    What could cause this heightmap pattern
    2.1k
    • Alex.crundefined
      Alex.cr
      Do you have any sort of magnetic build plate? I’ve seen something like this when adhesive fails on the edges of a bed covering on of one of my printers.
      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
      • jens55undefined
        jens55
        Thank you for your thought but no. It is an aluminum bed plate with a glass sheet on top and a 120V AC bed heater underneath.
          Could you post a video of the probing routine? At least a good part of it? I'd like to see what the motion of the printer is like.
          • jens55undefined
            jens55
            Unfortunately my 5 or so year old cell phone is not up to the task of taking such a video 😞 Heck, even a plain photo turns out fuzzy.
              Is the heightmap accurate? If you print a test file like this twice, once with mesh compensation and again with it deactivated, does it print better with it turned on?
              bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
              • jens55undefined
                jens55
                The height map is accurate. I have run it a total of 6 times. Twice cold, twice at 90C bed temperature and twice at a reduced resolution of 49 probe points with a cold bed.
                I then did a matrix subtraction of the two probings in each set to see the difference in readings. They turned out surprisingly consistent.
                Seeing that the difference between high areas and low areas is around 0.4 mm. it becomes very difficult to print anything without mesh compensation.
                I will give the stl you attached a try and report back.
                  Phaedrux Moderator @jens55
                  @jens55 said in What could cause this heightmap pattern:
                  It is a great feature.
                  • jens55undefined
                    jens55
                    The stl file is non printable. It imports into Cura but without a body. I can't slice it.
                      It's thin lines in a pattern. You may need to alter the extrusion width for your first layer, or enabled printing thin walls in cura?
                      • jens55undefined
                        jens55 @Phaedrux
                        @Phaedrux, I will see what I can do ... I have a 0.8 mm nozzle set up so that may be the problem.
                          In that case, try this one.
                          bedlevel_nozzle_0.8_200x200-0.4-1.6.stl
                          • jens55undefined
                            jens55
                            Dang it ... just finished making it printable ....
                            • jens55undefined
                              jens55
                              OK, the pattern is 0.4 mm tall and I am printing a 0.4 mm layer.
                              No compensation - about 1/3 of the print was ok, 1/3 was too high and 1/3 was too low.
                              WIth compensation - 95 % ok, only a small corner lifted a bit, possibly the second nozzle hitting the print.
                              Now the test was done in the middle of the bed that is relatively even.
                              Second test with mesh map active but a 0.2 mm layer height - perfect
                              Third test with same setup as second test but the model moved from the flat lands to the foothills and mountain range. Gut feeling is that the previous (flat land only) layer was a tad thicker but I have nothing but gut feeling to speak for that and the print was also 100% ok!
                              I am tickled pink about this result !
                              Of course this doesn't say anything about why the bed patterns are the way they are.
                              • JoergS5undefined
                                JoergS5
                                It would be interesting to find the reason for your intial question...
                                My ideas:
                                • you use glass, this huge difference is strange. Does your sensor measure the glass or the aluminium underneath: which type is the sensor?
                                • is the print bed fixed by screws (= do they have play for thermal expansion), is it supported below, is it bent by the screws?
                                • is the visual check in accordance with the measurement: a hairlineal would be perfect, but a h7 precision steel rod could help also, to check whether the surface is really the same as measured
                                • a mechanical reason is also possible: hotend at the right or left end could stuck the Z movement and produce wrong measurement at the edges (weight changes the angle of the axis. In the middle it's balanced)
                                • jens55undefined
                                  jens55 @JoergS5
                                  @JoergS5 said in What could cause this heightmap pattern:
                                  BLTouch so it measures the glass surface.
                                  Weeeelllll, that is a bit of an issue but doesn't explain the map. To answer the question, the normal Creality CR10 setup has 4 spring loaded screws. They are maybe 20 mm long so there is a built-in compliance. I have removed the spring, installed a locking nut underneath the bed and two nuts around the lower support - one below and one above. This does introduce some issues with stress but since the screws are fairly long, I am assuming/homing that there is enough give. If there wasn't enough give I would expect some deformation around those 4 screws but what I am seeing is completely different.
                                  Not sure what you are saying here but multiple probings ot he entire bed were done and they were confirmed to be fairly close.
                                  Not sure about this question either but off hand there is nothing that I see in the bed map that I could contribute to a slight angle change.
                                  JoergS5undefined 2 Replies Last reply Reply Quote 0
                                  • 4latheundefined
                                    4lathe
                                    What side of the bed does the wire bundle/filament come from into the carriage? High X maybe?
                                    • jens55undefined
                                      jens55 @4lathe
                                      @4lathe left side
                                      • JoergS5undefined
                                        JoergS5 @jens55
                                        @jens55 Let me clarify what I meant with points 3 and 4:
                                        Visual check: I meant you can check visually with a precision tool whether it is really your print bed which has this form or the gantry or other error A hairlineal allows to see unevenness, but if you don't have one you could use something other very even. The goal is to decide where the problem can be.
                                        Mechanical reason: I mean that your printer has two actuators to move Z, so there is a possibility that the two hinder each other moving. One possibility is that they get stuck at the sides. You can test it by temporarily more mass load on the hotend, so effects like backlash or angled axis will show in the meshmap (becoming better or worse). The mass should not be so high that the steppers don't move any more but high enough (maybe 1 kg). More differences => stuck of the movement, less differences => backlash effect.
                                        • JoergS5undefined
                                          JoergS5 @jens55
                                          @jens55 One thought to the screws: if they are steel screws, e-module is 210 for steel, aluminium is 70 and glass between 40 and 90, so a thermal expansion will bend the aluminium and glass, not the screws. So I wouldn't completely rule it out as possible reason.
                                          Thermal expansion of Aluminium is about 1.5 mm for 100 degree difference for 500 mm. I was surprised to calculate how much a plate bends: the calculator https://www.arndt-bruenner.de/mathe/scripts/kreissehnen.htm tells me, if 500 mm is compressed to 501 mm (s = 500, b = 501) and the plate bends because the screws fix it, it bends by 13 mm height (value a)! (incredible and counterintuitive). So even if it only bends the plate a bit, this may be enough.
                                          Bending of glass without thermal effect could be because of former expansion bending and hysteresis effect, not being flat after cooling down.
                                          • jens55undefined
                                            jens55
                                            The screws are 4mm steel but the glass plate is of course not 'fixed' as such but held on with spring clips in the corners. I never did bother to calculate the rate of expansion for aluminum. Although it is higher than I would have guessed at 1.5 mm, I am not terribly surprised. That is 0.75mm per screw so yes, I can see a bit of bending happening. But again, I would expect a somewhat even bending rather than a linear bending that I see.
                                            13mm of bending ??? Not a chance. The screws will move first. Some bending - possibly ... but again, the glass bed is somewhat isolated from the aluminum and again the linear pattern of distortion seems counter-intuitive. STill, I suppose it is possible.
                                            I wonder what the map would look like if I removed the corner clips. The probing happens slow enough so the plate doesn't move by itself without he clips and it will be an interesting thing to find out.
