    Prusa upgraded to duet, weird extrusion
    109
    6.2k
    • Murloc992undefined
      Murloc992 @Phaedrux
      @Phaedrux It does, in fact, all the 0.9 degree motors I bought sound like that. Even without load.. I suspect that I need to adjust something in the drivers themselves. I used 1.8 degree steppers, now I got 0.9 degree ones.
      "Prusa Bear" : Full Bear frame, Bear X-Axis and Extruder. Duet 2 WiFi with RRF 3.2.2.
        What is the power supply?
        Murloc992undefined 1 Reply Last reply Reply Quote 0
          Murloc992 @Phaedrux
          @Phaedrux Whatever came with Prusa MK2S originally.. 12V and I guess 20A? Maybe 15A, not sure.
            Can you post the results of an M122 command after doing a print?
            Murloc992undefined 2 Replies Last reply Reply Quote 0
              Using 8x microstepping probably won't do much other than make the motor noisier.
              I use the same E3D motor for my Titan aero without such a pattern.
                Murloc992 @Phaedrux
                @Phaedrux
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3S4-6JKDD-3S06R-KBQ3D
                Used output buffers: 3 of 24 (7 max)
                Static ram: 25680
                Dynamic ram: 92824 of which 0 recycled
                Exception stack ram used: 436
                Never used ram: 12132
                Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1664) IDLE(ready,200)
                Owned mutexes:
                Last reset 00:06:26 ago, cause: software
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12132 bytes (slot 0)
                Error status: 0
                Free file entries: 9
                SD card longest block write time: 10.7ms, max retries 0
                MCU temperature: min 41.3, current 41.7, max 42.4
                Supply voltage: min 12.1, current 13.0, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: ok, SG min/max 0/384
                Driver 1: standstill, SG min/max 0/400
                Driver 2: ok, SG min/max not available
                Driver 3: ok, SG min/max 0/463
                Driver 4: ok, SG min/max not available
                Date/time: 2019-12-18 23:02:44
                Cache data hit count 1365610563
                Slowest loop: 117.87ms; fastest: 0.06ms
                Hiccups: 0, FreeDm: 157, MinFreeDm: 146, MaxWait: 135474ms
                Bed compensation in use: mesh, comp offset 0.007
                === DDARing ===
                Scheduled moves: 357, completed moves: 353, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Heater 0 is on, I-accum = 0.7
                Heater 1 is on, I-accum = 0.6
                Segments left: 1
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is doing "G1 Z2.198 X134.775 Y95.225 E0.63527" in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 83.15ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is running
                WiFi firmware version 1.23
                WiFi MAC address 80:7d:3a:15:2c:b0
                WiFi Vcc 3.39, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25696
                WiFi IP address 192.168.1.253
                WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                === Filament sensors ===
                Extruder 0 sensor: ok
                I am doing a print right now, so here you go. 🙂
                FYI the PSU IS overvolted to 12.5V.
                @Phaedrux said in Prusa upgraded to duet, weird extrusion:
                Yup, didn't do anything. 😄
                  Murloc992 @Phaedrux
                  @Phaedrux
                  This is after a full print:
                  12/18/2019, 11:58:36 PM	M122
                  Used output buffers: 1 of 24 (7 max)
                  Static ram: 25680
                  Exception stack ram used: 460
                  Never used ram: 12108
                  Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1564) IDLE(ready,200)
                  Owned mutexes:
                  Last reset 00:28:34 ago, cause: software
                  Last software reset at 2019-12-18 23:29, reason: User, spinning module GCodes, available RAM 12124 bytes (slot 1)
                  Error status: 0
                  Free file entries: 10
                  SD card longest block write time: 39.2ms, max retries 0
                  MCU temperature: min 42.1, current 43.4, max 44.0
                  Supply voltage: min 11.6, current 13.0, max 13.6, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: standstill, SG min/max 0/1023
                  Driver 1: standstill, SG min/max 0/1023
                  Driver 3: standstill, SG min/max 0/1023
                  Date/time: 2019-12-18 23:58:33
                  Slowest loop: 156.87ms; fastest: 0.06ms
                  Hiccups: 0, FreeDm: 160, MinFreeDm: 114, MaxWait: 68278ms
                  Bed compensation in use: mesh, comp offset 0.005
                  === DDARing ===
                  Heater 0 is on, I-accum = 0.5
                  Heater 1 is on, I-accum = 0.5
                  Segments left: 0
                  file is idle in state(s) 0
                  === Network ===
                  Slowest loop: 157.02ms; fastest: 0.00ms
                  - WiFi -
                  WiFi flash size 4194304, free heap 25936
                  WiFi signal strength -41dBm, reconnections 0, sleep mode modem
                  12/18/2019, 11:56:54 PM	Finished printing file 0:/gcodes/Ripple_test_0.2mm_PET__19m.gcode, print time was 0h 26m
                  The print:
                  The config:
                  ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 21:16:45 GMT+0200 (Eastern European Standard Time)
                  G90                                       ; send absolute coordinates...
