    Electrical tools recommendations - Installing Maestro
    32
    1.6k
    • fcwiltundefined
      fcwilt
      Get a ratcheted crimper with dies for the contacts you are going to use. It will save time and produce more consistent crimps.
      Don't skimp on your tools, get the best you can afford.
      • sinned6915undefined
        sinned6915
        i will 2nd the 2 step process over the ratcheting ones.
        If you have to skimp on funds, consider the IWISS Mini Micro Open Barrel Crimping Tool from somewhere like Amazon.
        Its almost as nice as the true engineer brand- they did not do as nice a job on the final finishing of the tool but its done right where it counts. The usual pics don't show the milling on the backside of the tool and that is where its a bit unpolished.
        • Blacksheep99undefined
          Blacksheep99
          Thanks everyone, really useful information. Interesting opinions differ a little but to be expected.
            A Former User
            major problem IMHO with "ratchet" crimpers (the one with dies) is that I have ~100 of them and another box full of dies for those that have replaceable dies, and there's not a single one that can do all the pins .. and if you take the wrong one, that look like they should work, you usually figure too late you messed up bunch of pins 😞 .. on top of that, 50% of those PRC made are just too imprecise ..
            for someone asking what tool to get, it's better to have PA-09 and PA-20 to be able to crimp 99% of the connectors .. then, if same person figures he's doing a lot of type X one can get crimpers for type X specifically, but the universality of pa-09 and pa-20 is IMO unprecedented.
              droftarts administrators @jens55
              @jens55 said in Electrical tools recommendations - Installing Maestro:
              Mind you, after 500 crimps (ouch) I would imagine you have it sorted.
              It wasn't 500 crimps, it was 500 wiring loom sets for 3D printers! About 50 to 60 crimps per wiring loom, as some wires came pre-crimped. It was for the first RepRapPro Ormerod printers. I didn't do it alone, but did do a lot of the crimping; wire stripping and heatshrinking being the other parts. It's a bit like muscle memory doing Molex KK-type crimps now! Fortunately we got a proper wire stripping/crimping machine after the initial run.
              Edit: So, realistically, it's about variety and quantity of crimps you are likely to crimp. If you're doing a small amount and various sizes, I'd probably say the PA-09 and PA-20 would be the most suitable, as it covers all eventualities.
                @smece said in Electrical tools recommendations - Installing Maestro:
                ...except that for the JST VH pins on Duet 3, it has to be a PA-21.
                jay_s_ukundefined A Former User? 2 Replies Last reply Reply Quote 0
                  jay_s_uk @dc42
                  Whats the difference between the PA-20 and PA-21?
                    PA-09 does 1, 1.4, 1.6 and 1.9mm
                    PA-20 does 1.6, 1.9, 2.2 and 2.3mm
                    PA-21 does 1.6, 1.9, 2.2 and 2.5mm
                    jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @droftarts
                      And I take it the duet 3 JST VH requires the 2.5mm crimp capability?
                        dc42 administrators @droftarts
                        @droftarts said in Electrical tools recommendations - Installing Maestro:
                        It's more in the shape of the jaws than the sizes. The PA21 is designed to handle the longer flanges of the VH crimps that grip the insulation.
                          jay_s_uk
                          Could I get away with the PA-20?
                            A Former User
                            @jay_s_uk said in Electrical tools recommendations - Installing Maestro:
                            If its just the width of the jaws, you can get away with doing each section in to passes, but its also tricky to partially crimp back and forth to avoid sheering off the wings. for a one or four off I'd try it before ordering the new tool. IWISS also makes several versions, all have greater ranges than the Engineer tools.
                            On the other hand, if you're in the UK and have money to spend on a universal tool this would be my choice. https://precisehandtools.com/en/crimpingtools/153-pad-02-precision-crimping-tool-kit-interchangeable-dies-hard-case-4989833035396.html
                              Blacksheep99
                              Considering we have 3d printers I guess nobody has successfully produced a 3d printed crimping tool?! 😂
                                dc42 administrators @jay_s_uk
                                For the VH connectors on Duet 3, I don't think so
                                  A Former User @dc42
                                  @dc42 said in Electrical tools recommendations - Installing Maestro:
                                  ha, so for Duet3 you are not using the same connectors, here pins have that extra-long flaps that need to curl on themselves before they grip the insulating part of the wire? damn, I need to purchase PA-21 too 😄 ...
                                  why the change ?
                                  @droftarts it's not only the width, pa-21 is, according to engineer video, different (do not have one so can't say how they work except from videos) as they can handle those extra long flaps, they curl flaps on itself and press the wire, do not curl half circle and embed in wire like the PA-09 and PA-20 .. at least that's how I understood engineer videos when I ordered mine PA-09 and PA-20
                                  @jay_s_uk I did number of those "long flaps" pins with PA-20 and it holds the wire good but looks tad ugly and tends to bend the back of the pin a bit so it can be harder to push pin into connector... you can stop pressing bit earlier and that helps if you can train your hand.. I did maybe 50 such pins total in my life so don't have too much experience with them but PA-20 got the job done, not ideally but..
                                    deckingman @A Former User
                                    .............................why the change ?
                                    On Duet 3, bigger connectors are used because of the higher current capability of the other components.
                                      A Former User @deckingman
                                      @deckingman said in Electrical tools recommendations - Installing Maestro:
                                      interesting, just checked, you are using drivers that can handle 4A on the duet3 so 3A connectors that are on duet2 will not work 🙂 makes sense ...
                                      I have my internal policy that I never use connectors when I need more than 3A and I go with screw terminals but I understand how that could be impractical for the duet ... what are the exact connectors you are using? any chance you can share a supplier code (digikey, farnell, mouser...)
                                        @smece You need Tony or David to answer those questions - I'm not part of the Duet team - just an end user like you.
                                          jay_s_uk
                                          These are the motor connectors
                                          http://www.jst-mfg.com/product/pdf/eng/eVH.pdf
                                          • oryharaundefined
                                            oryhara
                                            Klein makes excellent wire strippers. Best I've ever used. Gotta strip before you crimp.
                                            And I second the 'right tool for the right job' sentiment. especially regarding crimpers.
                                            blog: https://deltahedron.net
