    Prusa upgraded to duet, weird extrusion
    109
    6.2k
      droftarts administrators @Murloc992
      @Murloc992 Quite possibly one of those! As it's so consistent, I'd think it has to be mechanical. If you can't spot anything obvious, maybe refit the old motor and revert extruder settings in config.g?
      Murloc992undefined 1 Reply Last reply Reply Quote 0
      • Murloc992undefined
        Murloc992 @droftarts
        @droftarts
        Every time I have to take the extruder of a prusa apart(including the wiring loom) I die a little inside, but I guess I will have to if I can't center the main gear.. 😞
        Will need to upgrade the extruder wiring loom someday to use a PCB at the back, so the wiring loom will be independent..
        "Prusa Bear" : Full Bear frame, Bear X-Axis and Extruder. Duet 2 WiFi with RRF 3.2.2.
          The fact that you can hear it pulsing makes me think it's the motor itself. Does it still sound like that if you run it free of any connection to the extruder gearing?
            Murloc992
            The motor shaft is straight, the gear is straight. Motor switch didn't help. All of them pulse. I will try reducing my microsteps to 8.. Maybe somebody knows about a TMC parameter called "Velocity"? I remember there's some register adjustments but I can't find it at the moment..
              Murloc992 @Phaedrux
              @Phaedrux It does, in fact, all the 0.9 degree motors I bought sound like that. Even without load.. I suspect that I need to adjust something in the drivers themselves. I used 1.8 degree steppers, now I got 0.9 degree ones.
                What is the power supply?
                  Murloc992 @Phaedrux
                  @Phaedrux Whatever came with Prusa MK2S originally.. 12V and I guess 20A? Maybe 15A, not sure.
                    Can you post the results of an M122 command after doing a print?
                    Murloc992undefined 2 Replies Last reply Reply Quote 0
                      Using 8x microstepping probably won't do much other than make the motor noisier.
                      I use the same E3D motor for my Titan aero without such a pattern.
                        Murloc992 @Phaedrux
                        @Phaedrux
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-9T6BU-FG3S4-6JKDD-3S06R-KBQ3D
                        Used output buffers: 3 of 24 (7 max)
                        Static ram: 25680
                        Dynamic ram: 92824 of which 0 recycled
                        Exception stack ram used: 436
                        Never used ram: 12132
                        Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1664) IDLE(ready,200)
                        Owned mutexes:
                        Last reset 00:06:26 ago, cause: software
                        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12132 bytes (slot 0)
                        Error status: 0
                        Free file entries: 9
                        SD card longest block write time: 10.7ms, max retries 0
                        MCU temperature: min 41.3, current 41.7, max 42.4
                        Supply voltage: min 12.1, current 13.0, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: ok, SG min/max 0/384
                        Driver 1: standstill, SG min/max 0/400
                        Driver 2: ok, SG min/max not available
                        Driver 3: ok, SG min/max 0/463
                        Driver 4: ok, SG min/max not available
                        Date/time: 2019-12-18 23:02:44
                        Cache data hit count 1365610563
                        Slowest loop: 117.87ms; fastest: 0.06ms
                        Hiccups: 0, FreeDm: 157, MinFreeDm: 146, MaxWait: 135474ms
                        Bed compensation in use: mesh, comp offset 0.007
                        === DDARing ===
                        Scheduled moves: 357, completed moves: 353, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                        Heater 0 is on, I-accum = 0.7
                        Heater 1 is on, I-accum = 0.6
                        Segments left: 1
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is doing "G1 Z2.198 X134.775 Y95.225 E0.63527" in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 83.15ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        - WiFi -
                        Network state is running
                        WiFi firmware version 1.23
                        WiFi MAC address 80:7d:3a:15:2c:b0
                        WiFi Vcc 3.39, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 25696
                        WiFi IP address 192.168.1.253
                        WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                        === Filament sensors ===
                        Extruder 0 sensor: ok
                        I am doing a print right now, so here you go. 🙂
                        FYI the PSU IS overvolted to 12.5V.