                  M83                                       ; ...but relative extruder moves
                  M550 P"Prusa Bear MK2.5"                              ; set printer name
                  M552 S1                                   ; enable network
                  M586 P0 S1                                ; enable HTTP
                  M586 P1 S0                                ; disable FTP
                  M586 P2 S0                                ; disable Telnet
                  M569 P0 S1                                ; physical drive 0 goes forwards
                  M569 P1 S1                                ; physical drive 1 goes forwards
                  M569 P2 S1                                ; physical drive 2 goes forwards
                  M569 P3 S1                                ; physical drive 3 goes forwards
                  M569 P4 S1                                ; physical drive 4 goes forwards
                  M584 X0 Y1 Z2:4 E3                        ; set drive mapping
                  M671 X-36.0:290.0 Y110:110 S1             ; Set the Z motor relative locations correction 1mm
                  M350 X16 Y16 Z16 E16 I1                   ; configure microstepping with interpolation
                  M92 X200.00 Y200.00 Z400.00 E276          ; set steps per mm
                  M566 X600.00 Y600.00 Z12.00 E150.00       ; set maximum instantaneous speed changes (mm/min)
                  M203 X9000.00 Y9000.00 Z360.00 E7200.00   ; set maximum speeds (mm/min)
                  M201 X1000.00 Y1000.00 Z200.00 E10000.00  ; set accelerations (mm/s^2)
                  M906 X1200 Y1200 Z600 E1200 I30              ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                   ; Set idle timeout
                  M208 X0 Y-4 Z0 S1                         ; set axis minima
                  M208 X250 Y210 Z210 S0                    ; set axis maxima
                  M574 X1 Y1 S1                             ; set active high endstops
                  M574 Z1 S2                                ; set endstops controlled by probe
                  M558 P1 H0.85 F600 T12000 ;A3 S-0.03       ; set Z probe type to switch and the dive height + speeds
                  G31 P500 X23 Y5 Z0.625                    ; set Z probe trigger value, offset(original 0.875) and trigger height
                  M557 X24:228 Y6:210 S50                   ; define mesh grid
                  ; Filament Sensor
                  M591 D0 P2 C3 S1
                  M307 H0 B0 S1.00                          ; disable bang-bang mode for the bed heater and set PWM limit
                  M305 P0 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 0
                  M143 H0 S120                              ; set temperature limit for heater 0 to 120C
                  M305 P1 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 1
                  M143 H1 S280                              ; set temperature limit for heater 1 to 280C
                  M106 P0 S0 I0 F500 H-1                    ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1 T45                 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                          ; define tool 0
                  G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
                  G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
                  T0                                        ; select first tool
                  Maybe my acceleration/jerk values are bad now? This is the first time I do such a conversion. I switched from 1.8 degree to 0.9 degree on X/Y and E. The config is still for 1.8 degree motors except for the steps and currents. Z motors are still original.
                  Interesting observation: the movement seemed to pause A LOT. Especially between infill/perimeters and z-lifts/retractions. Felt very sluggish.
                    Phaedrux Moderator @Murloc992
                    @Murloc992 said in Prusa upgraded to duet, weird extrusion:
                    Yes your Z and E axis settings are very conservative. this will make for slow retractions and layer changes / zhops.
                    The low XY jerk and acceleration don't seem to match up with the large amount of ringing you are seeing. Are your belts a little loose?
                    Here's what I use on my i3
                    M566 X800 Y800 Z60 E3000 P1				; Set maximum instantaneous speed changes (mm/min)
                    M203 X12000 Y12000 Z900 E6000				; Set maximum speeds (mm/min)
                    M201 X6000 Y6000 Z200 E5000				; Set accelerations (mm/s^2)
                    M204 P600 T3000						; Set accelerations (mm/s^2) for print and travel moves
                    • JamesMundefined
                      JamesM
                      The pauses you speak of are most likely due to the jerk setting you have for your z-axis and extruder. If you are using pressure advance I would change the extruder instantaneous speed change (jerk) to something around 2000 and the Z somewhere in the 150-300 range.
                        Murloc992 @Phaedrux
                        I will try your settings. My belts are not loose, just the right tension, printer moves more smoothly and silently with these motors I put on. Hopefully it's just a setting issue.
                        I will take a video of it printing in the evening.
                        No other variables except for the motors have changed.
                          Murloc992 @Phaedrux
                          @Phaedrux
                          So I used your settings, prints look identical, just that it printed WAY faster. Weird..
                          I just noticed that my X idler might be bigger than Y one.. I will investigate shortly..
                            Murloc992
                            Nope, seems identical. I am out of what I can do. Every axis seems to move extremely smoothly and fast. The frame is as rigid as it gets..
                              T3P3Tony administrators @Murloc992
                              @Murloc992 if you are still seeing the weird pulsing with @Phaedrux 's config then it might be worth swapping that motor with one of the other ones you bought to confirm that the problem is not with the motor.
                              Another bit of elimination is to try using E1 for the extruder to rule out some weird failure mode of the driver (highly unlikely but you never know). You can use M584 to switch between E0 and E1
                                Murloc992 @T3P3Tony
                                @T3P3Tony I already tried switching the motor, same pulsing. I haven't tried switching the driver yet, but I use dual Z, can I set Z as E0?
                                  @Murloc992 yes remap as you like. Also another option for this test you can connect two Z in series to the Z motor connector
                                    Murloc992 @T3P3Tony
                                    @T3P3Tony I am printing another single wall cube and notice something new with new acceleration/jerk settings. I will post soon. I still hear the pulsing though, but it looks a bit different than before.
                                      Murloc992
                                      X Axis:
                                      Y Axis:
                                      As you can see, increasing the settings(speeds, acceleration) made the pattern reversed(of all the things) and more intense. 😅
                                        @Murloc992 what about rotation by 45degrees?
                                          Murloc992 @T3P3Tony
                                          @T3P3Tony
                                          Let me try. 🤔
                                            Murloc992
                                            Original cube on the left, the 45 degree rotated on the right:
