    Installing Duet Maestro in FlashForge Creator Pro (2016)
    62
    3.2k
    • Fireflyundefined
      Firefly
      edit . . . , removed because I made an error
      • Fireflyundefined
        Firefly
        Ok, so this is the homing file that was generated, it is using H1 instead of S1?
        what is the deal with that?
        ; homey.g
        ; called to home the Y axis
        ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 14 2019 11:58:35 GMT-0500 (Eastern Standard Time)
        G91 ; relative positioning
        G1 H1 Y150 F1800 ; move quickly to Y axis endstop and stop there (first pass)
        G1 H2 Y-5 F6000 ; go back a few mm
        G1 H1 Y150 F360 ; move slowly to Y axis endstop once more (second pass)
        G1 H2 Z-5 F6000 ; lower Z again
        G90 ; absolute positioning
          Phaedrux Moderator @Firefly
          @Fireflynj said in Installing Duet Maestro in FlashForge Creator Pro (2016):
          ; homey.g
          S is being used for laser mode, so H has taken it's place.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
          • Fireflyundefined
            Firefly
            Thank you for that info!
            so now I got an issue where my stepper motors on extruder creating interference to the Thermocouplers. I am looking for some kind of shielding now. but I thought i'll ask what did anyone else do to fix this? which option best or works, shielding thermocoupler wires or stepper motor wires?, or twisted pair wires on stepper motors?
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              I try to keep all wire pairs twisted. If you can get shielding or distance between the wires that's even better.
              It can also help to ground the motors and printer frame.
                dc42 administrators @Firefly
                Thermocouples are most sensitive to inductive interference, so use twisted pair stepper motor cables, 1 pair for each phase. I assume your thermocouple wires are already twisted pair.
                • Fireflyundefined
                  Firefly
                  Ok, I made progress. I took the time to pull stepper wires out and twisted each pair, tedious task that needed to be done, Whew! I also lowered the stepper motors amps but, I still had to pull the Thermocoupler wires out of the umbilical cord, as it was still picking up noise, yes it was also twisted. I thought of using shielded Ethernet wire but I don't have anymore crimps left.
                  Thank you.
                    Crimps are readily available in most countries on eBay and Amazon. See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers. At least one of or distributors (Filastruder) sells a kit of spare connectors.
                    • Fireflyundefined
                      Firefly
                      I stalled on this project, looking at finishing it.
                      JadonMundefined 1 Reply Last reply Reply Quote 0
                      • JadonMundefined
                        JadonM @Firefly
                        If you need any help, feel free to tag me! I just successfully finished my conversion, except for some annoying blobs!
                        Fireflyundefined 1 Reply Last reply Reply Quote 0
                        • Fireflyundefined
                          Firefly @JadonM
                          @JadonM Hi, thank you for the post, hmm I didn't get notified and I need to check on that. So another 7 months has past, but I am sitting in front of it now reviewing stuff trying to figure out where I left off. so looks like I need get code setup for priming and do a test print.
                          • Fireflyundefined
                            Firefly
                            it's working, printed a 20cm cube, it's so nice to have variable speed part cooling fan!, something the FlashForge Creator Pro couldn't do before , just on/off.
                            so now I think I want to do the BLTouch tool on this printer next. I do find my nozzle gap differs from middle of print bed to edges, even with the 6.5mm glass, so my smooth rods must not be straight, is this what the BLTouch can help with?
                              Yes if you use mesh compensation to create a heightmap of the bed.
                              https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                              • Fireflyundefined
                                Firefly
                                Cool! Ok, will be doing the BLTouch then, Thank you @Phaedrux .
                                I saw @JadonM did a new graphical display menu
                                https://forum.duet3d.com/topic/14774/how-to-add-a-graphical-display-to-your-printer/18
                                with external SD card access, awesome! Thank you!
                                I need to update the firmware first , ran M115 to see:
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.04 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2019-11-01b1
                                Fireflyundefined 2 Replies Last reply Reply Quote 2
                                • Fireflyundefined
                                  Firefly @Firefly
                                  I am a little nervous doing this, I'm reading up on updating firmware and document says to make sure I have correct firmware, I understand I need to do 3.0.0 first before I get 3.1.1
                                  https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
                                  but I don't see anywhere saying that this firmware is for Duet 2 Maestro.
                                  can you confirm?
                                  Thank you.
                                    A Former User @Firefly
                                    can you confirm?
                                    It contains all firmwares (duet2-wifi/ethernet/maestro and duet3) when you download the .zip file
                                      If you upload this zip file as is, without extracting it, to the system tab in DWC it should update everything needed for all Duet2 boards including the Maestro. Then do the same with the 3.1.1 zip file.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                                      • Fireflyundefined
                                        Firefly @Firefly
                                        I got the firmware updated, whew, little scary, but learned just uploading zip files and the machine takes care of it is cool, but I have a question for @JadonM, in your instructions you said
                                        *upload it to your printer via the blue "Upload" button on the display tab of the web interface. *
                                        I use the "Upload menu files" button in display, to upload UltimateDuetMenuSystem-master.zip
                                        and it made a subfolder UltimateDuetMenuSystem-master
                                        is it suppose to be like that?
                                        display is still blank here and I did put the M918 P1 E-4 F2000000 code in the config.
                                          I think you're going to need to manually place the files from UltimateDuetMenuSystem-master.zip into a folder in the root of the SD card menu.
                                            @Fireflynj subfolder sounds wrong, if getting the sd card out and into a computer is tricky you might be able to decompress the zip file, and create a new that does not have a folder in the path for the archive?