                        @Phaedrux said in Prusa upgraded to duet, weird extrusion:
                        Yup, didn't do anything. 😄
                          Murloc992 @Phaedrux
                          @Phaedrux
                          This is after a full print:
                          12/18/2019, 11:58:36 PM	M122
                          Used output buffers: 1 of 24 (7 max)
                          Static ram: 25680
                          Exception stack ram used: 460
                          Never used ram: 12108
                          Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1564) IDLE(ready,200)
                          Owned mutexes:
                          Last reset 00:28:34 ago, cause: software
                          Last software reset at 2019-12-18 23:29, reason: User, spinning module GCodes, available RAM 12124 bytes (slot 1)
                          Error status: 0
                          Free file entries: 10
                          SD card longest block write time: 39.2ms, max retries 0
                          MCU temperature: min 42.1, current 43.4, max 44.0
                          Supply voltage: min 11.6, current 13.0, max 13.6, under voltage events: 0, over voltage events: 0, power good: yes
                          Driver 0: standstill, SG min/max 0/1023
                          Driver 1: standstill, SG min/max 0/1023
                          Driver 3: standstill, SG min/max 0/1023
                          Date/time: 2019-12-18 23:58:33
                          Slowest loop: 156.87ms; fastest: 0.06ms
                          Hiccups: 0, FreeDm: 160, MinFreeDm: 114, MaxWait: 68278ms
                          Bed compensation in use: mesh, comp offset 0.005
                          === DDARing ===
                          Heater 0 is on, I-accum = 0.5
                          Heater 1 is on, I-accum = 0.5
                          Segments left: 0
                          file is idle in state(s) 0
                          === Network ===
                          Slowest loop: 157.02ms; fastest: 0.00ms
                          - WiFi -
                          WiFi flash size 4194304, free heap 25936
                          WiFi signal strength -41dBm, reconnections 0, sleep mode modem
                          12/18/2019, 11:56:54 PM	Finished printing file 0:/gcodes/Ripple_test_0.2mm_PET__19m.gcode, print time was 0h 26m
                          The print:
                          The config:
                          ; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 21:16:45 GMT+0200 (Eastern European Standard Time)
                          G90                                       ; send absolute coordinates...
                          M83                                       ; ...but relative extruder moves
                          M550 P"Prusa Bear MK2.5"                              ; set printer name
                          M552 S1                                   ; enable network
                          M586 P0 S1                                ; enable HTTP
                          M586 P1 S0                                ; disable FTP
                          M586 P2 S0                                ; disable Telnet
                          M569 P0 S1                                ; physical drive 0 goes forwards
                          M569 P1 S1                                ; physical drive 1 goes forwards
                          M569 P2 S1                                ; physical drive 2 goes forwards
                          M569 P3 S1                                ; physical drive 3 goes forwards
                          M569 P4 S1                                ; physical drive 4 goes forwards
                          M584 X0 Y1 Z2:4 E3                        ; set drive mapping
                          M671 X-36.0:290.0 Y110:110 S1             ; Set the Z motor relative locations correction 1mm
                          M350 X16 Y16 Z16 E16 I1                   ; configure microstepping with interpolation
                          M92 X200.00 Y200.00 Z400.00 E276          ; set steps per mm
                          M566 X600.00 Y600.00 Z12.00 E150.00       ; set maximum instantaneous speed changes (mm/min)
                          M203 X9000.00 Y9000.00 Z360.00 E7200.00   ; set maximum speeds (mm/min)
                          M201 X1000.00 Y1000.00 Z200.00 E10000.00  ; set accelerations (mm/s^2)
                          M906 X1200 Y1200 Z600 E1200 I30              ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                   ; Set idle timeout
                          M208 X0 Y-4 Z0 S1                         ; set axis minima
                          M208 X250 Y210 Z210 S0                    ; set axis maxima
                          M574 X1 Y1 S1                             ; set active high endstops
                          M574 Z1 S2                                ; set endstops controlled by probe
                          M558 P1 H0.85 F600 T12000 ;A3 S-0.03       ; set Z probe type to switch and the dive height + speeds
                          G31 P500 X23 Y5 Z0.625                    ; set Z probe trigger value, offset(original 0.875) and trigger height
