https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                                    • Fireflyundefined
                                      Firefly
                                      Cool! Ok, will be doing the BLTouch then, Thank you @Phaedrux .
                                      I saw @JadonM did a new graphical display menu
                                      https://forum.duet3d.com/topic/14774/how-to-add-a-graphical-display-to-your-printer/18
                                      with external SD card access, awesome! Thank you!
                                      I need to update the firmware first , ran M115 to see:
                                      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-11-01b1
                                      Fireflyundefined 2 Replies Last reply Reply Quote 2
                                      • Fireflyundefined
                                        Firefly @Firefly
                                        I am a little nervous doing this, I'm reading up on updating firmware and document says to make sure I have correct firmware, I understand I need to do 3.0.0 first before I get 3.1.1
                                        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
                                        but I don't see anywhere saying that this firmware is for Duet 2 Maestro.
                                        can you confirm?
                                        Thank you.
                                          A Former User @Firefly
                                          can you confirm?
                                          It contains all firmwares (duet2-wifi/ethernet/maestro and duet3) when you download the .zip file
                                            If you upload this zip file as is, without extracting it, to the system tab in DWC it should update everything needed for all Duet2 boards including the Maestro. Then do the same with the 3.1.1 zip file.
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
