Unsolved Prusa upgraded to duet, weird extrusion
@Murloc992 if you are still seeing the weird pulsing with @Phaedrux 's config then it might be worth swapping that motor with one of the other ones you bought to confirm that the problem is not with the motor.
Another bit of elimination is to try using E1 for the extruder to rule out some weird failure mode of the driver (highly unlikely but you never know). You can use M584 to switch between E0 and E1
@T3P3Tony I already tried switching the motor, same pulsing. I haven't tried switching the driver yet, but I use dual Z, can I set Z as E0?
@Murloc992 yes remap as you like. Also another option for this test you can connect two Z in series to the Z motor connector
@T3P3Tony I am printing another single wall cube and notice something new with new acceleration/jerk settings. I will post soon. I still hear the pulsing though, but it looks a bit different than before.
X Axis:
Y Axis:
As you can see, increasing the settings(speeds, acceleration) made the pattern reversed(of all the things) and more intense.
@Murloc992 what about rotation by 45degrees?
Let me try.
Original cube on the left, the 45 degree rotated on the right:
It's gotta be the new extruder motor. Perhaps it came bad from E3D?
I tried the X and Y motors instead of it, all the same..
Could it be belts? I changed mine to spring steel mesh belts(because I didn't have any others), I will buy proper (normal) gt2 belts tomorrow.
But I think with belts I would have perimeter patterns, matching the tooth spacing..
@Murloc992 said in Prusa upgraded to duet, weird extrusion:
That might explain the excessive ringing shown on the other models, but I don't think it explains the diagonal pattern on the cubes.
The primeter walls seem to be perfect when looked from above though.
Now that I zoomed the picture in, it seems microscopically blobby..?
Were you able to test a different driver yet?
I will right now.
Same..
The light is non uniform but all of them look semi identical.
Left to right: the original one, 45 degree, 45 degree + swapped driverI made a video while printing this one:
Raise your volume a lot to hear the pulsing:
https://www.youtube.com/watch?v=wpG9eKp1ytAI know it's not the bondtech gear or the shaft for sure, as it is spinning slowly and pulsing dozens of times per rotation. Same was with the other motors.
Does the pulsing include your original 1.8ΒΊ motors?
No, in the beginning of this thread I posted some older pics using the old motors. All I had were VFAs and ghosting.
Actually in one pic I see faint diagonal pattern. I will test in the morning.
I was gonna say i know what it is since i had something similar, when you said the motors didnt have flat spots i thought the set screw stands out too far and hits the other gear when doing a full rotation and presses the two apart for a second, but since you said it happens multiple times per revolution it cant be that... but might not hurt to check the set screw is flush anyway?
It's not the set screw sadly. The extruder motor has a flat spot originally, others didn't but now have. A small metal file helped me with that.
Another interesting observation with the new motor:
10mm/s, 5mm/s extruder moves = smooth, but noisy.
1mm/s moves = pulsing is intense even without engaged gears.Old motor:
10mm/s, 5mm/s extruder moves = pulsing very very silently, but rapidly.
1mm/s moves = pulsing extremely, even more than the new one, but more silently.Video:
old motor, 800mA driver, 1mm/s retract move without engagement.https://youtu.be/rdDz5NVbe4k
(Increase the volume, a lot)https://youtu.be/LKBhyVVs9oE
(Can be heard way better in this one)Could it be the power supply? It's 3++ years old and has seen its fair share of life..