                          M557 X24:228 Y6:210 S50                   ; define mesh grid
                          ; Filament Sensor
                          M591 D0 P2 C3 S1
                          M307 H0 B0 S1.00                          ; disable bang-bang mode for the bed heater and set PWM limit
                          M305 P0 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 0
                          M143 H0 S120                              ; set temperature limit for heater 0 to 120C
                          M305 P1 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 1
                          M143 H1 S280                              ; set temperature limit for heater 1 to 280C
                          M106 P0 S0 I0 F500 H-1                    ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1 I0 F500 H1 T45                 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                          ; define tool 0
                          G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
                          G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
                          T0                                        ; select first tool
                          Maybe my acceleration/jerk values are bad now? This is the first time I do such a conversion. I switched from 1.8 degree to 0.9 degree on X/Y and E. The config is still for 1.8 degree motors except for the steps and currents. Z motors are still original.
                          Interesting observation: the movement seemed to pause A LOT. Especially between infill/perimeters and z-lifts/retractions. Felt very sluggish.
                            Phaedrux Moderator @Murloc992
                            @Murloc992 said in Prusa upgraded to duet, weird extrusion:
                            Yes your Z and E axis settings are very conservative. this will make for slow retractions and layer changes / zhops.
                            The low XY jerk and acceleration don't seem to match up with the large amount of ringing you are seeing. Are your belts a little loose?
                            Here's what I use on my i3
                            M566 X800 Y800 Z60 E3000 P1				; Set maximum instantaneous speed changes (mm/min)
                            M203 X12000 Y12000 Z900 E6000				; Set maximum speeds (mm/min)
                            M201 X6000 Y6000 Z200 E5000				; Set accelerations (mm/s^2)
                            M204 P600 T3000						; Set accelerations (mm/s^2) for print and travel moves
                            • JamesMundefined
                              JamesM
                              The pauses you speak of are most likely due to the jerk setting you have for your z-axis and extruder. If you are using pressure advance I would change the extruder instantaneous speed change (jerk) to something around 2000 and the Z somewhere in the 150-300 range.
                                Murloc992 @Phaedrux
                                I will try your settings. My belts are not loose, just the right tension, printer moves more smoothly and silently with these motors I put on. Hopefully it's just a setting issue.
                                I will take a video of it printing in the evening.
                                No other variables except for the motors have changed.
                                  Murloc992 @Phaedrux
                                  @Phaedrux
                                  So I used your settings, prints look identical, just that it printed WAY faster. Weird..
                                  I just noticed that my X idler might be bigger than Y one.. I will investigate shortly..
                                    Murloc992
                                    Nope, seems identical. I am out of what I can do. Every axis seems to move extremely smoothly and fast. The frame is as rigid as it gets..
                                      T3P3Tony administrators @Murloc992
                                      @Murloc992 if you are still seeing the weird pulsing with @Phaedrux 's config then it might be worth swapping that motor with one of the other ones you bought to confirm that the problem is not with the motor.
                                      Another bit of elimination is to try using E1 for the extruder to rule out some weird failure mode of the driver (highly unlikely but you never know). You can use M584 to switch between E0 and E1
                                        Murloc992 @T3P3Tony
                                        @T3P3Tony I already tried switching the motor, same pulsing. I haven't tried switching the driver yet, but I use dual Z, can I set Z as E0?
                                          @Murloc992 yes remap as you like. Also another option for this test you can connect two Z in series to the Z motor connector
                                            Murloc992 @T3P3Tony
                                            @T3P3Tony I am printing another single wall cube and notice something new with new acceleration/jerk settings. I will post soon. I still hear the pulsing though, but it looks a bit different than before.
